    birthdaylist
    module
    41 Posts 3 Posters 40.4k Views 3 Watching
      sdetweil @MyMirror
      @MyMirror I just pushed a change to display a message
      when no birthdays are found to display given the current settings
      I also added support to translate that message into the language set in the MM config…
      I provided files for english, french, german, italian and spanish
        MyMirror
        One more request/question:
        Could you add the month as a picture?
        If you set this option “currentMonthOnly: false” (which I find very good), then a month without an entry can lead to misunderstandings.
        Example:
        We have January and no entry for January in the bdl.csv.
        But on February 10.
        This would look like the next birthday is now on January 10, right?
        In this respect, is it possible to display the month as well?
        Jens
          sdetweil @MyMirror
          @MyMirror currently the module is designed only to display the day. IN THE CURENT MONTH.
          let me think about this
            sdetweil @MyMirror
            @MyMirror ok, git pull again
            add
            withMonth: true,
            to the config parms…
            note that the image is 27px square, so the space for text is small…
            to fit, I made new css classes with a smaller font size when showing month
              MyMirror @sdetweil
              Excellent - 5 stars for you!
              Great job!
              Jens
                pulser
                thanks for this module, first of all.
                upcoming months are sorted correctly, but current month is on the bottom. how can we get current month on top?
                  sdetweil @pulser
                  @pulser I’ll look at it
                    sdetweil @pulser
                    @pulser do
                    git pull
                    in the module folder
                    M P 3 Replies Last reply Reply Quote 0
                      MyMirror @sdetweil
                      Maybe other idea for “day/month”?
                      Possible?
                        sdetweil @MyMirror
                        @MyMirror not without some redesign.
                        the image we picked originally was only supposed to hold the day number
                        there is no up/down room, each line would have to get taller
                        and for US the month would have to come first…
                        so it gets harder and harder…
                        anyone that wants to try, fork the module and go for it…
                          pulser @sdetweil
                          work smoothly. thanks.
                            MyMirror @sdetweil
                            Hmm, but now something is wrong with the calculation of the age.
                            I have the following bdl.csv:
                            birth, name
                            08/01/1940,aaa 84
                            10/01/1963,bbb 61
                            15/01/1964,ccc 60
                            05/02/1964,Oliver 60
                            06/02/1974,Frank 50
                            and the result (made via my cell phone, as I can’t currently get the MagicMirror to start on my PC (mstsc)):
                            The birthdays from the coming month are now 1 year “too young”.
                              sdetweil @MyMirror
                              @MyMirror ok, will look. I didn’t change any of that, just sort
                                @MyMirror fixed… git pull in the module folder to update
                                I was only comparing the day of the month (as its the current month, right!!.. nope…!)
                                so if the bd month is > then the current month OR they are the same month but the bd DAY is > than today… show the projected age then …
                                  MyMirror @sdetweil
                                  Unfortunately not quite :disappointed_face:
                                  Now the age from the current month is no longer correct
                                  Same bdl.csv as above
                                    sdetweil @MyMirror
                                    @MyMirror git pull again… I made two changes… hoped I would update before you pulled… oops
                                      MyMirror @sdetweil
                                      Many thanks for the adjustments.
                                      Now it looks good.
                                      :thumbs_up_medium-light_skin_tone:
                                      • 2 / 3
