    Modifying the Config File
    101 Posts 7 Posters 192.5k Views 7 Watching
      sdetweil @jimb
      @jimb ok, sounds like the wifi network is a guest, not connected to the regular ethernet network…
      don’t use putty
      open a cmd.exe window
      ssh user_name@machine_ip
      add one of the tools
      winscp or bitvise ssh clients
      they will give you a filemanager view of the files and an ssh window ,
      per system you connect to…
      bitvise also provides a filemanager view of the pc filesystem , so you can drag/drop files in either direction… (you would only do that for logs to pc, of special bug fix file , to pi)
        jimb
        Sam, success! I have d/l’d the SSH gui program and here is my config.js file. I have deleted my apiKey
        			module: "alert",
        			module: "updatenotification",
        			position: "top_bar"
        			module: "clock",
        			position: "top_left"
        			header: "US Holidays",
        						symbol: "calendar-check",
        						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
        			module: "compliments",
        			position: "lower_third"
        			module: "weather",
        				apiVersion: "3.0",
        				lat: 33.50872,
        				lon: -96.612213,
        				weatherEndpoint: "/onecall",
        				type: "current",
        				locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        				apiKey: "8eca2aec"
        			module: "weather",
        			header: "Weather Forecast",
        				apiVersion: "3.0",
        				lat: 33.50872,
        				lon: -96.612213,
        				type: "forecast",
        				apiKey: "8
        			module: "newsfeed",
        			position: "bottom_bar",
        				feeds: [
        						title: "New York Times",
          sdetweil @jimb
          @jimb missing some at the bottom
          I assume the apikey with a new line inside is a removal edit problem
          always wrap config.js content in code block
          paste into editor
          blank line above and below
          select pasted text
          hit button </>
            jimb
            Sam, here is a copy of the config.js (with the apiKey deleted)
            let config = {
            	address: "localhost",	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
            	language: "en",
            	locale: "en-US",
            	timeFormat: 12,
            	units: "imperial",
            			module: "alert",
            			position: "top_bar"
            			module: "clock",
            			timezone: "America/Chicago",
            			showPeriodUpper: "true",
            			showDate: "true",
            			module: "weather",
            			units: "imperial",
            			windUnits: "imperial",
            			tempUnits: "imperial",
            			appendLocationNameToHeader: "true",
            			colored: "true",
            				apiVersion:"3.0",
            				weatherEndpoint:"/onecall",
            				lat: "33.50872",
            				lon: "-96.612213",
            				type: "current",
            				apiKey: "8acfbcab123ce212",
            			module: "weather",
            			units: "imperial",
            			winUnits: "imperial",
            			appendLocationNaneToHeader: "true",
            			colored: "true",
             				apiVersion:"3.0",
            				lat: "33.50872",
             				lon:"-96.612213",
             				type: "forecast",
            					apiKey: "8eca2acaacfbcab123ce212",
            			module: "newsfeed",
            				feeds: [
            						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
              jimb
              Sam, I tried to do the Ctrl-Shift_i keypress in the browser, but nothing happened. Do I need to do this at a certain point in time or from a certain place. The reason is because I’m still getting the 401-unauthorized messages if I perform the npm start dev process during application start.
              S 3 Replies Last reply
                sdetweil @jimb
                @jimb weird… always works for me.
                I meant to test w my apikeys today.
                will get to it
                  sdetweil @jimb
                  @jimb well, I used your exact weather config, and used my openweather api key , and it worked perfectly
                    sdetweil @jimb
                    @jimb and you’ve got some stuff out of position
                    this is the more correct layout
                                            module: "weather",
                                           config:{
                                               units: "imperial",
                                               colored: "true",
                            //              position: "top_right",
                            //              config: {
                                                    apiVersion:"3.0",
                                                    lat: "29.8155405", //"33.50872",
                                                    lon: "-96.0607878", //"-96.61",
                                                    type: "current",
                                                    //location: "Houston",
                                                    //locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and fi>
                                                    apiKey:""
                      GNU nano 6.2                                                       config/config.js
                                            module: "weather",
                                            position:"top_right",
                                            config:{
                                                units: "imperial",
                                              colored: "true",
                                            //position: "top_right",
                                            //header: "Weather Forecast",
                                            //config: {
                                                    apiVersion:"3.0",
                                                    lat: "33.50872",
                                                    lon:"-96.612213",
                                                    type: "forecast",
                                                            apiKey:"// "
                      jimb
                      Sam, that’s helpful, thanks! The items out of alignment happened when I deleted some of my apiKey. The original is perfectly straight. Since it worked with your Key, a couple of questions.
