    Multiple instances of ImagesPhotos module
    20 Posts 2 Posters 14.4k Views 2 Watching
    • N Offline
      Nneuland @sdetweil
      Thanks Sam. I’ll give that a go later tonight/. thank you for your suggestion
      N S 2 Replies Last reply Reply Quote 0
      • N Offline
        Nneuland @Nneuland
        @Nneuland
        Hi Sam. Seeing that my duplicate module is “MMM-ImagesPhotos2”
        Should I be changing all moments within the js files “MMM-ImagesPhotos/photos” or “MMM-ImagesPhotos” to “MMM-ImagesPhotos2/photos” or “MMM-ImagesPhotos2” ?
          sdetweil @Nneuland
          @Nneuland I would do that, yes
          doesn’t matter, as long as both url strings are different. I would add a 2 on the end of both, in all the places
          • N Offline
            Nneuland @sdetweil
            Seemed simple enough, but leave it to me. No visuals for this duplicated module.
            css folder renamed- but empty
            node-helper.js and MMM-ImagesPhotos.js folders renamed as well as every instance of ImagesPhotos(2) renamed
            Where can I look to troubleshoot?
              sdetweil @Nneuland
              @Nneuland I fixed the code so it can do multiple instances…
              make sure to set the path: variable to the subset of pics in the uploads folder
              if path is not set then uploads is the folder
              oh, and I added recursive folder support a few weeks ago
              the image drawing may be mangled I had two side by side… top_left/right, filled the screen
              my config
                      module: "MMM-ImagesPhotos",
                      disabled: false,
                      position:"top_left",
                        backgroundColor: "grey",
                        fill: true,
                        blur: 10,
                        sequential: true,
                        path:"foo",   // uploads/foo
               //         debug:true
                      disabled: false,
                      position:"top_right",
                        backgroundColor: "blue",
                        fill: true,
                        blur: 10,
                        sequential: true,
                        path:"test1",   // uploads/test1
              //          debug:true
                sdetweil @Nneuland
                @Nneuland you didn’t do npm install in the module folder
                • N Offline
                  Nneuland @sdetweil
                  I don’t know what I did, but I lost my auto restart. Seem to have MagicMirror AND mm running (twice) somehow. My vnc isnt showing what the mirror is showing, MMM-RemoteControl on my phone lost my second instance of ImagesPhotos (which I couldnt get working anyway)…
                  I think I need a break for the night and possibly a fresh install in the near future, I don’t know how you do this
                    sdetweil @Nneuland
                    @Nneuland
                    MagicMirror crashed cause this module was missing a library . that’s why you don’t see anything and can’t connect
                    do this
                    cd ~/MagicMirror/modules/MMM-InagesPhotos
                    npm install
                    cd ~
                    pm2 stop all
                    npm start
                      sdetweil @Nneuland
                      @Nneuland you ARE using my fork , right?
                      https://github.com/sdetweil/MMM-ImagesPhotos
                      • N Offline
                        Nneuland @sdetweil
                        Thank you! I hit a large wall last night and needed to stop.
                        I’m back up and running, but still need to reinitiate my auto restart and get back to the task at hand of duplicating two separate ImagesPhotos modules.
                        My attempt at duplicating an additional MMM-ImagesPhotos module has still fallen short. I enjoy using the MMM-RemoteControl to customize the mirror real time. Which included the idea of running two identical MMM-ImagesPhotos modules (different names) to be in the exact same space on the mirror, but only one at a time. One url set showing family photos and the other showing my son’s favorite cartoons.
                        So having two different running modules (MMM-ImagesPhotos, and MMM-ImagesPhotos2, on MMM-RemoteControl is ideal for my purposes.
                        I’ll need some fresh eyes on it tonight. I figured since they were referencing different uploads folders from two different module folders, this wouldn’t be a problem.
                        Unfortunately adding the path to my config file did not allow for the module to run.
                        I’ll need to keep at it
