    birthdaylist
    module
    41 Posts 3 Posters 40.7k Views 3 Watching
      sdetweil @MyMirror
      @MyMirror you have to use the 3rd icon from the right above the editor to include images
        MyMirror @sdetweil
        Sorry :flushed_face:Birthday_screenshot_2.jpg
          sdetweil @MyMirror
          @MyMirror
          I see 4 entries, u have dimmEntries: false, so the bd on the dec 19th doesn’t show…
          did u change the csv?
            sdetweil @MyMirror
            @MyMirror I added Suzie to the new bdl.csv but it was part of the git pull …
            birth, name
            15/01/1987,suzie
            12/05/1951, Sam
              MyMirror @sdetweil
              No, i took your example after getting no output of mine.
              So the only changes are in the config regarding the currentMonthOnly and the max Entries.
              Hmmm :confused_face:
              S 2 Replies Last reply Reply Quote 1
                sdetweil @MyMirror
                @MyMirror can u edit the birthdaylist/data/bdl.csv
                  sdetweil @MyMirror
                  @MyMirror the sample file is in
                  DD/MM/YYYY format
                    MyMirror @sdetweil
                    Yes, of course.
                    What should i try?
                    Add this:
                    15/01/1987,suzie
                    12/05/1951, Sam
                      sdetweil @MyMirror
                      @MyMirror that second line shouldbe there already, do this
                      cd ~/MagicMirror/modules/birthdaylist
                      git checkout data/bdl.csv
                      then look at the file again
                      it should start like mine
                      suzie on the second line
                        MyMirror @sdetweil
                        my bdl.csv:
                        my output:
                        4 lines
                        M S 3 Replies Last reply Reply Quote 0
                          MyMirror @MyMirror
                          is a blank needed before “Suzie”?
                            sdetweil @MyMirror
                            @MyMirror correct
                            the bd on Dec 19th is in the past, and u have
                            dimmEntries: false
                            so, past BD’s are not dispplayed
                              sdetweil @MyMirror
                              @MyMirror said in birthdaylist:
                              no, I trim off blanks… allow for sloppy editing/pasting
                              all entries have to have the same date format
                                sdetweil @MyMirror
                                @MyMirror the csv file format is
                                the header row,
                                birth  ,  name
                                and then
                                rows for each person
                                birthday , name
                                the birthday format can be in whatever format you like
                                MM/DD/YYYY
                                DD/MM/YYYY
                                YYYY/DD/MM
                                YYYY/MM/DD
                                using whatever separator you choose
                                the layout and separator have to be the same for all birthday rows
                                  MyMirror @sdetweil
                                  OK, my mistake :worried_face:
                                  I misinterpreted currentMonthOnly: and assumed that all maxEntries would then be displayed (for more than 2 month).
                                  But with “false”, the current and the following month are displayed.
                                  Sorry for the trouble :flushed_face:
                                  (There was no entrie for January in my data file)
                                    sdetweil @MyMirror
                                    @MyMirror yes, I already had support for next month dec=>jan
                                    just sort was broken.
                                      sdetweil @MyMirror
                                      @MyMirror I just pushed a change to display a message
                                      when no birthdays are found to display given the current settings
                                      I also added support to translate that message into the language set in the MM config…
                                      I provided files for english, french, german, italian and spanish
                                        MyMirror
                                        One more request/question:
                                        Could you add the month as a picture?
                                        If you set this option “currentMonthOnly: false” (which I find very good), then a month without an entry can lead to misunderstandings.
                                        Example:
                                        We have January and no entry for January in the bdl.csv.
                                        But on February 10.
                                        This would look like the next birthday is now on January 10, right?
                                        In this respect, is it possible to display the month as well?
                                        Jens
                                          sdetweil @MyMirror
                                          @MyMirror currently the module is designed only to display the day. IN THE CURENT MONTH.
                                          let me think about this
                                            sdetweil @MyMirror
                                            @MyMirror ok, git pull again
                                            add
                                            withMonth: true,
                                            to the config parms…
                                            note that the image is 27px square, so the space for text is small…
                                            to fit, I made new css classes with a smaller font size when showing month
