    Modifying the Config File
    101 Posts 7 Posters 170.1k Views 7 Watching
      sdetweil @jimb
      @jimb hm… I don’t see those words
      git clone is done via command line
      ALL commands are done via command line
      command line is terminal or ssh terminal window
        jimb
        Sam, sorry to be so dense. You mention the ‘git clone’ command. Is that how ‘all’ your files are moved into the MagicMirror/Moddules directory? I’ll hunt around for the proper usage. It’s a little confusing using commands from the computer though. Please keep im mind this is all new to me, thanks
          sdetweil @jimb
          @jimb please read this
          https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
          I didn’t write it
            jimb
            Sam, I read your comments, thanks! I have git-cloned the files into the modules sub-directory. I modified the config.js to include the lines of code you listed. Somehow I’ve blown up the file. Running in dev mode it says “unexpected (:)” is in line 58. I’ve gone over the code and don’t see the issue. Here is my config file-
            * MagicMirror² Config Sample
             * By Michael Teeuw https://michaelteeuw.nl
             * MIT Licensed.
             * see https://docs.magicmirror.builders/configuration/introduction.html
             * and https://docs.magicmirror.builders/modules/configuration.html
             * You can use environment variables using a `config.js.template` file instead of `config.js`
             * which will be converted to `config.js` while starting. For more information
             * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
            let config = {
            	address: "localhost",	// Address to listen on, can be:
            	port: 8080,
            	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
            	useHttps: false, 	// Support HTTPS or not, default "false" will use HTTP
            	language: "en",
            	locale: "en-US",
            	timeFormat: 12,
            	units: "imperial",
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "MMM-Config",
            			position: "top_right",		//the QR code (if requested) will appear here
            			config:{
            			module: "clock",
            			timezone: "America/Chicago",
            			showPeriodUpper: "true",
            			showDate: "true",
            			header: "US Holidays",
            						symbol: "calendar-check",
            						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
            			module: "compliments",
            			position: "lower_third"
            			module: "weather",
            			units: "imperial",
            			windUnits: "imperial",
            			tempUnits: "imperial",
            			appendLocationNameToHeader: "true",
            			colored: "true",
            			header: "Current Weather",
            				lat: "29.763281",
            				lon: "-95.363274",
            				type: "current",
            				locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            				apiKey: "8eca2aec0c123ce212",
            			module: "weather",
            			units: "imperial",
            			winUnits: "imperial",
            			colored: "true",
            			header: "Weather Forecast",
            				lat: "29.763281",
             				lon:"-95.363274",
             				type: "forecast",
            				apiKey: "8eca2aecb123ce212",
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            				title: "New York Times",
            					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
            				showSourceTitle: true,
            				showPublishDate: true,
            				broadcastNewsFeeds: true,
            				broadcastNewsUpdates: true
              sdetweil @jimb
              @jimb you are still not using the code block , which makes this hard to read…
                sdetweil @jimb
                @jimb said in Modifying the Config File:
                  	config:{
                you obviously didn’t copy everything
                the syntax requires every { to have a matching }
                and every [ and matching ]
                and every " a matching "
                  jimb
                  Sam, Guess who? I got the Config.js straightened out and MM was starting fine. This was with the MMM-Config text added to the file.
                  The I attempted to follow the steps to add the module code to the module sub-folder.
                  1. Clicked on the green button in your instructions and pasted the link into the terminal prefaced by ‘git clone’. It ‘cloned’ into the modules directory without errors.
                  2. I ran ‘MPM install’ and it executed without errors
                  3. From the terminal I started MM, by executing NPM Start.
                  4. It started loading, but had errors then stopped.
                  5. I was unable to copy text of the loading (w/errors) because the terminal times out.
                    sdetweil @jimb
                    @jimb
                    1. npm install, all lower case
                    2. in the mm folder?, all lower case
                    3. maybe a picture?
                    4. don’t understand this, what terminal window
                    mm will always start, even to put up a dumb message. ctrl-c to stop it
                      jimb
                      Sam, I was able to grab the text from the terminal running on my computer- this was after starting MM
                      /home/rutspi/MagicMirror$ npm start
                      magicmirror@2.25.0 start
                      [11.12.2023 19:08.13.289] [LOG] Starting MagicMirror: v2.25.0
                      [11.12.2023 19:08.13.298] [LOG] Loading config …
                      [11.12.2023 19:08.13.303] [DEBUG] config template file not exists, no envsubst
                      [11.12.2023 19:08.13.308] [LOG] Loading module helpers …
                      [11.12.2023 19:08.13.311] [LOG] No helper found for module: alert.
                      [11.12.2023 19:08.13.338] [LOG] Initializing new module helper …
                      [11.12.2023 19:08.13.339] [LOG] Module helper loaded: updatenotification
                      [11.12.2023 19:08.13.352] [ERROR] (node:1623) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘deep-object-diff’
                      Require stack:
                      • /home/rutspi/MagicMirror/modules/MMM-Config/node_helper.js
                      • /home/rutspi/MagicMirror/js/app.js
                      • /home/rutspi/MagicMirror/js/electron.js
                      • /home/rutspi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                      • at node:internal/modules/cjs/loader:1084:15
                        at Function. (node:electron/js2c/browser_init:2:117576)
                        at Module._resolveFilename (/home/rutspi/MagicMirror/node_modules/module-alias/index.js:49:29)
                        at node:internal/modules/cjs/loader:929:27
                        at Function._load (node:electron/js2c/asar_bundle:2:13327)
                        at Module.require (node:internal/modules/cjs/loader:1150:19)
                        at require (node:internal/modules/cjs/helpers:110:18)
                        at Object. (/home/rutspi/MagicMirror/modules/MMM-Config/node_helper.js:10:14)
                        at Module._compile (node:internal/modules/cjs/loader:1271:14)
                        at Object…js (node:internal/modules/cjs/loader:1326:10)
                        at Module.load (node:internal/modules/cjs/loader:1126:32)
                        at node:internal/modules/cjs/loader:967:12
                        at loadModule (/home/rutspi/MagicMirror/js/app.js:180:19)
                        (Use electron --trace-warnings ... to show where the warning was created)
                        [11.12.2023 19:08.13.353] [ERROR] (node:1623) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                      [1623:1211/190814.008170:ERROR:object_proxy.cc(590)] Failed to call
                      ``` method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                      MESA-LOADER: failed to retrieve device information
                      MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                      failed to load driver: kms_swrast
                      MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                      failed to load swrast driver
                        sdetweil @jimb
                        yeh, you missed a step
                        Clone this repo into ~/MagicMirror/modules directory.
                        cd MMM-Config    <---- this one
                        npm install
                        I’ve updated the install steps
                        1. cd ~/MagicMirror/modules
                        2. git clone https://github.com/sdetweil/MMM-Config
                        3. cd MMM-Config
                        4. npm install
                        • 10
                        • 11
                        • 9 / 11
