    MMM-Pir-Sensor - Display remains black
    6 Posts 3 Posters 1.3k Views 3 Watching
    • K Offline
      Kastore
      Hello everyone,
      I just repaired my connection of the PIR Sensor and the Pi. Doing so i thought this should be it and the sensor work again.
      However: For some reason the Module is not working as intended.
      Intention:
      Monitor being on for 20s when movement has been registered
      Current behavior:
      Either being ONLY when movement is detected or CONSTANTLY on
      Status Quo:
      The old code i have used and worked is as follows:
      	module: 'MMM-PIR-Sensor',
      		     sensorPin: 14,
      		     powerSaving: true,
      	             OffDelay: 20000,
      Doing so will have the monitor turned off instantly unless i move.
      		     sensorPin: 14,
      		     powerSaving: true,
      	             powerSavingDelay: 15,
      this code will have the MM on “forever” (well i havent been standing infront of the mirror for minutes… so i cant tell if forever…) at least not after 15s
      I am a bit at a loss as to what has changed… i have not updated any modules or the MM… reconecting the pin 17 to the sensor was all I did…
      Any help is highly appreciated
      • K Offline
        Kastore @sdetweil
        Thanks for the links. I ran the 2nd script and it came back with constant “motion detected” and “motion stopped” while there was I wasnt moving.
        Which is a bit strange as the only thing i did was reconnect the existing cable to pin 17… (the soldering came off)
          sdetweil @Kastore
          @Kastore I think the sensor is having trouble.
          I would test it outside MagicMirror to insure it’s working correctly.
          there are a few python scripts you can use.
          a Google search brings up two as the first choices
          • K Offline
            Kastore @sdetweil
              sdetweil @Kastore
              @Kastore at least you know its not the MagicMirror module…
              • K Offline
                Kastore @sdetweil
                Just tried it with another pin (pin 20) and the results are completly different. So i am not sure what to make out of the infos i get from the script.
                Gosh this is such a bummer that the sensor for some reason decided to quit…
                Guess i will have to build in a switch or something to turn on the mirror for X minutes and use the existing script for it
                  diverdennis @Kastore
                  @Kastore
                  One question: du u use a pull-down or pull-up resistor?
                  If not this might be ur problem, the gpio will detect random activation, it really needs a pull-up or pull-down resistor to work properly.
                  Hope it helps a bit.
