    MM doesn't start after last update
    20 Posts 5 Posters 8.2k Views 4 Watching
      matt216 @JoeFranz
      @JoeFranz I’m getting these vulkan warnings too - any idea what they/it is?! Doesn’t seem to affect my mirror working…
        sdetweil @matt216
        @matt216 I think the vulcan warnings are a side effect of another error…
        can u send me that somefile.txt… same userid as here at gmail…
        i don’t look at any personal info… so try not to filter it…
        J 1 Reply Last reply
          JoeFranz @sdetweil
          MMM-Tado doesn’t start, here are the error messages :-(
          /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
          1|MagicMir |     at process.processTimers (node:internal/timers:512:7)
          1|MagicMir | [02.01.2024 16:25.56.242] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 36)
          1|MagicMir | [02.01.2024 16:30.56.239] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: TypeError: self.tadoClient.login is not a function
          1|MagicMir |     at Class.getData (/home/pi/MagicMirror/modules/MMM-Tado/node_helper.js:20:25)
          1|MagicMir |     at Timeout._onTimeout (/home/pi/MagicMirror/modules/MMM-Tado/node_helper.js:103:22)
          1|MagicMir |     at listOnTimeout (node:internal/timers:569:17)
          1|MagicMir | [02.01.2024 16:30.56.240] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: Unhandled promise rejec
          tion. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 40)
          1|MagicMir | [02.01.2024 16:35.56.242] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: TypeError: self.tadoClient.login is not a function
          1|MagicMir | [02.01.2024 16:35.56.243] [ERROR] (node:1226) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 44)
          1|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
            sdetweil @JoeFranz
            @JoeFranz yeh tado seems to be affected by a change in how nodejs does context scoping.
            I’ll try to make fork in the morning
              @JoeFranz try my fork
              rename the current module folder out of the way
              cd ~/MagicMirror/modules
              git clone https://github.com/sdetweil/MMM-Tado
              cd MMM-Tado
              npm install
              restart mm
                JoeFranz @sdetweil
                That worked, thank you very much :-)
                Now I’m only missing two calendars that aren’t displayed.
                One from icloud and one from google. Other iCloud calendars are displayed. I hope I find the error :-)
                N 1 Reply Last reply
                • N
                  nechry @JoeFranz
                  @JoeFranz hello I also got, I think same issue, about 2 ical didn’t load. did you figure out the issue?
                    JoeFranz
                    No, unfortunately not… :-(
                    S 2 Replies Last reply
                      sdetweil @JoeFranz
                      @JoeFranz still trying to find the cause…
                      so far every cal url I have received works great on my local MM systems. 2.25 and 2.26, x86, pi3, pi4 and pi5.
                      so, i’m not use what is going on…
                      in all the cases if the cal is parsed the events are broadcast but cal says no events… ???
                      weird…
                        sdetweil @JoeFranz
                        @JoeFranz lets get you back to working, move you back to whatever release worked…
                        stop mm if running
                        on the command line
                        git  tag -l
                        to list the tags (checkpoints in the list f changes, made at every release)
                        you should see a list
                        then whichever release you were last working on do
                        git checkout -b tempbranch tags/v???  the number,  2.25.0 or whatever
                        like
                        git checkout -b tempbranch tags/v2.25.0
                        if successful
                        then
                        rm -rf node_modules
                        npm install
                        and give it a try
                          JoeFranz @sdetweil
                          Don’t work so hard…
                          It was just a calendar where the appointments weren’t displayed. I have now copied these into another calendar and they are now displayed there. I’m glad that everything else is working fine again, thank you for your help! :-)
                          The command “git tag -l” only shows me up to version v2.2.0.
                          I think I’ll leave it like that for now…:winking_face:
                            sdetweil @JoeFranz
                            @JoeFranz weird. but thanks for the info
                            • plainbrokeP
                              plainbroke
                              @sdetweil > git tag -l
                              Sam,
                              I am running MM 2.24.0 if I update to 2.26 Do you think it will break MMM-RTSPStream? I have 4 different instances of it running in carousel. We love the way it works showing us video of all 4 sides of our house outside.
                                sdetweil @plainbroke
                                @plainbroke no idea, don’t upgrade
                                if u see the new update message, just add
                                disabled: true
                                to the updatenotifications module
                                and restart mm
                                plainbrokeP 1 Reply Last reply
                                • plainbrokeP
                                  plainbroke @sdetweil
                                  Ok thanks for the honest answer.
                                  You the man.
                                    @plainbroke there is NEVER any reason to upgrade, unless there is something you NEED .
                                    if it ain’t broke, don’t ‘fix’ it…
