    MMM-RTSPStream - no video
    6 Posts 5 Posters 2.1k Views 5 Watching
    • buzzkcB Offline
      buzzkc
      Have you disabled any other modules to make sure there isn’t a conflict with one? I ran into the issue with the MMM-GoogleMapsTraffic module (see pr for fix: https://github.com/vicmora/MMM-GoogleMapsTraffic/pull/24). Before applying that fix I was getting the box, but no video. Also had issues with other modules loading.
      Darren
      My Build: https://forum.magicmirror.builders/topic/11153/new-non-mirror
      • zdenekZ Offline
        zdenek
        @zdenek said in MMM-RTSPStream - no video:
        http://www.ispyconnect.com/man.aspx?n=airlive
        I’ve used also “sample” config and added just MMM-RTSPStream module, but the same result. I’ve red about Google Maps, but I don’t use this module
        module config:
            module: "MMM-RTSPStream",
                autoStart: true,
                rotateStreams: true,
                rotateStreamTimeout: 10,
                moduleWidth: 354,
                moduleHeight: 240,
                localPlayer: 'omxplayer',
                remotePlayer: 'none',
                showSnapWhenPaused: true,
                remoteSnaps: true,
                stream1: {
                    url: 'rtsp://IPADDRESS/stream1',
                    frameRate: 'undefined',
                    snapshotType: 'url',
                    snapshotRefresh: 10,
                    width: undefined,
                    height: undefined,
        • 3 Offline
          35110
          That sounds interesting, because I’m apparently too stupid to get a picture on my MM from my Dahua IP camera. About VLC Player I can easily see the RTSP video stream on my PC.
          Das klingt interessant, ich bin nämlich scheinbar auch zu blöd, ein Bild auf meinen MM von meiner Dahua IP Kamera zu bekommen. Über VLC Player kann ich ohne Probleme den RTSP Videostream auf meinem PC ansehen.
            Joern @zdenek
            @zdenek Hello, what did you fix in Google Maps Traffic code?
            Have same issue…
            • BKeyportB Offline
              BKeyport Module Developer @zdenek
              @zdenek I’ve never been able to get any stream working out of RTSPStream other than OMXPlayer, which is quite dead, sadly. What I’ve done is use an old pi I had lying around to run MotionEyeOS to convert the image, then MMM-EmbedURL to embed the web “Photo” generated by MotionEyeOS. I need a modern solution, but it works.
              With RTSPStream going unsupported, I would look for another solution.
              That being said, it does appear to have a direct URL = http://user:pass@192.168.X.X/axis-cgi/mjpg/video.cgi
              If that produces a image stream DIRECTLY IN A BROWSER, you can use MMM-EmbedURL and the like to point directly at that and bam you’ve got it without a fuss. If it attempts to load a video player, no dice.
