    New installation but even default is displayed
    23 Posts 2 Posters 7.3k Views 2 Watching
      sdetweil @kupperma
      @kupperma and did that bring up MagicMirror?
      if so, you can delete the mm definition
      pm2  delete mm
      pm2 save
      watching
      the system maybe doesn’t that support… in my json file I request it
      • K Offline
        kupperma
        I deleted mm
        But no, MagicMirror does not appear.
        pm2 status looks like that now:
        ~/MagicMirror $ pm2 status
        │ id  │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
        │ 0   │ MagicMirror    │ default     │ 2.26.0  │ fork    │ 4369     │ 6m     │ 0    │ online    │ 0%       │ 2.8mb    │ pi       │ disabled │
          sdetweil @kupperma
          @kupperma where are you doing the pm2 start?
          on the MM system screen in a terminal window
          over ssh
          over vnc
          lets try this, without pm2 involved
          pm2 stop all
          npm start
          • K Offline
            kupperma
            Here is the output:
            npm start
            > magicmirror@2.26.0 start
            [06.01.2024 15:56.41.020] [LOG]   Starting MagicMirror: v2.26.0
            [06.01.2024 15:56.41.030] [LOG]   Loading config ...
            [06.01.2024 15:56.41.035] [DEBUG] config template file not exists, no envsubst
            [06.01.2024 15:56.41.042] [LOG]   Loading module helpers ...
            [06.01.2024 15:56.41.044] [LOG]   No helper found for module: alert.
            [06.01.2024 15:56.41.095] [LOG]   Initializing new module helper ...
            [06.01.2024 15:56.41.097] [LOG]   Module helper loaded: updatenotification
            [06.01.2024 15:56.41.098] [LOG]   No helper found for module: clock.
            [06.01.2024 15:56.41.376] [LOG]   Initializing new module helper ...
            [06.01.2024 15:56.41.378] [LOG]   Module helper loaded: calendar
            [06.01.2024 15:56.41.380] [LOG]   No helper found for module: compliments.
            [06.01.2024 15:56.41.381] [LOG]   No helper found for module: weather.
            [06.01.2024 15:56.41.580] [LOG]   Initializing new module helper ...
            [06.01.2024 15:56.41.581] [LOG]   Module helper loaded: newsfeed
            [06.01.2024 15:56.41.581] [LOG]   All module helpers loaded.
            [06.01.2024 15:56.41.597] [LOG]   Starting server on port 8080 ...
            [06.01.2024 15:56.42.098] [LOG]   Server started ...
            [06.01.2024 15:56.42.099] [LOG]   Connecting socket for: updatenotification
            [06.01.2024 15:56.42.101] [LOG]   Starting module helper: updatenotification
            [06.01.2024 15:56.42.102] [LOG]   Connecting socket for: calendar
            [06.01.2024 15:56.42.103] [LOG]   Starting node helper for: calendar
            [06.01.2024 15:56.42.104] [LOG]   Connecting socket for: newsfeed
            [06.01.2024 15:56.42.105] [LOG]   Starting node helper for: newsfeed
            [06.01.2024 15:56.42.106] [LOG]   Sockets connected & modules started ...
            [06.01.2024 15:56.42.132] [LOG]   Launching application.
            [06.01.2024 15:56.45.490] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 604800000
            [06.01.2024 15:56.45.911] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            [06.01.2024 15:56.45.924] [INFO]  updatenotification: Updater Class Loaded!
            [06.01.2024 15:56.45.926] [INFO]  updatenotification: Checking PM2 using...
            [06.01.2024 15:56.45.931] [INFO]  Checking git for module: MagicMirror
            [06.01.2024 15:56.47.527] [INFO]  Calendar-Fetcher: Broadcasting 12 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
            [06.01.2024 15:56.47.822] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
            [06.01.2024 15:56.48.421] [INFO]  updatenotification: You are not using pm2
              sdetweil @kupperma
              @kupperma cool… thats good… tell me about the physical system hookup
              where is the physical display?
              • K Offline
                kupperma
                Sorry forgot to answer:
                I am on the raspberrypi over ssh.
                The Display is connected directly via the HDMI Port of the pi . All equipment is right at arm distance, because I’m setting it up first before staching it behind the actual mirror.
                But I am on the pi via ssh so that later I can do updates and probably adding new modules .
                Manfred
                  sdetweil @kupperma
                  @kupperma which kind of pi? if Pi 4/5 is the port on the left (closest to power) hdmi port?
                  • K Offline
                    kupperma
                    This is an pi 3 Model B V1.2
                    the HDMI is about 2 Centimeters right to the MicroUSB Power input.
                    I updated to raspianOS bookworm first.
                    Manfred
                      sdetweil @kupperma
                      @kupperma weird…
                      do you have keyboard to pi system desktop?
                      if so, ctrl-alt-t to open a terminal window and do
                      echo $DISPLAY
                      • K Offline
                        kupperma
                        Yes I have_
                        Ok this does not work.
                        So it seems to be raspianOS failure.
