    Simple(?) module to send a notification every x minutes?
    35 Posts 3 Posters 22.4k Views 3 Watching
    • UncleRogerU Offline
      UncleRoger @sdetweil
      I switched to your fork and while it’s better, it’s still sending a notification every several seconds.
      Here’s my config:
      			module: "MMM-Pages",
                              classes: "fixed",
      			config:	{
      				modules:[	[ "page1" ],
      							[ "page2" ],
      				fixed: [ "fixed" ],
      				rotationTime:	10000,
      				animationTime:	10000,
      and
                  module: 'MMM-SendNotification',
                  classes: "fixed",
                      interval: 3600000, // 1 minute interval
                      notification: 'PAGE_CHANGED',
                      payload: 1,
      (I upped the interval to see if that would do anything. It didn’t.)
      I’ve commented out all the other modules except the clock, MMM-BackgroundSlideshow, and MMM-ViewNotifications.
        sdetweil @UncleRoger
        @UncleRoger ok, git pull the latest
        and restart
        I now check to see if the handler was turned off on resume, so don’t start another
        lmk
        UncleRogerU 1 Reply Last reply Reply Quote 0
          That worked! Thank you so much!
          Now I am just being cheeky but if you are bored and want to add a feature, it would be great to be able to reset the timer based on a notification. (In my case, if MMM-Keypress sends a PAGE_INCREMENT notification to change pages, restart the timer from that point.)
          Anyway, I am getting really close to having everything the way I want it and am hoping that I can build an actual frame for the mirror and mount it next week and I couldn’t have done it without all your help (and so many others, like @MMRIZE and everyone who wrote the modules I’m using.) So, really, thank you!
            @UncleRoger done, git pull to update
            if the notification received matches the configured notification restart the timer
              You truly are amazing!
              Am I right in thinking that if I change this:
                    } else if(topic==this.config.notification){
              to this:
                    } else if(topic==this.config.resetNotification){
              and put this in the config:
              resetNotification: "DIFF_NOTIF",
              in addition to the notification: setting, then I can have it reset when a different notification is received? And I’m assuming all modules get all the notifications?
              This would be so that if someone comes up and pushed the button to switch to the info display close to the end of the timer, it will reset it so they have time to look at what they want.
              UncleRogerU S 3 Replies Last reply Reply Quote 0
                UncleRoger @UncleRoger
                I made that change and it does indeed work as I’d hoped. This is totally awesome!
                Thank you!
                  @UncleRoger yes, make sure to add a default value in the defaults section
                  one could consider a list of notifications that cause reset, then you can search the list w includes()
                  as it’s a list, you could pre or postpend the notification to send to that list too
                  this stops the code from growing with other else clauses
                  resetNotifications:[]
                  in start maybe,
                  this.config.resetNotifications.unshift(this.config.notification)
                  that puts the actual notification of the front of the list
                  the in notificationReceived
                  if(this.config.resetNotifications.includes(notification)
                  resetTimer()
                  only one test
                    @UncleRoger said in Simple(?) module to send a notification every x minutes?:
                    yes, sendNotifications are broadcast to all modules
                      UncleRoger
                      Do modules each have their own timer or does resetting the timer in one module affect another?
                      I ask because I have MMM-BackgroundSlideshow set to change pictures each hour and MMM-SendNotification set to send a notification to MMM-Pages to switch to page 1 every 5 minutes. But in this setup, the picture never changes. My hypothesis is that when SendNotification resets the timer after 5 minutes, that affects BGSS which then never gets to 1 hour to switch to the next picture.
                      If I change BGSS to change pictures every 1 minute (or less than 5 minutes), the picture does change as expected.
                      Mind you, it’s probably something I’ve done that’s screwed it up, but I figured I’d ask about this first just to eliminate it as the source of the issue.
                      M UncleRogerU 2 Replies Last reply Reply Quote 0
                        MMRIZE @UncleRoger
                        @UncleRoger
                        Unfortunately, BGSS is implementing suspend method to stop it’s timer. So when you page rotator hides BGSS, it’s timer doesn’t work.
                        If you have some knowledge of JS, you can make monkey-patch with MMM-ModuleMonkeyPatch to suspend method not to stop its timer.
                          UncleRoger @MMRIZE
                          @MMRIZE
                          Hmmm… That’s actually a good behaviour, in my case. If it’s not being shown, there’s no need to be changing the picture.
                          But even when it’s not suspended, i.e., the picture is shown, it doesn’t change if its interval is greater than the SendNotification interval.
                          If i disable SendNotification and manually switch to the picture (i.e., unsuspend BGSS), it will happily switch pictures every hour.
                            MMRIZE @UncleRoger
                            @UncleRoger
                            The module also implements “resume” method to reset timer, so if the module get shown, it may be reset.
                            But I’m not sure unless examining all three modules related.
                              sdetweil @MMRIZE
                              @MMRIZE the sendnotification module implements both suspend and resume
                                So a little more testing…
                                If the interval for BGSS is >= the interval for SN, BGSS never changes the image. That is, SN causes BGSS to be active so its timer should start and (assuming nothing else changes) it should switch pictures according to the set interval but it doesn’t.
                                If the interval for BGSS < the interval for SN, and BGSS is active, it changes the image as it should.
                                Suspending and resuming BGSS does reset its timer, but if it’s not suspended, and its interval is >= SN’s, then it doesn’t change the image.
                                  @UncleRoger well there was a change I had to make to SN because pages was sending spurious resumes which caused timer resets
                                    I have the latest version. (I’ve also forked it to add a separate resetNotification but that’s not in place at the moment.)
                                    Based on what I’ve read about setInterval, the two modules should not be interfering with each other and yet, they sure seem to be.
                                    M S 2 Replies Last reply Reply Quote 0
                                      MMRIZE @UncleRoger
                                      @UncleRoger
                                      Can you share your forked version?
                                        @UncleRoger you will need a module to record all the notifications so you can see what is happening
                                        mmm-notifications I think
                                          UncleRoger @MMRIZE
                                          @MMRIZE said in Simple(?) module to send a notification every x minutes?:
                                          @UncleRoger
                                          I’d love to, but I’m not sure how. I mean, it’s a couple tiny changes…
                                          It’s here: https://github.com/Unclearogre/MMM-SendNotification
                                          I should update the readme before trying to put it back in the main one.
                                            @UncleRoger if you forked mine you can submit a pull request for me to include your changes
