    New installation but even default is displayed
    23 Posts 2 Posters 8.7k Views 2 Watching
    • K Offline
      kupperma
      Sorry forgot to answer:
      I am on the raspberrypi over ssh.
      The Display is connected directly via the HDMI Port of the pi . All equipment is right at arm distance, because I’m setting it up first before staching it behind the actual mirror.
      But I am on the pi via ssh so that later I can do updates and probably adding new modules .
      Manfred
        sdetweil @kupperma
        @kupperma which kind of pi? if Pi 4/5 is the port on the left (closest to power) hdmi port?
        • K Offline
          kupperma
          This is an pi 3 Model B V1.2
          the HDMI is about 2 Centimeters right to the MicroUSB Power input.
          I updated to raspianOS bookworm first.
          Manfred
            sdetweil @kupperma
            @kupperma weird…
            do you have keyboard to pi system desktop?
            if so, ctrl-alt-t to open a terminal window and do
            echo $DISPLAY
            • K Offline
              kupperma
              Yes I have_
              Ok this does not work.
              So it seems to be raspianOS failure.
                sdetweil @kupperma
                @kupperma I ONLY use SSH to install MM… never use the actual display.
                have pi 0w, 02w, 3, 4,5 odroid, jetson nano, chromebox, chromebook,
                and multiple virtual machines under vmware
                NEVER seen npm run start say successful but not see it on screen…
                also, on the screen if u can,
                ctrl-c to stop the in ssh version
                on screen
                cd ~/Magicmirror
                npm start
                  sdetweil @kupperma
                  @kupperma said in New installation but even default is displayed:
                  what does not work?
                  • K Offline
                    kupperma
                    The display does not react to ctrl-alt-t and there is no terminal visible.
                      sdetweil @kupperma
                      @kupperma ok, on the menu bar there is a terminal window, click that
                      • K Offline
                        kupperma
                        I know what you mean:
                        in an earlier installation I could move the mouse and the menubar got visible or I could press F11 and the menubar got visible. But now nothing works.
                        So should I reinstall raspian and start from the beginning or is there a work a round?
                          sdetweil @kupperma
                          @kupperma can u reboot? does anything change? again weird…
                          did you have MM running before? what would you lose starting over?
                          IF you start over,
                          new flash
                          boot, skip updates,
                          reboot turn on ssh
                          then run my install script… it will update system, install node, then mm…
                          • K Offline
                            kupperma
                            I start over!
                            Thanks for the checklist.
                            I wont loose much for my custom.css , config.js I have the code copied in a textfile. The modules I would have to reinstall but thats ok.
                            Thank you for your time.
                            Manfred
                              sdetweil @kupperma
                              @kupperma run my backup/restore script… it saves all that and can be loaded up to github and versioned and restored from there
                              https://github.com/sdetweil/MagicMirror-backup-restore
                              it saves links to all the modules and restores from the links
                              • K Offline
                                kupperma @sdetweil
                                Thank you again.
                                MM2 is up and running.
                                  sdetweil @kupperma
                                  @kupperma awesome… thanks for the feedback
