    Modifying the Config File
    101 Posts 7 Posters 192.5k Views 7 Watching
      sdetweil @jimb
      @jimb notjing in config.js. we are trying to look at the errors from the module
      so you need to use the browser you are viewing mm with
      three keys on the keyboard.
      ctrl-shift-i
      or npm start dev
      to start mm with the dev window open
      then select the console tab
      • UncleRogerU
        UncleRoger @jimb
        @jimb I will always defer to @sdetweil 's greater knowledge and intelligence but another option is (I hope, anyway, since it’s what I’m using) to use the latitude and longitude of your location. I have the weather module set up to show my wife’s school using the coordinates. (We are known for our microclimates here – her school 2 miles away may have completely different weather from what we have at home.)
        To get the coordinates, I went to maps.google.com, clicked on a location, then copied the resulting URL. It should look like this:
        https://www.google.com/maps/@37.7761918,-122.4222641,16.25z?entry=ttu
        The first number after the @ sign is the latitude; the second is the longitude. So you could put in your config file:
        lat: 37.7761918,
        lon: -122.4222641,
        and it will show the weather for your location (or the San Francisco War Memorial Opera House in that example). This might be handy if you’re not near a city listed in the file.
        UncleRogerU 1 Reply Last reply
        • UncleRogerU
          UncleRoger @UncleRoger
          And now, having actually looked at the file in question, I see it includes latitude and longitude for each entry. Very cool.
            jimb
            Sam, some progress. Operating in “dev” mode I do show status 401 unauthorized . However I am unable to 'place the ‘V 3.0’ in a way/place where it is recognized correctly. I tried placing it on its own “3.0” “API id…” and inside the quote mark "3.0 API ID …
            That gives me a syntax error and blows up the config file.
              sdetweil @jimb
              @jimb all the parms to a module go inside the modules
              config:{} section
              things to the left of : do not need quotes
              things to the right of : do not need quotes if they are true/false, or a number
              otherwise they need quotes. single or double doesn’t.mattet as long as both ends are the same.
              also for each.parm you add, it needs to tell the interpreter if there is more after it. do this by adding a trailing comma
              the apiVersion Parm
                 module:"weather",
                 position mmmmm ,
                  config:{
                          apiVersion:3.0,
                           whatever other parms
                jimb
                Sam, I seem to be deeper in the weeds. After adding the apiVersion:3.0 parameter just below the config identifier in the config file -
                running dev displays the following error-
                Uncaught SyntaxError: Unexpected identifier 'weather identifie ‘weatherProvider’
                and the config file blows up.
                Do I need to add this on some other line?
                  sdetweil @jimb
                  @jimb after the config: for the module
                    jimb
                    Sam, that’s where I put it. I can’t cut and paste here because I’m on a different computer than the Pi.
                      sdetweil @jimb
                      @jimb said in Modifying the Config File:
                      turn on ssh, and install the bitvise or winscp ssh clients
                      then you can do everything from your PC. it’s SOOOOO much better
                        jimb
                        Sam , After adding the commas to the end of the version Iine I ran it with the check on the config file- All OK. I ran MM in Dev mode and now am getting a 401 error when it attempts to load the openweather resource files. So I seem to not be passing the version or ID string>
                          sdetweil @jimb
                          @jimb can you show the config for the weather module…
                            jimb
                            Sam, as a last resort (operating from 2 computers) I attemped to take a picture with my phone and copy that here. No luck. I hear you about working from my PC on the pi, but beyond my experience level. I could try and copy to another place or system?
                              sdetweil @jimb
                              @jimb posting your pic is the third icon from the right above the message editor
                                jimb
                                Co
                                Sam, I get an error when trying to copy the file. Does it need to have a particular extension?
                                  sdetweil @jimb
                                  @jimb copy what file?
                                    jimb
                                    Phone picture of the Config.js file. The picture has a jpg extension.
                                      sdetweil @jimb
                                      @jimb never any trouble, 3rd icon from the right
                                        jimb
                                        Sam, I don’t know why the picture is not copied, I suspect it is over-sized. Dev yield
                                        The first 12 s the following error message:
                                        Failed to load resource: the api.openweatherapp.0…c6acaacfb123ce212:1 server responded with a status of 401 (unauthorized)
                                        (twice)
                                        Could not locate data …TypeError: Cannot read openweathermap.is 43 properties of undefined (reading ‘humidity’)
                                        …then as time increases and it tries to update the screen more specific error messages occur
                                        Thye first 12 characters of my api id are truncated in the first error message text above
                                          sdetweil @jimb
                                          @jimb yes I have had to upload to my PC, then edit the.pic smaller sometimes. technology is so cool sometimes
                                          • F
                                            fulviolcabrera @jimb
                                            @jimb once you download it search for your location. For example, city. It with show your locationID or long or lat. Etc
                                            • 1 / 6
