    birthdaylist
    module
    41 Posts 3 Posters 40.7k Views 3 Watching
      sdetweil @MyMirror
      @MyMirror
      I see 4 entries, u have dimmEntries: false, so the bd on the dec 19th doesn’t show…
      did u change the csv?
        sdetweil @MyMirror
        @MyMirror I added Suzie to the new bdl.csv but it was part of the git pull …
        birth, name
        15/01/1987,suzie
        12/05/1951, Sam
          MyMirror @sdetweil
          No, i took your example after getting no output of mine.
          So the only changes are in the config regarding the currentMonthOnly and the max Entries.
          Hmmm :confused_face:
          S 2 Replies Last reply Reply Quote 1
            sdetweil @MyMirror
            @MyMirror can u edit the birthdaylist/data/bdl.csv
              sdetweil @MyMirror
              @MyMirror the sample file is in
              DD/MM/YYYY format
                MyMirror @sdetweil
                Yes, of course.
                What should i try?
                Add this:
                15/01/1987,suzie
                12/05/1951, Sam
                  sdetweil @MyMirror
                  @MyMirror that second line shouldbe there already, do this
                  cd ~/MagicMirror/modules/birthdaylist
                  git checkout data/bdl.csv
                  then look at the file again
                  it should start like mine
                  suzie on the second line
                    MyMirror @sdetweil
                    my bdl.csv:
                    my output:
                    4 lines
                    M S 3 Replies Last reply Reply Quote 0
                      MyMirror @MyMirror
                      is a blank needed before “Suzie”?
                        sdetweil @MyMirror
                        @MyMirror correct
                        the bd on Dec 19th is in the past, and u have
                        dimmEntries: false
                        so, past BD’s are not dispplayed
                          sdetweil @MyMirror
                          @MyMirror said in birthdaylist:
                          no, I trim off blanks… allow for sloppy editing/pasting
                          all entries have to have the same date format
                            sdetweil @MyMirror
                            @MyMirror the csv file format is
                            the header row,
                            birth  ,  name
                            and then
                            rows for each person
                            birthday , name
                            the birthday format can be in whatever format you like
                            MM/DD/YYYY
                            DD/MM/YYYY
                            YYYY/DD/MM
                            YYYY/MM/DD
                            using whatever separator you choose
                            the layout and separator have to be the same for all birthday rows
                              MyMirror @sdetweil
                              OK, my mistake :worried_face:
                              I misinterpreted currentMonthOnly: and assumed that all maxEntries would then be displayed (for more than 2 month).
                              But with “false”, the current and the following month are displayed.
                              Sorry for the trouble :flushed_face:
                              (There was no entrie for January in my data file)
                                sdetweil @MyMirror
                                @MyMirror yes, I already had support for next month dec=>jan
                                just sort was broken.
                                  sdetweil @MyMirror
                                  @MyMirror I just pushed a change to display a message
                                  when no birthdays are found to display given the current settings
                                  I also added support to translate that message into the language set in the MM config…
                                  I provided files for english, french, german, italian and spanish
                                    MyMirror
                                    One more request/question:
                                    Could you add the month as a picture?
                                    If you set this option “currentMonthOnly: false” (which I find very good), then a month without an entry can lead to misunderstandings.
                                    Example:
                                    We have January and no entry for January in the bdl.csv.
                                    But on February 10.
                                    This would look like the next birthday is now on January 10, right?
                                    In this respect, is it possible to display the month as well?
                                    Jens
                                      sdetweil @MyMirror
                                      @MyMirror currently the module is designed only to display the day. IN THE CURENT MONTH.
                                      let me think about this
                                        sdetweil @MyMirror
                                        @MyMirror ok, git pull again
                                        add
                                        withMonth: true,
                                        to the config parms…
                                        note that the image is 27px square, so the space for text is small…
                                        to fit, I made new css classes with a smaller font size when showing month
                                          MyMirror @sdetweil
                                          Excellent - 5 stars for you!
                                          Great job!
                                          Jens
                                            pulser
                                            thanks for this module, first of all.
                                            upcoming months are sorted correctly, but current month is on the bottom. how can we get current month on top?
