    birthdaylist
    module
    41 Posts 3 Posters 37.1k Views 3 Watching
      sdetweil @MyMirror
      @MyMirror I added Suzie to the new bdl.csv but it was part of the git pull …
      birth, name
      15/01/1987,suzie
      12/05/1951, Sam
        MyMirror @sdetweil
        No, i took your example after getting no output of mine.
        So the only changes are in the config regarding the currentMonthOnly and the max Entries.
        Hmmm :confused_face:
        S 2 Replies Last reply Reply Quote 1
          sdetweil @MyMirror
          @MyMirror can u edit the birthdaylist/data/bdl.csv
            sdetweil @MyMirror
            @MyMirror the sample file is in
            DD/MM/YYYY format
              MyMirror @sdetweil
              Yes, of course.
              What should i try?
              Add this:
              15/01/1987,suzie
              12/05/1951, Sam
                sdetweil @MyMirror
                @MyMirror that second line shouldbe there already, do this
                cd ~/MagicMirror/modules/birthdaylist
                git checkout data/bdl.csv
                then look at the file again
                it should start like mine
                suzie on the second line
                  MyMirror @sdetweil
                  my bdl.csv:
                  my output:
                  4 lines
                  M S 3 Replies Last reply Reply Quote 0
                    MyMirror @MyMirror
                    is a blank needed before “Suzie”?
                      sdetweil @MyMirror
                      @MyMirror correct
                      the bd on Dec 19th is in the past, and u have
                      dimmEntries: false
                      so, past BD’s are not dispplayed
                        sdetweil @MyMirror
                        @MyMirror said in birthdaylist:
                        no, I trim off blanks… allow for sloppy editing/pasting
                        all entries have to have the same date format
                          sdetweil @MyMirror
                          @MyMirror the csv file format is
                          the header row,
                          birth  ,  name
                          and then
                          rows for each person
                          birthday , name
                          the birthday format can be in whatever format you like
                          MM/DD/YYYY
                          DD/MM/YYYY
                          YYYY/DD/MM
                          YYYY/MM/DD
                          using whatever separator you choose
                          the layout and separator have to be the same for all birthday rows
                            MyMirror @sdetweil
                            OK, my mistake :worried_face:
                            I misinterpreted currentMonthOnly: and assumed that all maxEntries would then be displayed (for more than 2 month).
                            But with “false”, the current and the following month are displayed.
                            Sorry for the trouble :flushed_face:
                            (There was no entrie for January in my data file)
                              sdetweil @MyMirror
                              @MyMirror yes, I already had support for next month dec=>jan
                              just sort was broken.
                                sdetweil @MyMirror
                                @MyMirror I just pushed a change to display a message
                                when no birthdays are found to display given the current settings
                                I also added support to translate that message into the language set in the MM config…
                                I provided files for english, french, german, italian and spanish
                                  MyMirror
                                  One more request/question:
                                  Could you add the month as a picture?
                                  If you set this option “currentMonthOnly: false” (which I find very good), then a month without an entry can lead to misunderstandings.
                                  Example:
                                  We have January and no entry for January in the bdl.csv.
                                  But on February 10.
                                  This would look like the next birthday is now on January 10, right?
                                  In this respect, is it possible to display the month as well?
                                  Jens
                                    sdetweil @MyMirror
                                    @MyMirror currently the module is designed only to display the day. IN THE CURENT MONTH.
                                    let me think about this
                                      sdetweil @MyMirror
                                      @MyMirror ok, git pull again
                                      add
                                      withMonth: true,
                                      to the config parms…
                                      note that the image is 27px square, so the space for text is small…
                                      to fit, I made new css classes with a smaller font size when showing month
                                        MyMirror @sdetweil
                                        Excellent - 5 stars for you!
                                        Great job!
                                        Jens
                                          pulser
                                          thanks for this module, first of all.
                                          upcoming months are sorted correctly, but current month is on the bottom. how can we get current month on top?
                                            sdetweil @pulser
                                            @pulser I’ll look at it
                                            • 2 / 3
