    Modifying the Config File
    101 Posts 7 Posters 184.4k Views 7 Watching
      sdetweil @jimb
      @jimb weather is done all in the browser, so open the browser developers window.
      ctrl-shift-i on the browser keyboard, select the console tab and put weath in the filter field
      show any errors… I suspect 401, not authorized.
      you are using a v3 API key, so have to add the apiVersion:“3.0”
      to the weather module config
        jimb
        Sorry, your reply is higher than my limited knowledge :
        Do I have to enter some line(s) in the config file? I had no success with the browser instructions.
          sdetweil @jimb
          @jimb notjing in config.js. we are trying to look at the errors from the module
          so you need to use the browser you are viewing mm with
          three keys on the keyboard.
          ctrl-shift-i
          or npm start dev
          to start mm with the dev window open
          then select the console tab
          • UncleRogerU Offline
            UncleRoger @jimb
            @jimb I will always defer to @sdetweil 's greater knowledge and intelligence but another option is (I hope, anyway, since it’s what I’m using) to use the latitude and longitude of your location. I have the weather module set up to show my wife’s school using the coordinates. (We are known for our microclimates here – her school 2 miles away may have completely different weather from what we have at home.)
            To get the coordinates, I went to maps.google.com, clicked on a location, then copied the resulting URL. It should look like this:
            https://www.google.com/maps/@37.7761918,-122.4222641,16.25z?entry=ttu
            The first number after the @ sign is the latitude; the second is the longitude. So you could put in your config file:
            lat: 37.7761918,
            lon: -122.4222641,
            and it will show the weather for your location (or the San Francisco War Memorial Opera House in that example). This might be handy if you’re not near a city listed in the file.
            UncleRogerU 1 Reply Last reply Reply Quote 0
              UncleRoger @UncleRoger
              And now, having actually looked at the file in question, I see it includes latitude and longitude for each entry. Very cool.
                jimb
                Sam, some progress. Operating in “dev” mode I do show status 401 unauthorized . However I am unable to 'place the ‘V 3.0’ in a way/place where it is recognized correctly. I tried placing it on its own “3.0” “API id…” and inside the quote mark "3.0 API ID …
                That gives me a syntax error and blows up the config file.
                  sdetweil @jimb
                  @jimb all the parms to a module go inside the modules
                  config:{} section
                  things to the left of : do not need quotes
                  things to the right of : do not need quotes if they are true/false, or a number
                  otherwise they need quotes. single or double doesn’t.mattet as long as both ends are the same.
                  also for each.parm you add, it needs to tell the interpreter if there is more after it. do this by adding a trailing comma
                  the apiVersion Parm
                     module:"weather",
                     position mmmmm ,
                      config:{
                              apiVersion:3.0,
                               whatever other parms
                    jimb
                    Sam, I seem to be deeper in the weeds. After adding the apiVersion:3.0 parameter just below the config identifier in the config file -
                    running dev displays the following error-
                    Uncaught SyntaxError: Unexpected identifier 'weather identifie ‘weatherProvider’
                    and the config file blows up.
                    Do I need to add this on some other line?
                      sdetweil @jimb
                      @jimb after the config: for the module
                        jimb
                        Sam, that’s where I put it. I can’t cut and paste here because I’m on a different computer than the Pi.
                          sdetweil @jimb
                          @jimb said in Modifying the Config File:
                          turn on ssh, and install the bitvise or winscp ssh clients
                          then you can do everything from your PC. it’s SOOOOO much better
                            jimb
                            Sam , After adding the commas to the end of the version Iine I ran it with the check on the config file- All OK. I ran MM in Dev mode and now am getting a 401 error when it attempts to load the openweather resource files. So I seem to not be passing the version or ID string>
                              sdetweil @jimb
                              @jimb can you show the config for the weather module…
                                jimb
                                Sam, as a last resort (operating from 2 computers) I attemped to take a picture with my phone and copy that here. No luck. I hear you about working from my PC on the pi, but beyond my experience level. I could try and copy to another place or system?
                                  sdetweil @jimb
                                  @jimb posting your pic is the third icon from the right above the message editor
                                    jimb
                                    Co
                                    Sam, I get an error when trying to copy the file. Does it need to have a particular extension?
                                      sdetweil @jimb
                                      @jimb copy what file?
                                        jimb
                                        Phone picture of the Config.js file. The picture has a jpg extension.
                                          sdetweil @jimb
                                          @jimb never any trouble, 3rd icon from the right
                                            jimb
                                            Sam, I don’t know why the picture is not copied, I suspect it is over-sized. Dev yield
                                            The first 12 s the following error message:
                                            Failed to load resource: the api.openweatherapp.0…c6acaacfb123ce212:1 server responded with a status of 401 (unauthorized)
                                            (twice)
                                            Could not locate data …TypeError: Cannot read openweathermap.is 43 properties of undefined (reading ‘humidity’)
                                            …then as time increases and it tries to update the screen more specific error messages occur
                                            Thye first 12 characters of my api id are truncated in the first error message text above
                                            • 1 / 6
