    Modifying the Config File
    101 Posts 7 Posters 192.5k Views 7 Watching
      sdetweil @jimb
      @jimb awesome… making progress!!!
      • BKeyportB
        BKeyport Module Developer @jimb
        @jimb it’s always the simplest solution… ALWAYS.
          jimb
          Sam, into the weeds once again :-)
          I read the readme and comments on your MMM-Config module. I was stumped immediately by your comment: “clone this repo” into the config directory. I’m assuming this this is done via WinSCP remotely into the Pi, but have no clue. Some more Linux…
            sdetweil @jimb
            @jimb hm… I don’t see those words
            git clone is done via command line
            ALL commands are done via command line
            command line is terminal or ssh terminal window
              jimb
              Sam, sorry to be so dense. You mention the ‘git clone’ command. Is that how ‘all’ your files are moved into the MagicMirror/Moddules directory? I’ll hunt around for the proper usage. It’s a little confusing using commands from the computer though. Please keep im mind this is all new to me, thanks
                sdetweil @jimb
                @jimb please read this
                https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
                I didn’t write it
                  jimb
                  Sam, I read your comments, thanks! I have git-cloned the files into the modules sub-directory. I modified the config.js to include the lines of code you listed. Somehow I’ve blown up the file. Running in dev mode it says “unexpected (:)” is in line 58. I’ve gone over the code and don’t see the issue. Here is my config file-
                  * MagicMirror² Config Sample
                   * By Michael Teeuw https://michaelteeuw.nl
                   * MIT Licensed.
                   * see https://docs.magicmirror.builders/configuration/introduction.html
                   * and https://docs.magicmirror.builders/modules/configuration.html
                   * You can use environment variables using a `config.js.template` file instead of `config.js`
                   * which will be converted to `config.js` while starting. For more information
                   * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
                  let config = {
                  	address: "localhost",	// Address to listen on, can be:
                  	port: 8080,
                  	basePath: "/",			// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                  	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
                  	useHttps: false, 	// Support HTTPS or not, default "false" will use HTTP
                  	language: "en",
                  	locale: "en-US",
                  	timeFormat: 12,
                  	units: "imperial",
                  			module: "alert",
                  			module: "updatenotification",
                  			position: "top_bar"
                  			module: "MMM-Config",
                  			position: "top_right",		//the QR code (if requested) will appear here
                  			config:{
                  			module: "clock",
                  			timezone: "America/Chicago",
                  			showPeriodUpper: "true",
                  			showDate: "true",
                  			header: "US Holidays",
                  						symbol: "calendar-check",
                  						url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
                  			module: "compliments",
                  			position: "lower_third"
                  			module: "weather",
                  			units: "imperial",
                  			windUnits: "imperial",
                  			tempUnits: "imperial",
                  			appendLocationNameToHeader: "true",
                  			colored: "true",
                  			header: "Current Weather",
                  				lat: "29.763281",
                  				lon: "-95.363274",
                  				type: "current",
                  				locationID: "4699066", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                  				apiKey: "8eca2aec0c123ce212",
                  			module: "weather",
                  			units: "imperial",
                  			winUnits: "imperial",
                  			colored: "true",
                  			header: "Weather Forecast",
                  				lat: "29.763281",
                   				lon:"-95.363274",
                   				type: "forecast",
                  				apiKey: "8eca2aecb123ce212",
                  			module: "newsfeed",
                  			position: "bottom_bar",
                  				feeds: [
                  				title: "New York Times",
                  					url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                  				showSourceTitle: true,
                  				showPublishDate: true,
                  				broadcastNewsFeeds: true,
                  				broadcastNewsUpdates: true
                  S 2 Replies Last reply
                    sdetweil @jimb
                    @jimb you are still not using the code block , which makes this hard to read…
                      sdetweil @jimb
                      @jimb said in Modifying the Config File:
                        	config:{
                      you obviously didn’t copy everything
                      the syntax requires every { to have a matching }
                      and every [ and matching ]
                      and every " a matching "
                        jimb
                        Sam, Guess who? I got the Config.js straightened out and MM was starting fine. This was with the MMM-Config text added to the file.
                        The I attempted to follow the steps to add the module code to the module sub-folder.
                        1. Clicked on the green button in your instructions and pasted the link into the terminal prefaced by ‘git clone’. It ‘cloned’ into the modules directory without errors.
