    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 18.5k Views 5 Watching
    • karsten13K Offline
      karsten13 @sdetweil
      you are right, they “fixed” it in devDependencies instead in dependencies …
      then git pull is useless, you have to install the missing library in the module folder as sam already explained above
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @karsten13
        I created a PR to fix this, let’s see when @0m4r accept it.
        S 0m4r0 2 Replies Last reply Reply Quote 1
          sdetweil @KristjanESPERANTO
          @KristjanESPERANTO well, npm install would have installed the devDependencies too…
          KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 0
            @sdetweil Sure. But my PR removes node-fetch, so npm install is no longer necessary for this module.
              karsten13 @sdetweil
              This sentence clicked in my brain.
              I have NODE_ENV=production as default in my images (expect images I use for testing) and with this
              • npm install will install nothing
              • npm install node-fetch@2 will install nothing
              so @codac please go again in the folder of the module and run NODE_ENV=test npm install node-fetch@2
              this should hopefully solve the issue
                codac @codac
                @karsten13
                @codac said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
                root@04492d039b9f:/opt/magic_mirror/modules# cd MMM-SoccerLiveScore
                root@04492d039b9f:/opt/magic_mirror/modules/MMM-SoccerLiveScore# npm install node
                -fetch@2
                up to date, audited 1 package in 1s
                found 0 vulnerabilities
                How would I restart MM of the container?
                pm2 is not set up.
                DISPLAY=:0 npm restart
                …results in
                > magicmirror@2.26.0 restart
                > npm stop --if-present && npm start
                > magicmirror@2.26.0 start
                sh: 1: ./node_modules/.bin/electron: not found
                  codac @karsten13
                  @karsten13 said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
                  I could see that this time node-fetch got installed (different than before running npm install node-fetch@2 only).
                  But after restarting the docker container, the same error remained.
                    karsten13
                    did the same and it works, so no idea anymore
                      codac @karsten13
                      @karsten13 your are right… somehow the docker didn’t keep the installation after first try.
                      After installing it a second time and restarting the docker afterwards, the container kept the installation of node-fetch. Its working now.
                      Thank you guys for your massive support. Big time!
                      @karsten13, @sdetweil, @KristjanESPERANTO
                      • 0m4r0 Offline
                        0m4r Module Developer @KristjanESPERANTO
                        @KristjanESPERANTO thank you!
                        …and apologies for missing the whole discussion, I have updated my preferences to get e-mails when someone mentions me :)
                        https://github.com/0m4r
