    New installation but even default is displayed
    23 Posts 2 Posters 8.2k Views 2 Watching
    • K Offline
      kupperma
      I have just installed https://github.com/sdetweil/MagicMirror_scripts
      MagicMirror2 is booting, I can see the splashscreen but then nothing is displayed. I did not add any module yet, no API-Keys it’s just the new installed MM.
      Here is the pm2 log mm
      ~/MagicMirror $ pm2 log mm
      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
      1|mm       | [06.01.2024 12:07.46.129] [LOG]   Loading config ...
      1|mm       | [06.01.2024 12:07.46.138] [DEBUG] config template file not exists, no envsubst
      1|mm       | [06.01.2024 12:07.46.216] [LOG]   Loading module helpers ...
      1|mm       | [06.01.2024 12:07.46.255] [LOG]   No helper found for module: alert.
      1|mm       | [06.01.2024 12:07.46.750] [LOG]   Initializing new module helper ...
      1|mm       | [06.01.2024 12:07.46.752] [LOG]   Module helper loaded: updatenotification
      1|mm       | [06.01.2024 12:07.46.815] [LOG]   No helper found for module: clock.
      1|mm       | [06.01.2024 12:07.48.676] [LOG]   Initializing new module helper ...
      1|mm       | [06.01.2024 12:07.48.678] [LOG]   Module helper loaded: calendar
      1|mm       | [06.01.2024 12:07.48.724] [LOG]   No helper found for module: compliments.
      1|mm       | [06.01.2024 12:07.48.726] [LOG]   No helper found for module: weather.
      1|mm       | [06.01.2024 12:07.49.978] [LOG]   Initializing new module helper ...
      1|mm       | [06.01.2024 12:07.49.979] [LOG]   Module helper loaded: newsfeed
      1|mm       | [06.01.2024 12:07.49.980] [LOG]   All module helpers loaded.
      1|mm       | [06.01.2024 12:07.50.118] [LOG]   Starting server on port 8080 ...
      1|mm       |   errno: -98,
      1|mm       |   syscall: 'listen',
      1|mm       |   address: '::1',
      1|mm       |   port: 8080
      1|mm       | }
      1|mm       | [06.01.2024 12:07.55.424] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      1|mm       | [06.01.2024 12:07.55.435] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      1|mm       | Warning: vkCreateInstance: Found no drivers!
      1|mm       | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
      1|mm       |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
      1|mm       |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
      1|mm       |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
      1|mm       |     at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
      1|mm       |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
      1|mm       |
      Can anybody tell me what I do not see?
      Manfred
        sdetweil @kupperma
        @kupperma run my backup/restore script… it saves all that and can be loaded up to github and versioned and restored from there
        https://github.com/sdetweil/MagicMirror-backup-restore
        it saves links to all the modules and restores from the links
          sdetweil @kupperma
          @kupperma was this a new SD card install?
          that error means some other app is using port 8080.
          mm is not the name of my pm2 mm task, so it sounds like you tried the manual way and it is running too
          pm2 status
          will show the managed apps
          pm2 stop all
          pm2 start MagicMirror
          • K Offline
            kupperma
            I did what you asked:
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] [MagicMirror](0) ✓
            [PM2] Process successfully started
            │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
            │ 0   │ MagicMirror    │ default     │ 2.26.0  │ fork    │ 4369     │ 0s     │ 0    │ online    │ 0%       │ 2.8mb    │ pi       │ disabled │
            │ 1   │ mm             │ default     │ N/A     │ fork    │ 0        │ 0      │ 1    │ stopped   │ 0%       │ 0b       │ pi       │ disabled │
            I wonder why “watching” is disabled.
            Manfred
              sdetweil @kupperma
              @kupperma and did that bring up MagicMirror?
              if so, you can delete the mm definition
              pm2  delete mm
              pm2 save
              watching
              the system maybe doesn’t that support… in my json file I request it
              • K Offline
                kupperma
                I deleted mm
                But no, MagicMirror does not appear.
                pm2 status looks like that now:
                ~/MagicMirror $ pm2 status
                │ 0   │ MagicMirror    │ default     │ 2.26.0  │ fork    │ 4369     │ 6m     │ 0    │ online    │ 0%       │ 2.8mb    │ pi       │ disabled │
                  sdetweil @kupperma
                  @kupperma where are you doing the pm2 start?
                  on the MM system screen in a terminal window
                  over ssh
                  over vnc
                  lets try this, without pm2 involved
                  pm2 stop all
                  npm start
                  • K Offline
                    kupperma
                    Here is the output:
                    npm start
                    > magicmirror@2.26.0 start
                    [06.01.2024 15:56.41.020] [LOG]   Starting MagicMirror: v2.26.0
                    [06.01.2024 15:56.41.030] [LOG]   Loading config ...
                    [06.01.2024 15:56.41.035] [DEBUG] config template file not exists, no envsubst
                    [06.01.2024 15:56.41.042] [LOG]   Loading module helpers ...
                    [06.01.2024 15:56.41.044] [LOG]   No helper found for module: alert.
                    [06.01.2024 15:56.41.095] [LOG]   Initializing new module helper ...
