    Multiple instances of ImagesPhotos module
    20 Posts 2 Posters 16.8k Views 2 Watching
    • N
      Nneuland @Nneuland
      @Nneuland
      Hi Sam. Seeing that my duplicate module is “MMM-ImagesPhotos2”
      Should I be changing all moments within the js files “MMM-ImagesPhotos/photos” or “MMM-ImagesPhotos” to “MMM-ImagesPhotos2/photos” or “MMM-ImagesPhotos2” ?
        sdetweil @Nneuland
        @Nneuland I would do that, yes
        doesn’t matter, as long as both url strings are different. I would add a 2 on the end of both, in all the places
        N 1 Reply Last reply
        • N
          Nneuland @sdetweil
          Seemed simple enough, but leave it to me. No visuals for this duplicated module.
          css folder renamed- but empty
          node-helper.js and MMM-ImagesPhotos.js folders renamed as well as every instance of ImagesPhotos(2) renamed
          Where can I look to troubleshoot?
          S 2 Replies Last reply
            sdetweil @Nneuland
            @Nneuland I fixed the code so it can do multiple instances…
            make sure to set the path: variable to the subset of pics in the uploads folder
            if path is not set then uploads is the folder
            oh, and I added recursive folder support a few weeks ago
            the image drawing may be mangled I had two side by side… top_left/right, filled the screen
            my config
                    module: "MMM-ImagesPhotos",
                    disabled: false,
                    position:"top_left",
                      backgroundColor: "grey",
                      fill: true,
                      blur: 10,
                      sequential: true,
                      path:"foo",   // uploads/foo
             //         debug:true
                    disabled: false,
                    position:"top_right",
                      backgroundColor: "blue",
                      fill: true,
                      blur: 10,
                      sequential: true,
                      path:"test1",   // uploads/test1
            //          debug:true
              sdetweil @Nneuland
              @Nneuland you didn’t do npm install in the module folder
              • N
                Nneuland @sdetweil
                I don’t know what I did, but I lost my auto restart. Seem to have MagicMirror AND mm running (twice) somehow. My vnc isnt showing what the mirror is showing, MMM-RemoteControl on my phone lost my second instance of ImagesPhotos (which I couldnt get working anyway)…
                I think I need a break for the night and possibly a fresh install in the near future, I don’t know how you do this
                  sdetweil @Nneuland
                  @Nneuland
                  MagicMirror crashed cause this module was missing a library . that’s why you don’t see anything and can’t connect
                  do this
                  cd ~/MagicMirror/modules/MMM-InagesPhotos
                  npm install
                  cd ~
                  pm2 stop all
                  npm start
                    sdetweil @Nneuland
                    @Nneuland you ARE using my fork , right?
                    https://github.com/sdetweil/MMM-ImagesPhotos
                    • N
                      Nneuland @sdetweil
                      Thank you! I hit a large wall last night and needed to stop.
                      I’m back up and running, but still need to reinitiate my auto restart and get back to the task at hand of duplicating two separate ImagesPhotos modules.
                      My attempt at duplicating an additional MMM-ImagesPhotos module has still fallen short. I enjoy using the MMM-RemoteControl to customize the mirror real time. Which included the idea of running two identical MMM-ImagesPhotos modules (different names) to be in the exact same space on the mirror, but only one at a time. One url set showing family photos and the other showing my son’s favorite cartoons.
                      So having two different running modules (MMM-ImagesPhotos, and MMM-ImagesPhotos2, on MMM-RemoteControl is ideal for my purposes.
                      I’ll need some fresh eyes on it tonight. I figured since they were referencing different uploads folders from two different module folders, this wouldn’t be a problem.
                      Unfortunately adding the path to my config file did not allow for the module to run.
                      I’ll need to keep at it
                        sdetweil @Nneuland
                        @Nneuland remove the old separates and copied code, only confuses things.
                        use my new forked code only
                        the module looks for images in the uploads folder inside the module folder
                        you can ADD to that with path (not my design)
                        so some pics are in uploads/foo and some are in uploads/bar
                        each module config needs that path:“foo”, or path:“bar”
                        else it looks in uploads and with my recursive support will get everything .
                        the new fork code adds the module identifier to the url paths to make things unique.
                        took a bit to make all that work tho. mostly in the node helper, as it has to service all the instances at once
                        N 2 Replies Last reply
                        • N
                          Nneuland @sdetweil
                          Thank you. I’m hoping to look at this tonight
                          • N
                            Nneuland @sdetweil
                            Finally got it up and running. Thank you for your patience.
                            The only thing, because I’m running two instances, the positioning and photo size is quite off. MaxHeight and MaxWidth in config doesn’t seem to be influencing any and the custom css modifications also are not working as expected. Looking to keep the same posting for both url sets
                              sdetweil @Nneuland
                              @Nneuland yes, I said maybe the sizing was wrong. I’ll look at it.in the morning.
                              I added some special code to fix the sizes so that they kept the original aspect ratio, but never tried in non full screen. I’ll see if I can turn that off easily.
                              N S 2 Replies Last reply
                              • N
                                Nneuland @sdetweil
                                you did. Maybe I can simply rescale my images, but if you have a work around that would be great. Just curious if it were my ignorance, or something else.
                                  sdetweil @Nneuland
                                  @Nneuland all my fault
                                    @Nneuland ok, update
                                    git pull in the module folder
                                    make sure to set the maxHeight and width in the config
                                                    disabled: false,
                                                      fill: true,
                                                      blur: 10,
                                                      sequential: true,
                                                      path:"foo",
                                                      debug:true,
                                                      maxWidth:"50%",
                                                      maxHeight:"50%"
                                                    order: "*",
                                                    bad_position: "fullscreen"
                                                    disabled: false,
                                                      fill: true,
                                                      blur: 10,
                                                      sequential: true,
                                                      path:"test1",
                                                      debug:true,
                                                      maxWidth:"500px",
                                                      maxHeight:"500px"
                                                    order: "*",
                                    note 50% vs 500px produces different sizes
                                    there are two different image css classes… one when full screen, one not
                                    • N
                                      Nneuland @sdetweil
                                      This is amazing! Thank you for all of your hard work. Works perfectly
