    Multiple instances of ImagesPhotos module
    20 Posts 2 Posters 14.2k Views 2 Watching
    • N Offline
      Nneuland
      HI there,
      I’ve successfully duplicated MMM-ImagesPhotos to run two different photo sets, however I’m running into a silly issue.
      Despite the “new” module MMM-ImagesPhotos2 working, it is referencing the upload images from the original MMM-ImagesPhotos upload folder. Even though the images are in appropriate locations.
      Is this a caching issue? Any help would be greatly appreciated
        @Nneuland ok, update
        git pull in the module folder
        make sure to set the maxHeight and width in the config
                        module: "MMM-ImagesPhotos",
                        disabled: false,
                        position:"top_left",
                          backgroundColor: "grey",
                          fill: true,
                          blur: 10,
                          sequential: true,
                          path:"foo",
                          debug:true,
                          maxWidth:"50%",
                          maxHeight:"50%"
                        order: "*",
                        bad_position: "fullscreen"
                        disabled: false,
                        position:"top_right",
                          backgroundColor: "blue",
                          fill: true,
                          blur: 10,
                          sequential: true,
                          path:"test1",
                          debug:true,
                          maxWidth:"500px",
                          maxHeight:"500px"
                        order: "*",
        note 50% vs 500px produces different sizes
        there are two different image css classes… one when full screen, one not
          sdetweil @Nneuland
          @Nneuland no, not a caching… the way the module works it creates a url link back into the node_helper to access the images
          in the node_helper.js
          extraRoutes: function() {
          		var self = this;
                           // this url gets the images
          		this.expressApp.get("/MMM-ImagesPhotos/photos", function(req, res) {
          			self.getPhotosImages(req, res);
                            // this url processes THIS image
          		this.expressApp.use("/MMM-ImagesPhotos/photo",   //<-----
           express.static(self.path_images));
          // return photos-images by response in JSON format.
          	getPhotosImages: function(req, res) {
          		directoryImages = this.path_images;
          		let imgs=this.getFiles(directoryImages)
          		var imagesPhotos = this.getImages(imgs).map(function (img) {
          			if(this.config.debug){
          			  	console.log("have image="+img);
          			return {url: "/MMM-ImagesPhotos/photo/" + img}; //<----- url for an image
          		res.send(imagesPhotos);
          and then in the
          MMM-ImagesPhotos.js
          getPhotos: function() {
          		var urlApHelper = "/MMM-ImagesPhotos/photos";    /// path got get images
          		var retry = true;
          		var photosRequest = new XMLHttpRequest();
          		photosRequest.open("GET", urlApHelper, true);  // used here to get images list
          you can change the values, just in one instance
          • N Offline
            Nneuland @sdetweil
            Thanks Sam. I’ll give that a go later tonight/. thank you for your suggestion
            N S 2 Replies Last reply Reply Quote 0
            • N Offline
              Nneuland @Nneuland
              @Nneuland
              Hi Sam. Seeing that my duplicate module is “MMM-ImagesPhotos2”
              Should I be changing all moments within the js files “MMM-ImagesPhotos/photos” or “MMM-ImagesPhotos” to “MMM-ImagesPhotos2/photos” or “MMM-ImagesPhotos2” ?
                sdetweil @Nneuland
                @Nneuland I would do that, yes
                doesn’t matter, as long as both url strings are different. I would add a 2 on the end of both, in all the places
                • N Offline
                  Nneuland @sdetweil
                  Seemed simple enough, but leave it to me. No visuals for this duplicated module.
                  css folder renamed- but empty
                  node-helper.js and MMM-ImagesPhotos.js folders renamed as well as every instance of ImagesPhotos(2) renamed
                  Where can I look to troubleshoot?
                    sdetweil @Nneuland
                    @Nneuland I fixed the code so it can do multiple instances…
                    make sure to set the path: variable to the subset of pics in the uploads folder
                    if path is not set then uploads is the folder
                    oh, and I added recursive folder support a few weeks ago
                    the image drawing may be mangled I had two side by side… top_left/right, filled the screen
                    my config
                            disabled: false,
                              fill: true,
                              blur: 10,
                              sequential: true,
                              path:"foo",   // uploads/foo
                     //         debug:true
                            disabled: false,
                              fill: true,
                              blur: 10,
                              sequential: true,
                              path:"test1",   // uploads/test1
                    //          debug:true
                      sdetweil @Nneuland
                      @Nneuland you didn’t do npm install in the module folder
                      • N Offline
                        Nneuland @sdetweil
                        I don’t know what I did, but I lost my auto restart. Seem to have MagicMirror AND mm running (twice) somehow. My vnc isnt showing what the mirror is showing, MMM-RemoteControl on my phone lost my second instance of ImagesPhotos (which I couldnt get working anyway)…
                        I think I need a break for the night and possibly a fresh install in the near future, I don’t know how you do this
                          sdetweil @Nneuland
                          @Nneuland
                          MagicMirror crashed cause this module was missing a library . that’s why you don’t see anything and can’t connect
                          do this
                          cd ~/MagicMirror/modules/MMM-InagesPhotos
                          npm install
                          cd ~
                          pm2 stop all
                          npm start
