    Config for a simple clean montly calendar
    25 Posts 8 Posters 27.6k Views 9 Watching
      cyberphox @mlcampbe
      @mlcampbe that’s exactly the info i was looking for! thanks!
        sdetweil @Clubjack
        @Clubjack style sheets cascade. newer can replace/override prior classes and styles…
        so MM does this
        main.css (1st)
        modules adding their own style sheets (thru the getStyles() method response if used)
        custom.css (last)
        so, anything that happened BEFORE custom.css is loaded can be changed with entries in custom.css
        custom.css is empty by default
          Plainbroke 0 @mlcampbe
          @mlcampbe
          I know this is an old post, but I need some help setting up a full screen calendar.
          Can you send me your config.Js and custom.css or however you made that calendar you show above. I have been waiting for someone to come up with that exact calendar…
          Did you use the default calendar or something else…? I could combine my 3 different calendars into one… Saving realestate.
          Jeff Burdick aka Plainbroke
            mlcampbe @Plainbroke 0
            @Plainbroke-0
            Take a look at https://forum.magicmirror.builders/topic/11001/config-for-a-simple-clean-montly-calendar/8 as it has the css and necessary config needed.
            • Piranha1605P Offline
              Piranha1605
              Here is a sample for you.
               * module.width_height
               .module.MMM-CalendarExt2 {
                height: 600px;
               * module.color_border_shadow
                background-color:#2a313b;
                border-radius:8px;
                padding:8px;
                box-shadow: 0 4px 8px 0 rgba(0, 0, 0, 1), 0 8px 20px 0 rgba(0, 0, 0, 0.19);
               * MMM-CalendarExt2.
              .CX2 .slot .event{
              	background: #1f242c;
              .CX2 .agenda .eventSub {
              	display:none;
              .CX2 .slot .slotHeader{
                border: 1px solid black;
                color: white;
              .CX2 .today .slotHeader * {
              	color: white;
               .CX2 .event.fullday {
                border-radius:0px;
              .CX2 .event[data-calendar-name="Google"] {
                color: white;
                min-height:80px;
              .CX2 .event[data-calendar-name="Karate"] {
                color: white;
                min-height:80px;
              .CX2 .event[data-calendar-name="Abfall"] {
                color: white;
                min-height:80px;
              .CX2 .event[data-calendar-name="Arbeit"] {
                color: white;
                min-height:80px;
              .CX2 .event[data-calendar-name="Feiertage"] {
                color: white;
                min-height:80px;
               * Iconsize.
              .CX2 .event .eventIcon {
                min-width: calc(var(--font-size) * 2,5);
                min-height: calc(var(--font-size) * 2,5);
                margin-right:5px;
                float:left;
              .CX2 .period .eventIcon {
                margin-right:5px;
                float:left;
              .CX2 .weekSlot .eventIcon {
                min-width: var(--font-size);
                min-height: var(--font-size);
                margin-right:3px;
                display:block;
                padding-bottom:3px;
                Piranha1605
                @Piranha1605 said in Config for a simple clean montly calendar:
                .CX2 .event[data-calendar-name=“Google”]
                Enter the name of your calendar here
                  Clubjack @mlcampbe
                  @mlcampbe
                  Hey. Last days i created my calendar with your helpfull custom.css.
                  Do You know the Code for changing the height of the Event-Bar?
                  I need it a little bit smaller.
                  Thank You.
                    mlcampbe @Clubjack
                    @Clubjack
                    I am not quite sure what you mean by the Event-Bar. Is that the height of a row or title size or what exactly are you talking about? I no longer use the calendar as my needs were only for about 1 years time but might be able to help if you can tell me exactly what part you need to modify.
                      Clubjack @mlcampbe
                      @mlcampbe
                      Thank You. But i found it myself. 👍🏼
                      But i have another queetion.
                      I use the calendar in week-View.
                      The Today-Header has an other Color. Thats good.
                      But is it possible to change the background-Color of the Today Slot too?
                      So it is easier to see the actual day.
                        mlcampbe
                        I believe one of these should probably work:
                        .CX2 .today .slotHeader {
                        background: rgba(64,64,64,0.8);
                        color: #000;
                        .CX2 .today .slotHeader .slotTitle {
                        color: #FFF;
                        .CX2 .today .slotContent {
                        background: #eeeeee69;
                        #border: 1px solid white;
                          Clubjack @mlcampbe
                          @mlcampbe
                          Thanks a lot.
                          The last Code was the right. 👍🏼👍🏼👍🏼👍🏼
                          • T Offline
                            TJSartain @Piranha1605
                            @Piranha1605 Very nice. What does the config look like?
                            • H Offline
                              HansDampf
                              is there any suggestion fpr CalendarExt3?
                              https://github.com/MMRIZE/MMM-CalendarExt3