                        2. I ran ‘MPM install’ and it executed without errors
                        3. From the terminal I started MM, by executing NPM Start.
                        4. It started loading, but had errors then stopped.
                        5. I was unable to copy text of the loading (w/errors) because the terminal times out.
                          sdetweil @jimb
                          @jimb
                          1. npm install, all lower case
                          2. in the mm folder?, all lower case
                          3. maybe a picture?
                          4. don’t understand this, what terminal window
                          mm will always start, even to put up a dumb message. ctrl-c to stop it
                            jimb
                            Sam, I was able to grab the text from the terminal running on my computer- this was after starting MM
                            /home/rutspi/MagicMirror$ npm start
                            magicmirror@2.25.0 start
                            [11.12.2023 19:08.13.289] [LOG] Starting MagicMirror: v2.25.0
                            [11.12.2023 19:08.13.298] [LOG] Loading config …
                            [11.12.2023 19:08.13.303] [DEBUG] config template file not exists, no envsubst
                            [11.12.2023 19:08.13.308] [LOG] Loading module helpers …
                            [11.12.2023 19:08.13.311] [LOG] No helper found for module: alert.
                            [11.12.2023 19:08.13.338] [LOG] Initializing new module helper …
                            [11.12.2023 19:08.13.339] [LOG] Module helper loaded: updatenotification
                            [11.12.2023 19:08.13.352] [ERROR] (node:1623) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘deep-object-diff’
                            Require stack:
                            • /home/rutspi/MagicMirror/modules/MMM-Config/node_helper.js
                            • /home/rutspi/MagicMirror/js/app.js
                            • /home/rutspi/MagicMirror/js/electron.js
                            • /home/rutspi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
                            • at node:internal/modules/cjs/loader:1084:15
                              at Function. (node:electron/js2c/browser_init:2:117576)
                              at Module._resolveFilename (/home/rutspi/MagicMirror/node_modules/module-alias/index.js:49:29)
                              at node:internal/modules/cjs/loader:929:27
                              at Function._load (node:electron/js2c/asar_bundle:2:13327)
                              at Module.require (node:internal/modules/cjs/loader:1150:19)
                              at require (node:internal/modules/cjs/helpers:110:18)
                              at Object. (/home/rutspi/MagicMirror/modules/MMM-Config/node_helper.js:10:14)
                              at Module._compile (node:internal/modules/cjs/loader:1271:14)
                              at Object…js (node:internal/modules/cjs/loader:1326:10)
                              at Module.load (node:internal/modules/cjs/loader:1126:32)
                              at node:internal/modules/cjs/loader:967:12
                              at loadModule (/home/rutspi/MagicMirror/js/app.js:180:19)
                              (Use electron --trace-warnings ... to show where the warning was created)
                              [11.12.2023 19:08.13.353] [ERROR] (node:1623) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
                            [1623:1211/190814.008170:ERROR:object_proxy.cc(590)] Failed to call
                            ``` method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
                            MESA-LOADER: failed to retrieve device information
                            MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                            failed to load driver: kms_swrast
                            MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/aarch64-linux-gnu/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                            failed to load swrast driver
                              sdetweil @jimb
                              yeh, you missed a step
                              Clone this repo into ~/MagicMirror/modules directory.
                              cd MMM-Config    <---- this one
                              npm install
                              I’ve updated the install steps
                              1. cd ~/MagicMirror/modules
                              2. git clone https://github.com/sdetweil/MMM-Config
                              3. cd MMM-Config
                              4. npm install
                                jimb
                                Sam, all is working OK again. Thanks! FYI, my capitalizations were for emphasis only, not copied or used.
                                Now, real dumb question "How is “MMM-Config” invoked?
                                  sdetweil @jimb
                                  from the doc
                                  showQR OPTIONAL false Show a QR code on the MM screen to allow quick access to the configuration form
                                  Otherwise, use a browser to open
                                  http://MM_IP_Address:MM_Port/modules/MMM-Config/review
                                    jimb
                                    Sam, you can stick a fork in this one as I don’t need any more help at this point. Thanks for all the assistance!
                                      sdetweil @jimb
                                      @jimb is mmm-config working or just moved on?
                                        jimb
                                        Sam, moving on as I want to build the actual frame for the Magic Mirror and not spend this amount of time on the code which is difficult to understand. Not your fault, but mine. :-)
                                          sdetweil @jimb
                                          @jimb no problem. come back when you’re ready.
                                          • 5 / 6