                    [06.01.2024 15:56.41.097] [LOG]   Module helper loaded: updatenotification
                    [06.01.2024 15:56.41.098] [LOG]   No helper found for module: clock.
                    [06.01.2024 15:56.41.376] [LOG]   Initializing new module helper ...
                    [06.01.2024 15:56.41.378] [LOG]   Module helper loaded: calendar
                    [06.01.2024 15:56.41.380] [LOG]   No helper found for module: compliments.
                    [06.01.2024 15:56.41.381] [LOG]   No helper found for module: weather.
                    [06.01.2024 15:56.41.580] [LOG]   Initializing new module helper ...
                    [06.01.2024 15:56.41.581] [LOG]   Module helper loaded: newsfeed
                    [06.01.2024 15:56.41.581] [LOG]   All module helpers loaded.
                    [06.01.2024 15:56.41.597] [LOG]   Starting server on port 8080 ...
                    [06.01.2024 15:56.42.098] [LOG]   Server started ...
                    [06.01.2024 15:56.42.099] [LOG]   Connecting socket for: updatenotification
                    [06.01.2024 15:56.42.101] [LOG]   Starting module helper: updatenotification
                    [06.01.2024 15:56.42.102] [LOG]   Connecting socket for: calendar
                    [06.01.2024 15:56.42.103] [LOG]   Starting node helper for: calendar
                    [06.01.2024 15:56.42.104] [LOG]   Connecting socket for: newsfeed
                    [06.01.2024 15:56.42.105] [LOG]   Starting node helper for: newsfeed
                    [06.01.2024 15:56.42.106] [LOG]   Sockets connected & modules started ...
                    [06.01.2024 15:56.42.132] [LOG]   Launching application.
                    [06.01.2024 15:56.45.490] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 604800000
                    [06.01.2024 15:56.45.911] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                    [06.01.2024 15:56.45.924] [INFO]  updatenotification: Updater Class Loaded!
                    [06.01.2024 15:56.45.926] [INFO]  updatenotification: Checking PM2 using...
                    [06.01.2024 15:56.45.931] [INFO]  Checking git for module: MagicMirror
                    [06.01.2024 15:56.47.527] [INFO]  Calendar-Fetcher: Broadcasting 12 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                    [06.01.2024 15:56.47.822] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                    [06.01.2024 15:56.48.421] [INFO]  updatenotification: You are not using pm2
                      sdetweil @kupperma
                      @kupperma cool… thats good… tell me about the physical system hookup
                      where is the physical display?
                      • K Offline
                        kupperma
                        Sorry forgot to answer:
                        I am on the raspberrypi over ssh.
                        The Display is connected directly via the HDMI Port of the pi . All equipment is right at arm distance, because I’m setting it up first before staching it behind the actual mirror.
                        But I am on the pi via ssh so that later I can do updates and probably adding new modules .
                        Manfred
                          sdetweil @kupperma
                          @kupperma which kind of pi? if Pi 4/5 is the port on the left (closest to power) hdmi port?
                          • K Offline
                            kupperma
                            This is an pi 3 Model B V1.2
                            the HDMI is about 2 Centimeters right to the MicroUSB Power input.
                            I updated to raspianOS bookworm first.
                            Manfred
                              sdetweil @kupperma
                              @kupperma weird…
                              do you have keyboard to pi system desktop?
                              if so, ctrl-alt-t to open a terminal window and do
                              echo $DISPLAY
                              • K Offline
                                kupperma
                                Yes I have_
                                Ok this does not work.
                                So it seems to be raspianOS failure.
                                  sdetweil @kupperma
                                  @kupperma I ONLY use SSH to install MM… never use the actual display.
                                  have pi 0w, 02w, 3, 4,5 odroid, jetson nano, chromebox, chromebook,
                                  and multiple virtual machines under vmware
                                  NEVER seen npm run start say successful but not see it on screen…
                                  also, on the screen if u can,
                                  ctrl-c to stop the in ssh version
                                  on screen
                                  cd ~/Magicmirror
                                  npm start
                                    sdetweil @kupperma
                                    @kupperma said in New installation but even default is displayed:
                                    what does not work?
                                    • K Offline
                                      kupperma
                                      The display does not react to ctrl-alt-t and there is no terminal visible.
                                        sdetweil @kupperma
                                        @kupperma ok, on the menu bar there is a terminal window, click that
                                        • K Offline
                                          kupperma
                                          I know what you mean:
                                          in an earlier installation I could move the mouse and the menubar got visible or I could press F11 and the menubar got visible. But now nothing works.
                                          So should I reinstall raspian and start from the beginning or is there a work a round?
                                            sdetweil @kupperma
                                            @kupperma can u reboot? does anything change? again weird…
                                            did you have MM running before? what would you lose starting over?
                                            IF you start over,
                                            new flash
                                            boot, skip updates,
                                            reboot turn on ssh
                                            then run my install script… it will update system, install node, then mm…
                                            • K Offline
                                              kupperma
                                              I start over!
                                              Thanks for the checklist.
                                              I wont loose much for my custom.css , config.js I have the code copied in a textfile. The modules I would have to reinstall but thats ok.
                                              Thank you for your time.
                                              Manfred