                      1. Does your Key have 28 digits?
                      2. Can you answer my question concerning the Ctrl-Shift-i keys to display the browser data. Can I stop the MM app and load the browser, or…
                        JimB
                        sdetweil @jimb
                        @jimb my apikey has 33 characters
                        it is the default key in openweather (I have multiple)
                        i just brought up MM, and used my chromebook to bring up the page… and then ctrl-shift-i (letter sounds like eye) all at once, opened the dev window
                        you can do those three keys on any webpage, its a toggle… on/off
                        using normal chrome, you can use the 3 dot menu to get there too
                          jimb
                          Sam, why is it always the simple things :-)
                          I found a simple link that allowed me to test the openweather api link:
                          http://api.openweathermap.org/data/2.5/forecast?id=524901&appid={API Key}
                          I saw the 2.5 and changed it to 3.0 and got a 401 error. I changed it back to 2.5 and it worked. I tried commenting out the 3.0 & /onecall items in config.js and got a “config.js not found” error when running MM. I had used (/*) in the leftmost column as a ‘ignore line’ comment. So, I deleted the 4 lines from config.js and it worked fine except for a teensy error “displaying Howe instead of Houston” in the display. I have no idea where that came from. I wonder why the fourth largest city in the US isn’t listed in the pull-down menu?
                          Now, I’m going to see if I can add additional modules.
                          Thanks for your very patient help!!
                          S BKeyportB 2 Replies Last reply
                            sdetweil @jimb
                            @jimb awesome… making progress!!!
                            • BKeyportB
                              BKeyport Module Developer @jimb
                              @jimb it’s always the simplest solution… ALWAYS.
                                jimb
                                Sam, into the weeds once again :-)
                                I read the readme and comments on your MMM-Config module. I was stumped immediately by your comment: “clone this repo” into the config directory. I’m assuming this this is done via WinSCP remotely into the Pi, but have no clue. Some more Linux…
                                  sdetweil @jimb
                                  @jimb hm… I don’t see those words
                                  git clone is done via command line
                                  ALL commands are done via command line
                                  command line is terminal or ssh terminal window
                                    jimb
                                    Sam, sorry to be so dense. You mention the ‘git clone’ command. Is that how ‘all’ your files are moved into the MagicMirror/Moddules directory? I’ll hunt around for the proper usage. It’s a little confusing using commands from the computer though. Please keep im mind this is all new to me, thanks
                                      sdetweil @jimb
                                      @jimb please read this
                                      https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                                      I didn’t write it
                                        jimb
                                        Sam, I read your comments, thanks! I have git-cloned the files into the modules sub-directory. I modified the config.js to include the lines of code you listed. Somehow I’ve blown up the file. Running in dev mode it says “unexpected (:)” is in line 58. I’ve gone over the code and don’t see the issue. Here is my config file-
                                        * MagicMirror² Config Sample
                                         * By Michael Teeuw https://michaelteeuw.nl
                                         * MIT Licensed.
                                         * see https://docs.magicmirror.builders/configuration/introduction.html
                                         * and https://docs.magicmirror.builders/modules/configuration.html
                                         * You can use environment variables using a `config.js.template` file instead of `config.js`
                                         * which will be converted to `config.js` while starting. For more information
                                         * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                                        let config = {
                                        	port: 8080,
                                        	language: "en",
                                        	locale: "en-US",
                                        	timeFormat: 12,
                                        	units: "imperial",
                                        			module: "alert",
                                        			position: "top_bar"
                                        			module: "MMM-Config",
                                        			position: "top_right",		//the QR code (if requested) will appear here
                                        			config:{
                                        			module: "clock",
                                        			showDate: "true",
                                        			module: "weather",
                                        			units: "imperial",
                                        			colored: "true",
                                        			header: "Current Weather",
                                        				lat: "29.763281",
                                        				lon: "-95.363274",
                                        				type: "current",
                                        				apiKey: "8eca2aec0c123ce212",
                                        			module: "weather",
                                        			units: "imperial",
                                        			colored: "true",
                                        				lat: "29.763281",
                                         				lon:"-95.363274",
                                         				type: "forecast",
                                        				apiKey: "8eca2aecb123ce212",
                                        			module: "newsfeed",
                                        				feeds: [
                                        S 2 Replies Last reply
                                          sdetweil @jimb
                                          @jimb you are still not using the code block , which makes this hard to read…
                                            sdetweil @jimb
                                            @jimb said in Modifying the Config File:
                                              	config:{
                                            you obviously didn’t copy everything
                                            the syntax requires every { to have a matching }
                                            and every [ and matching ]
                                            and every " a matching "
                                            • 5 / 6
