Solved Magic Mirror doesn't work after a boot
"start":"./run-start.sh $1", "start":"./run-start.sh $1", "server": "node ./serveronly", "install-mm": "npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev", "install-mm:dev": "npm install --no-audit --no-fund --no-update-notifier", "install-vendor": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error --no-audit --no-fund --no-update-notifier", "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error --no-audit --no-fund --no-update-notifier", "postinstall": "npm run install-vendor && npm run install-fonts && echo \"MagicMirror² installation finished successfully! \n\"", "test": "NODE_ENV=test jest -i --forceExit", "test:coverage": "NODE_ENV=test jest --coverage -i --verbose false --forceExit", "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit", "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit", "test:unit": "NODE_ENV=test jest --selectProjects unit", "test:prettier": "prettier . --check", "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi> "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json", "test:calendar": "node ./modules/default/calendar/debug.js", "config:check": "node js/check_config.js", "lint:prettier": "prettier . --write", "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --confi> "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix", "lint:staged": "lint-staged", "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed."
delete one of them and replace the other with
also do uname -a
@sdetweil said in Magic Mirror doesn't work after a boot:
“start”: “DISPLAY=”${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js",
{ "name": "magicmirror", "version": "2.25.0", "description": "The open source modular smart mirror platform.", "main": "js/electron.js", "scripts": { "start": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js", }, "repository": { "type": "git", "url": "git+https://github.com/MichMich/MagicMirror.git"
Linux raspberrypi 6.1.21-v7+ #1642 SMP Mon Apr 3 17:20:52 BST 2023 armv7l GNU/Linux
@eightbit you didn’t need to delete all the rest of the scripts
@eightbit ok, armv7 and memory >512… hm
can u send me the ~/install.log
I want to see why it picked the run-statrt approach…same userid at gmail
@eightbit thanks for the log… says electron did not install. hmm…
thus trying to use chromium…
does it start now ? pm2 or npm start?
@sdetweil ```
secretsanta@raspberrypi:~/MagicMirror $ npm startmagicmirror@2.25.0 start
DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.jssh: 1: ./node_modules/.bin/electron: not found
@eightbit i couldn’t approve the message, system though it was spam
those are noise we can’t hide…
try npm start again
