    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 17.7k Views 5 Watching
      codac @sdetweil
      @sdetweil the node-fetch error
      • karsten13K Offline
        karsten13 @codac
        @codac
        if you are using https://github.com/0m4r/MMM-SoccerLiveScore the module contains the missing node-fetch so you should do a git pull in the module folder and try again (which means restart the container)
          sdetweil @karsten13
          @karsten13 did they fix the module? I didn’t check
            karsten13 @sdetweil
            you are right, they “fixed” it in devDependencies instead in dependencies …
            then git pull is useless, you have to install the missing library in the module folder as sam already explained above
            • KristjanESPERANTOK Offline
              KristjanESPERANTO Module Developer @karsten13
              I created a PR to fix this, let’s see when @0m4r accept it.
              S 0m4r0 2 Replies Last reply Reply Quote 1
                sdetweil @KristjanESPERANTO
                @KristjanESPERANTO well, npm install would have installed the devDependencies too…
                KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 0
                  @sdetweil Sure. But my PR removes node-fetch, so npm install is no longer necessary for this module.
                    karsten13 @sdetweil
                    This sentence clicked in my brain.
                    I have NODE_ENV=production as default in my images (expect images I use for testing) and with this
                    • npm install will install nothing
                    • npm install node-fetch@2 will install nothing
                    so @codac please go again in the folder of the module and run NODE_ENV=test npm install node-fetch@2
                    this should hopefully solve the issue
                      codac @codac
                      @karsten13
                      @codac said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
                      root@04492d039b9f:/opt/magic_mirror/modules# cd MMM-SoccerLiveScore
                      root@04492d039b9f:/opt/magic_mirror/modules/MMM-SoccerLiveScore# npm install node
                      -fetch@2
                      up to date, audited 1 package in 1s
                      found 0 vulnerabilities
                      How would I restart MM of the container?
                      pm2 is not set up.
                      DISPLAY=:0 npm restart
                      …results in
                      > magicmirror@2.26.0 restart
                      > npm stop --if-present && npm start
                      > magicmirror@2.26.0 start
                      sh: 1: ./node_modules/.bin/electron: not found
                        codac @karsten13
                        @karsten13 said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
                        I could see that this time node-fetch got installed (different than before running npm install node-fetch@2 only).
                        But after restarting the docker container, the same error remained.
                          karsten13
                          did the same and it works, so no idea anymore
                            codac @karsten13
                            @karsten13 your are right… somehow the docker didn’t keep the installation after first try.
                            After installing it a second time and restarting the docker afterwards, the container kept the installation of node-fetch. Its working now.
                            Thank you guys for your massive support. Big time!
                            @karsten13, @sdetweil, @KristjanESPERANTO
                            • 0m4r0 Offline
                              0m4r Module Developer @KristjanESPERANTO
                              @KristjanESPERANTO thank you!
                              …and apologies for missing the whole discussion, I have updated my preferences to get e-mails when someone mentions me :)
