    Simple(?) module to send a notification every x minutes?
    35 Posts 3 Posters 22.7k Views 3 Watching
    • UncleRogerU Offline
      UncleRoger @sdetweil
      @sdetweil said in Simple(?) module to send a notification every x minutes?:
      https://github.com/sdetweil/MMM-SendNotification
      Thank you so much! That got a lot farther than I ever did. When it gets to the point of actually sending the notification, however, I see an error in the browser console:
      sendNotification: Notification should be a string.
      As far as I can tell, the notification (this.config.notification) is a string. Is there something else that I can do to force it to be considered a string?
      Note: the only change I made was to add a bunch of console.log messages so I could try to understand what was going on and then, when I saw that error, commented out the sendnotification line (which made the error disappear). When I uncommented it, the error came back.
        sdetweil @UncleRoger
        @UncleRoger do a git pull in the module folder… just posted a fix
        UncleRogerU 1 Reply Last reply Reply Quote 0
          Got the new version (typo in “notification”?) and it seems to work except that it ignores the interval and just constantly sends the notification.
          Also, there’s an error showing in the console log:
          Parameter mismatch in module.show: callback is not an optional parameter! 3 module.js:394:8
          with different numbers. I’m not sure that’s a problem (MMM-BackgroundSlideshow has the same error and it works fine) but I thought I’d mention it.
            @UncleRoger can u post the module config
              This is what I have:
                module: 'MMM-SendNotification',
                position: 'top_right',
                classes: "fixed",
                  interval: 60000, // 1 minute interval
                  notification: 'PAGE_CHANGED',
                  payload: 1,
              Thank you for your patience and assistance! You are amazing!
                @UncleRoger no position, as there is no UI…
                  @UncleRoger I ran your config in debug ( npm start dev) with a stop on the actual sendNotification and it happens once every minute.
                  I don’t have pages or carousel installed…
                    sdetweil @MMRIZE
                    @MMRIZE said in Simple(?) module to send a notification every x minutes?:
                    But sending notifications is harmless, so I put it into start, just for example.
                    not harmless to the receiver if not setup yet
                      I’ve no clue how to run it the way you did with the stop and all, but I did start commenting out modules and it seems that MMM-pages is the culprit.
                      Without it, SendNotification works fine but when it’s active, SendNotification sends multiple notifications per second:
                      It may be that MMM-pages is suspending and resuming MMM-SendNotification with each change, even though it’s set as “fixed”, and maybe that’s triggering it?
                      It may be that this is just something that won’t work for me.
                      I really appreciate your help!
                        @UncleRoger ok, I’ll check it out… hang on…
                          @UncleRoger ok… it was pages (for the error)
                          if you are using my fork
                              cd ~/MagicMirror/modules/MMM-Pages
                              git pull
                          if u are NOT using my fork
                          then rename the MMM-Pages folder out of the way (the command is mv)
                          then
                          git clone https://github.com/sdetweil/MMM-Pages
                          also, two parms need to be added
                          here is the updated config
                                  module: 'MMM-Pages',
                                          modules:
                                              [[ "page1" ],
                                               [ "page2" ],
                                          //     [ "page3"],
                                          fixed: [ "fixed" ],
                                          hiddenPages: {
                                              "screenSaver": [ "screensaver_page" ],
                                              "admin": [ "admin_page" ],
                                          animationTime: 10000,
                                          rotationTime: 10000,
                          rotationtime defaults to 0!!!
                            I switched to your fork and while it’s better, it’s still sending a notification every several seconds.
                            Here’s my config:
                            			module: "MMM-Pages",
                                                    classes: "fixed",
                            			config:	{
                            				modules:[	[ "page1" ],
                            							[ "page2" ],
                            				fixed: [ "fixed" ],
                            and
                                        classes: "fixed",
                                            interval: 3600000, // 1 minute interval
                                            payload: 1,
                            (I upped the interval to see if that would do anything. It didn’t.)
                            I’ve commented out all the other modules except the clock, MMM-BackgroundSlideshow, and MMM-ViewNotifications.
                              @UncleRoger ok, git pull the latest
                              and restart
                              I now check to see if the handler was turned off on resume, so don’t start another
                              lmk
                                That worked! Thank you so much!
                                Now I am just being cheeky but if you are bored and want to add a feature, it would be great to be able to reset the timer based on a notification. (In my case, if MMM-Keypress sends a PAGE_INCREMENT notification to change pages, restart the timer from that point.)
                                Anyway, I am getting really close to having everything the way I want it and am hoping that I can build an actual frame for the mirror and mount it next week and I couldn’t have done it without all your help (and so many others, like @MMRIZE and everyone who wrote the modules I’m using.) So, really, thank you!
                                  @UncleRoger done, git pull to update
                                  if the notification received matches the configured notification restart the timer
                                    You truly are amazing!
                                    Am I right in thinking that if I change this:
                                          } else if(topic==this.config.notification){
                                    to this:
                                          } else if(topic==this.config.resetNotification){
                                    and put this in the config:
                                    resetNotification: "DIFF_NOTIF",
                                    in addition to the notification: setting, then I can have it reset when a different notification is received? And I’m assuming all modules get all the notifications?
                                    This would be so that if someone comes up and pushed the button to switch to the info display close to the end of the timer, it will reset it so they have time to look at what they want.
                                    UncleRogerU S 3 Replies Last reply Reply Quote 0
                                      UncleRoger @UncleRoger
                                      I made that change and it does indeed work as I’d hoped. This is totally awesome!
                                      Thank you!
                                        @UncleRoger yes, make sure to add a default value in the defaults section
                                        one could consider a list of notifications that cause reset, then you can search the list w includes()
                                        as it’s a list, you could pre or postpend the notification to send to that list too
                                        this stops the code from growing with other else clauses
                                        resetNotifications:[]
                                        in start maybe,
                                        this.config.resetNotifications.unshift(this.config.notification)
                                        that puts the actual notification of the front of the list
                                        the in notificationReceived
                                        if(this.config.resetNotifications.includes(notification)
                                        resetTimer()
                                        only one test
                                          @UncleRoger said in Simple(?) module to send a notification every x minutes?:
                                          yes, sendNotifications are broadcast to all modules
                                            UncleRoger
                                            Do modules each have their own timer or does resetting the timer in one module affect another?
                                            I ask because I have MMM-BackgroundSlideshow set to change pictures each hour and MMM-SendNotification set to send a notification to MMM-Pages to switch to page 1 every 5 minutes. But in this setup, the picture never changes. My hypothesis is that when SendNotification resets the timer after 5 minutes, that affects BGSS which then never gets to 1 hour to switch to the next picture.
                                            If I change BGSS to change pictures every 1 minute (or less than 5 minutes), the picture does change as expected.
                                            Mind you, it’s probably something I’ve done that’s screwed it up, but I figured I’d ask about this first just to eliminate it as the source of the issue.
                                            M UncleRogerU 2 Replies Last reply Reply Quote 0
