    Cannot find module 'node-fetch' error with MMM-SoccerLiveScore
    34 Posts 5 Posters 18.6k Views 5 Watching
    • karsten13K Offline
      karsten13 @sdetweil
      and I think the electron error is just noise, as you must be running server only mode, whcih doesn’t use electron
      yes, there is no electron installed
        codac @karsten13
        @karsten13 well restarting / stopping / starting is no problem. But the error just remains and doesnt go away…
          sdetweil @codac
          @codac which error? the node-fetch or the lib error?
          (@karsten13 we installed electron, my mistake… in docker, doah! )
            codac @sdetweil
            @sdetweil the node-fetch error
              karsten13 @codac
              @codac
              if you are using https://github.com/0m4r/MMM-SoccerLiveScore the module contains the missing node-fetch so you should do a git pull in the module folder and try again (which means restart the container)
                sdetweil @karsten13
                @karsten13 did they fix the module? I didn’t check
                  karsten13 @sdetweil
                  you are right, they “fixed” it in devDependencies instead in dependencies …
                  then git pull is useless, you have to install the missing library in the module folder as sam already explained above
                  • KristjanESPERANTOK Offline
                    KristjanESPERANTO Module Developer @karsten13
                    I created a PR to fix this, let’s see when @0m4r accept it.
                    S 0m4r0 2 Replies Last reply Reply Quote 1
                      sdetweil @KristjanESPERANTO
                      @KristjanESPERANTO well, npm install would have installed the devDependencies too…
                      KristjanESPERANTOK karsten13K 2 Replies Last reply Reply Quote 0
                        @sdetweil Sure. But my PR removes node-fetch, so npm install is no longer necessary for this module.
                          karsten13 @sdetweil
                          This sentence clicked in my brain.
                          I have NODE_ENV=production as default in my images (expect images I use for testing) and with this
                          • npm install will install nothing
                          • npm install node-fetch@2 will install nothing
                          so @codac please go again in the folder of the module and run NODE_ENV=test npm install node-fetch@2
                          this should hopefully solve the issue
                            codac @codac
                            @karsten13
                            @codac said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
                            root@04492d039b9f:/opt/magic_mirror/modules# cd MMM-SoccerLiveScore
                            root@04492d039b9f:/opt/magic_mirror/modules/MMM-SoccerLiveScore# npm install node
                            -fetch@2
                            up to date, audited 1 package in 1s
                            found 0 vulnerabilities
                            How would I restart MM of the container?
                            pm2 is not set up.
                            DISPLAY=:0 npm restart
                            …results in
                            > magicmirror@2.26.0 restart
                            > npm stop --if-present && npm start
                            > magicmirror@2.26.0 start
                            sh: 1: ./node_modules/.bin/electron: not found
                              codac @karsten13
                              @karsten13 said in Cannot find module 'node-fetch' error with MMM-SoccerLiveScore:
                              I could see that this time node-fetch got installed (different than before running npm install node-fetch@2 only).
                              But after restarting the docker container, the same error remained.
                                karsten13
                                did the same and it works, so no idea anymore
                                  codac @karsten13
                                  @karsten13 your are right… somehow the docker didn’t keep the installation after first try.
                                  After installing it a second time and restarting the docker afterwards, the container kept the installation of node-fetch. Its working now.
                                  Thank you guys for your massive support. Big time!
                                  @karsten13, @sdetweil, @KristjanESPERANTO
                                  • 0m4r0 Offline
                                    0m4r Module Developer @KristjanESPERANTO
                                    @KristjanESPERANTO thank you!
                                    …and apologies for missing the whole discussion, I have updated my preferences to get e-mails when someone mentions me :)
