    birthdaylist
    module
    41 Posts 3 Posters 41.1k Views 3 Watching
      sdetweil @MyMirror
      @MyMirror currently the module is designed only to display the day. IN THE CURENT MONTH.
      let me think about this
        sdetweil @MyMirror
        @MyMirror ok, git pull again
        add
        withMonth: true,
        to the config parms…
        note that the image is 27px square, so the space for text is small…
        to fit, I made new css classes with a smaller font size when showing month
          MyMirror @sdetweil
          Excellent - 5 stars for you!
          Great job!
          Jens
            pulser
            thanks for this module, first of all.
            upcoming months are sorted correctly, but current month is on the bottom. how can we get current month on top?
              sdetweil @pulser
              @pulser I’ll look at it
                sdetweil @pulser
                @pulser do
                git pull
                in the module folder
                M P 3 Replies Last reply Reply Quote 0
                  MyMirror @sdetweil
                  Maybe other idea for “day/month”?
                  Possible?
                    sdetweil @MyMirror
                    @MyMirror not without some redesign.
                    the image we picked originally was only supposed to hold the day number
                    there is no up/down room, each line would have to get taller
                    and for US the month would have to come first…
                    so it gets harder and harder…
                    anyone that wants to try, fork the module and go for it…
                      pulser @sdetweil
                      work smoothly. thanks.
                        MyMirror @sdetweil
                        Hmm, but now something is wrong with the calculation of the age.
                        I have the following bdl.csv:
                        birth, name
                        08/01/1940,aaa 84
                        10/01/1963,bbb 61
                        15/01/1964,ccc 60
                        05/02/1964,Oliver 60
                        06/02/1974,Frank 50
                        and the result (made via my cell phone, as I can’t currently get the MagicMirror to start on my PC (mstsc)):
                        The birthdays from the coming month are now 1 year “too young”.
                          sdetweil @MyMirror
                          @MyMirror ok, will look. I didn’t change any of that, just sort
                            @MyMirror fixed… git pull in the module folder to update
                            I was only comparing the day of the month (as its the current month, right!!.. nope…!)
                            so if the bd month is > then the current month OR they are the same month but the bd DAY is > than today… show the projected age then …
                              MyMirror @sdetweil
                              Unfortunately not quite :disappointed_face:
                              Now the age from the current month is no longer correct
                              Same bdl.csv as above
                                sdetweil @MyMirror
                                @MyMirror git pull again… I made two changes… hoped I would update before you pulled… oops
                                  MyMirror @sdetweil
                                  Many thanks for the adjustments.
                                  Now it looks good.
                                  :thumbs_up_medium-light_skin_tone:
                                  • 2 / 3
