    MM current version on Raspberry Pi 5 cannot turn off monitor
    53 Posts 9 Posters 32.2k Views 9 Watching
    • V Offline
      vvrangler
      Anyone using MM on a Raspberry Pi 5 or running a Raspberry Pi 5 in general know how to turn off the monitor now?
      I have been using MMM-Remote-Control and turning off/on the monitor using the following requests
      http://<MagicMirrorIPAddress>:8080/remote?action=MONITOROFF
      http://<MagicMirrorIPAddress>:8080/remote?action=MONITORON
      Which ultimately issue the commands
      vcgencmd display_power 0
      vcgencmd display_power 1
      but these commands, no longer work and are generating errors and not Turing the monitor off/on
      [30.12.2023 12:15.44.921] [ERROR]
      [30.12.2023 12:15.44.927] [ERROR] Error: Command failed: vcgencmd display_power 0
          at ChildProcess.exithandler (node:child_process:430:12)
          at ChildProcess.emit (node:events:513:28)
          at maybeClose (node:internal/child_process:1091:16)
          at Process.onexit (node:internal/child_process:302:5) {
        code: 255,
        killed: false,
        signal: null,
        cmd: 'vcgencmd display_power 0'
      [30.12.2023 12:15.47.731] [ERROR]
      [30.12.2023 12:15.47.732] [ERROR] Error: Command failed: vcgencmd display_power 1
        code: 255,
        killed: false,
        signal: null,
        cmd: 'vcgencmd display_power 1'
      This is the command line result from outside of MM
      MMUser@MagicMirror:~ $ vcgencmd display_power 0
      vc_gencmd_read_response returned -1
      error=1 error_msg="Command not registered"
      Web searches for a solution have been unsuccessful.
      Thanks for any help you might be able to provide.
      • karsten13K Offline
        karsten13 @vvrangler
        @vvrangler
        untested:
        wlr-randr --output HDMI-A-1 --off
        wlr-randr --output HDMI-A-1 --on
        instead of vcgencmd commands.
        See e.g. https://forums.raspberrypi.com/viewtopic.php?t=358689
        • V Offline
          vvrangler @karsten13
          @karsten13 said in MM current version on Raspberry Pi 5 cannot turn off monitor:
          @karsten13, I did try those commands and I receive this response to both
          MMUser@MagicMirror:~ $ wlr-randr --output HDMI-A-1 --off
          failed to connect to display
            @vvrangler
            may wrong display, don’t no how the syntax is for the other HDMI port instead of HDMI-A-1 …
            • V Offline
              @karsten13 I was not able to get any commands using the wlr-randr to show anything other than “failed to connect to display”, however, after much searching, I did find a command that was able to turn the screen off and on
              MMUser@MagicMirror:~ $ DISPLAY=:0.0 xrandr --output HDMI-1 --off
              MMUser@MagicMirror:~ $ DISPLAY=:0.0 xrandr --output HDMI-1 --mode 2560x1440 --rate 60 --rotate left
              Although I’m not sure how to get this into something that can be called from MagicMirror itself so that it can be run as a menu command in MMM-Remote-Control or some other way that it can be called from outside of MagicMirror
                jbat66 @vvrangler
                @vvrangler
                You have to have MMM-Remote-Control installed, and in the config.js file you can put several custom commands that point to scripts on your machine.
                Here is an example for two of them in my config.js.
                mm-manager.sh, is just a script I wrote to do things to my magic mirror, you scripts can be named what you want and just have the commands you want.
                • V Offline
                  vvrangler @jbat66
                  @jbat66 , @karsten13 , thank you for the help, I was able to get it going using the custom commands in MMM-Remote-Control
                    JohnGalt
                    I’m having the same issues… I recently built a new MagicMirror instance using the latest Raspbian OS, and the commands I have used in prior instances don’t work in the new OS.
                    None of the commands listed above work for me. I have also tried the following in the crontab. While it DOES turn off the monitor display, the display turns itself back on in about 10 seconds…
                    display_off >/dev/null 2>&1
                    Any help will be greatly appreciated, as the MagicMirror is in a location where running the display all night is disrupting people’s sleep, and having to manually turn it on and off is very inconvenient.
                      jbat66 @JohnGalt
                      @JohnGalt I have a Pi 4, but have the latest OS, and I never have found a way to turn off the monitor. I have the same problem of the screen being too bright, so what I did was write a bash script, to turn off the background slide show, and to dim all the modules via the api into MMM-remote. I also have in my script just a hide all, and the screen goes blank, even tho the monitor is still on.
                      Here is how you can hide all modules
                      curl -X GET “$API_URL/api/module/all/hide” -H “accept: application/json”
                      the $API_URL, is your IP address. I use “http://localhost:8080”
                      I also wrote a script that will get the sunrise sunset times for the day and shut off my screen by hiding or diming all the modules at sunset, and then reverse that at sunrise.
                      let me know if you are interested. I need to put some of my stuff up on github. I’m just getting familiar with github, and have fixed a couple of modules for folks in the last week.
                        jbat66 @JohnGalt
                        @JohnGalt Side note, I will buy someone a pizza, if I can get working commands to actually turn off and turn on my HDMI display. I think I have tried everything on the internet with no luck. I’m serious about the pizza!
                        • 1 / 6
