    Simple(?) module to send a notification every x minutes?
    35 Posts 3 Posters 23.0k Views 3 Watching
      sdetweil @UncleRoger
      @UncleRoger I ran your config in debug ( npm start dev) with a stop on the actual sendNotification and it happens once every minute.
      I don’t have pages or carousel installed…
      UncleRogerU 1 Reply Last reply
        sdetweil @MMRIZE
        @MMRIZE said in Simple(?) module to send a notification every x minutes?:
        But sending notifications is harmless, so I put it into start, just for example.
        not harmless to the receiver if not setup yet
        • UncleRogerU
          UncleRoger @sdetweil
          I’ve no clue how to run it the way you did with the stop and all, but I did start commenting out modules and it seems that MMM-pages is the culprit.
          Without it, SendNotification works fine but when it’s active, SendNotification sends multiple notifications per second:
          It may be that MMM-pages is suspending and resuming MMM-SendNotification with each change, even though it’s set as “fixed”, and maybe that’s triggering it?
          It may be that this is just something that won’t work for me.
          I really appreciate your help!
          S 2 Replies Last reply
            @UncleRoger ok, I’ll check it out… hang on…
              @UncleRoger ok… it was pages (for the error)
              if you are using my fork
                  cd ~/MagicMirror/modules/MMM-Pages
                  git pull
              if u are NOT using my fork
              then rename the MMM-Pages folder out of the way (the command is mv)
              then
              git clone https://github.com/sdetweil/MMM-Pages
              also, two parms need to be added
              here is the updated config
                      module: 'MMM-Pages',
                              modules:
                                  [[ "page1" ],
                                   [ "page2" ],
                              //     [ "page3"],
                              fixed: [ "fixed" ],
                              hiddenPages: {
                                  "screenSaver": [ "screensaver_page" ],
                                  "admin": [ "admin_page" ],
                              animationTime: 10000,
                              rotationTime: 10000,
              rotationtime defaults to 0!!!
              • UncleRogerU
                I switched to your fork and while it’s better, it’s still sending a notification every several seconds.
                Here’s my config:
                			module: "MMM-Pages",
                                        classes: "fixed",
                			config:	{
                				modules:[	[ "page1" ],
                							[ "page2" ],
                				fixed: [ "fixed" ],
                and
                            module: 'MMM-SendNotification',
                            classes: "fixed",
                                interval: 3600000, // 1 minute interval
                                notification: 'PAGE_CHANGED',
                                payload: 1,
                (I upped the interval to see if that would do anything. It didn’t.)
                I’ve commented out all the other modules except the clock, MMM-BackgroundSlideshow, and MMM-ViewNotifications.
                  @UncleRoger ok, git pull the latest
                  and restart
                  I now check to see if the handler was turned off on resume, so don’t start another
                  lmk
                  • UncleRogerU
                    That worked! Thank you so much!
                    Now I am just being cheeky but if you are bored and want to add a feature, it would be great to be able to reset the timer based on a notification. (In my case, if MMM-Keypress sends a PAGE_INCREMENT notification to change pages, restart the timer from that point.)
                    Anyway, I am getting really close to having everything the way I want it and am hoping that I can build an actual frame for the mirror and mount it next week and I couldn’t have done it without all your help (and so many others, like @MMRIZE and everyone who wrote the modules I’m using.) So, really, thank you!
                      @UncleRoger done, git pull to update
                      if the notification received matches the configured notification restart the timer
                      • UncleRogerU
                        You truly are amazing!
                        Am I right in thinking that if I change this:
                              } else if(topic==this.config.notification){
                        to this:
                              } else if(topic==this.config.resetNotification){
                        and put this in the config:
                        resetNotification: "DIFF_NOTIF",
                        in addition to the notification: setting, then I can have it reset when a different notification is received? And I’m assuming all modules get all the notifications?
                        This would be so that if someone comes up and pushed the button to switch to the info display close to the end of the timer, it will reset it so they have time to look at what they want.
                        UncleRogerU S 3 Replies Last reply
                        • UncleRogerU
                          UncleRoger @UncleRoger
                          I made that change and it does indeed work as I’d hoped. This is totally awesome!
                          Thank you!
                            @UncleRoger yes, make sure to add a default value in the defaults section
                            one could consider a list of notifications that cause reset, then you can search the list w includes()
                            as it’s a list, you could pre or postpend the notification to send to that list too
                            this stops the code from growing with other else clauses
                            resetNotifications:[]
                            in start maybe,
                            this.config.resetNotifications.unshift(this.config.notification)
                            that puts the actual notification of the front of the list
                            the in notificationReceived
                            if(this.config.resetNotifications.includes(notification)
                            resetTimer()
                            only one test
                              @UncleRoger said in Simple(?) module to send a notification every x minutes?:
                              yes, sendNotifications are broadcast to all modules
                              • UncleRogerU
                                UncleRoger
                                Do modules each have their own timer or does resetting the timer in one module affect another?
                                I ask because I have MMM-BackgroundSlideshow set to change pictures each hour and MMM-SendNotification set to send a notification to MMM-Pages to switch to page 1 every 5 minutes. But in this setup, the picture never changes. My hypothesis is that when SendNotification resets the timer after 5 minutes, that affects BGSS which then never gets to 1 hour to switch to the next picture.
                                If I change BGSS to change pictures every 1 minute (or less than 5 minutes), the picture does change as expected.
                                Mind you, it’s probably something I’ve done that’s screwed it up, but I figured I’d ask about this first just to eliminate it as the source of the issue.
                                M UncleRogerU 2 Replies Last reply
                                  MMRIZE @UncleRoger
                                  @UncleRoger
                                  Unfortunately, BGSS is implementing suspend method to stop it’s timer. So when you page rotator hides BGSS, it’s timer doesn’t work.
                                  If you have some knowledge of JS, you can make monkey-patch with MMM-ModuleMonkeyPatch to suspend method not to stop its timer.
                                  • UncleRogerU
                                    UncleRoger @MMRIZE
                                    @MMRIZE
                                    Hmmm… That’s actually a good behaviour, in my case. If it’s not being shown, there’s no need to be changing the picture.
                                    But even when it’s not suspended, i.e., the picture is shown, it doesn’t change if its interval is greater than the SendNotification interval.
                                    If i disable SendNotification and manually switch to the picture (i.e., unsuspend BGSS), it will happily switch pictures every hour.
                                    M 1 Reply Last reply
                                      MMRIZE @UncleRoger
                                      @UncleRoger
                                      The module also implements “resume” method to reset timer, so if the module get shown, it may be reset.
                                      But I’m not sure unless examining all three modules related.
                                        sdetweil @MMRIZE
                                        @MMRIZE the sendnotification module implements both suspend and resume
                                        • UncleRogerU
                                          So a little more testing…
                                          If the interval for BGSS is >= the interval for SN, BGSS never changes the image. That is, SN causes BGSS to be active so its timer should start and (assuming nothing else changes) it should switch pictures according to the set interval but it doesn’t.
                                          If the interval for BGSS < the interval for SN, and BGSS is active, it changes the image as it should.
                                          Suspending and resuming BGSS does reset its timer, but if it’s not suspended, and its interval is >= SN’s, then it doesn’t change the image.
                                            @UncleRoger well there was a change I had to make to SN because pages was sending spurious resumes which caused timer resets
