    can i build software before hardware and how do i go about that ?
    13 Posts 6 Posters 4.5k Views 6 Watching
      mezcalbomb @UncleRoger
      @UncleRoger that sounds interesting. but it would require me to buy 2 Rpi then which would raise the cost significant. but on the other hand if i intend do do multiple in the future it could def be worth it.
      mumblebajM UncleRogerU 2 Replies Last reply Reply Quote 0
      • thgmirrorT Offline
        thgmirror @mezcalbomb
        @mezcalbomb
        You can use virtualbox (you may find images/instructions in the internet) to get a running raspberry and additionally install MM2 there…
        Without looking deeper in it, but https://pimylifeup.com/raspberry-pi-virtualbox/ may work.
        • mumblebajM Offline
          mumblebaj Module Developer @mezcalbomb
          @mezcalbomb If you have a windows machine I would suggest running Ubuntu on it and install MM in there to test what you want and how you want it all setup etc.
            sdetweil @mumblebaj
            @mumblebaj but you can run MM on windows without any extra stuff… just a tiny set of install process changes
              @sdetweil Wasn’t sure if the Windows install was working properly. Thought I saw in one of your recent posts that it wasn’t working properly. My bad…
                MMRIZE
                You can build MM on any device, Windows, MacOS, any Linux Distros,
                But you cannot “copy & paste” built MM to another device. (Yup… maybe Dump would be possible in some environments, but not all. Using Docker is another topic.)
                Finally, you need to build your own infra of the target device.(OS setup, some configuration, WIFI setup, and so on.) Then, you have to install MM(and its dependencies like nodeJS) manually or with the help of scripts.
                After that, you can copy & paste custom.css and config.js from your test environment. But maybe 3rd-party modules should be installed again by your hand.
                Not as difficult as it sounds. Good luck.
                  sdetweil @mumblebaj
                  @mumblebaj and its documented in the MM install section
                  https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems
                  • UncleRogerU Offline
                    UncleRoger @mezcalbomb
                    @mezcalbomb
                    Not necessarily… you can use the one RPi remotely. Before I got the second RPi, I was doing testing and setup on the main one downstairs. It worked fine. I have a browser tab open pointing to it so I can see what’s going on.
                    You didn’t specify what hardware you wanted to wait on – I assumed you meant you wanted to get the MM set up before you physically built the frame and such for it. If you have an old monitor, you can plug your RPi into it or you should be able to run it without a monitor and just see the MM in the browser on your main computer.
                    I managed to scrounge up a second RPi which means I can break stuff on it while the first one is still (relatively) functional downstairs, even though I haven’t gotten around to building a frame or mounting it on the wall. But you could still set things up with just one RPi as long as you’re not trying to put it into production before you finalize everything. (Or if you back up your settings frequently. Get Sam’s backup scripts.)
                      mezcalbomb
                      this sounds like a smart plan, then initial cost will only be cost of RPi while i try to develop a dashboard i like.
                      Thanks for answer.
                        sdetweil @mezcalbomb
                        @mezcalbomb and again, you can do this on your windows PC for free
