    Config for a simple clean montly calendar
    25 Posts 8 Posters 28.2k Views 9 Watching
      Plainbroke 0 @mlcampbe
      @mlcampbe
      I know this is an old post, but I need some help setting up a full screen calendar.
      Can you send me your config.Js and custom.css or however you made that calendar you show above. I have been waiting for someone to come up with that exact calendar…
      Did you use the default calendar or something else…? I could combine my 3 different calendars into one… Saving realestate.
      Jeff Burdick aka Plainbroke
      M 1 Reply Last reply
        mlcampbe @Plainbroke 0
        @Plainbroke-0
        Take a look at https://forum.magicmirror.builders/topic/11001/config-for-a-simple-clean-montly-calendar/8 as it has the css and necessary config needed.
        • Piranha1605P
          Piranha1605
          Here is a sample for you.
           * module.width_height
           .module.MMM-CalendarExt2 {
            height: 600px;
           * module.color_border_shadow
            background-color:#2a313b;
            border-radius:8px;
            padding:8px;
            box-shadow: 0 4px 8px 0 rgba(0, 0, 0, 1), 0 8px 20px 0 rgba(0, 0, 0, 0.19);
           * MMM-CalendarExt2.
          .CX2 .slot .event{
          	background: #1f242c;
          .CX2 .agenda .eventSub {
          	display:none;
          .CX2 .slot .slotHeader{
            border: 1px solid black;
            color: white;
          .CX2 .today .slotHeader * {
          	color: white;
           .CX2 .event.fullday {
            border-radius:0px;
          .CX2 .event[data-calendar-name="Google"] {
            color: white;
            min-height:80px;
          .CX2 .event[data-calendar-name="Karate"] {
            color: white;
            min-height:80px;
          .CX2 .event[data-calendar-name="Abfall"] {
            color: white;
            min-height:80px;
          .CX2 .event[data-calendar-name="Arbeit"] {
            color: white;
            min-height:80px;
          .CX2 .event[data-calendar-name="Feiertage"] {
            color: white;
            min-height:80px;
           * Iconsize.
          .CX2 .event .eventIcon {
            min-width: calc(var(--font-size) * 2,5);
            min-height: calc(var(--font-size) * 2,5);
            margin-right:5px;
            float:left;
          .CX2 .period .eventIcon {
            margin-right:5px;
            float:left;
          .CX2 .weekSlot .eventIcon {
            min-width: var(--font-size);
            min-height: var(--font-size);
            margin-right:3px;
            display:block;
            padding-bottom:3px;
          T 1 Reply Last reply
          • Piranha1605P
            Piranha1605
            @Piranha1605 said in Config for a simple clean montly calendar:
            .CX2 .event[data-calendar-name=“Google”]
            Enter the name of your calendar here
              Clubjack @mlcampbe
              @mlcampbe
              Hey. Last days i created my calendar with your helpfull custom.css.
              Do You know the Code for changing the height of the Event-Bar?
              I need it a little bit smaller.
              Thank You.
                mlcampbe @Clubjack
                @Clubjack
                I am not quite sure what you mean by the Event-Bar. Is that the height of a row or title size or what exactly are you talking about? I no longer use the calendar as my needs were only for about 1 years time but might be able to help if you can tell me exactly what part you need to modify.
                C 1 Reply Last reply
                  Clubjack @mlcampbe
                  @mlcampbe
                  Thank You. But i found it myself. 👍🏼
                  But i have another queetion.
                  I use the calendar in week-View.
                  The Today-Header has an other Color. Thats good.
                  But is it possible to change the background-Color of the Today Slot too?
                  So it is easier to see the actual day.
                    mlcampbe
                    I believe one of these should probably work:
                    .CX2 .today .slotHeader {
                    background: rgba(64,64,64,0.8);
                    color: #000;
                    .CX2 .today .slotHeader .slotTitle {
                    color: #FFF;
                    .CX2 .today .slotContent {
                    background: #eeeeee69;
                    #border: 1px solid white;
                      Clubjack @mlcampbe
                      @mlcampbe
                      Thanks a lot.
                      The last Code was the right. 👍🏼👍🏼👍🏼👍🏼
                      • T
                        TJSartain @Piranha1605
                        @Piranha1605 Very nice. What does the config look like?
                        • H
                          HansDampf
                          is there any suggestion fpr CalendarExt3?
                          https://github.com/MMRIZE/MMM-CalendarExt3
