Issues with MMM-PIR
22 Posts 7 Posters 11.3k Views 7 Watching
  • E Offline
    eyesallin
    Hi
    I’m completely new to this.
    I have a Pi 5 on Magicmirror.
    I installed MMM-Pir when ir runs the countdown but it displays 2 errors top of screen, pir has no effect countdown expires and turns of the screen.
    Unable to recover without rebooting
    Errors on screen :
    EINVAL: Invalid argument, write
    Command failed: /usr/bin/vcgencommand display_power
    S 1 Reply Last reply Jan 10, 2024, 7:17 PM Reply Quote 0
      diccon @bugsounet
      @bugsounet thank you changing to pir_mode 1 fixed the problem. Just for awareness I am running on a RPi 3 B+ Rev 1.3 hence why I didn’t do this sooner.
        sdetweil @eyesallin
        @eyesallin on pi5 by default you have to use mode 10, as Wayland is the display manager
        E 1 Reply Last reply Jan 10, 2024, 11:25 PM Reply Quote 0
        • E Offline
          eyesallin @sdetweil
          Many thanks I’ll give it a try. Will report back.
          E 1 Reply Last reply Jan 11, 2024, 8:36 AM Reply Quote 0
          • E Offline
            eyesallin @eyesallin
            @eyesallin
            50% unfortunately the top error is still there, any other help would be appreciated.
            EINVAL: Invalid argument, write.
            B 1 Reply Last reply Jan 15, 2024, 9:21 PM Reply Quote 0
              bugsounet Banned @eyesallin
              @eyesallin hi, eventually can I have the result of this commands in a terminal:
              groups
              thanks
              E 1 Reply Last reply Jan 16, 2024, 10:46 AM Reply Quote 0
              • E Offline
                eyesallin @bugsounet
                @bugsounet Apologies but I don’t understand what you are asking for?
                B 1 Reply Last reply Jan 16, 2024, 12:14 PM Reply Quote 0
                  @eyesallin
                  like that:
                  pi@raspberrypi:~ $ groups
                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi
                  pi@raspberrypi:~ $
                  I have to see if you are in gpio group :)
                  E 1 Reply Last reply Jan 17, 2024, 9:37 AM Reply Quote 0
                  • I Offline
                    ingo916
                    @bugsounet said in Issues with MMM-PIR:
                    groups
                    I am also getting the error
                    MMM-Pir
                    Error detected: EINVAL:invalid argument, write
                    pi@raspberrypi:~ $
                    I 2 Replies Last reply Jan 16, 2024, 6:02 PM Reply Quote 0
                    • I Offline
                      ingo916 @ingo916
                      @ingo916
                      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/bugsounet/MMM-Pir
                      Cloning into 'MMM-Pir'...
                      remote: Enumerating objects: 546, done.
                      remote: Counting objects: 100% (136/136), done.
                      remote: Compressing objects: 100% (111/111), done.
                      remote: Total 546 (delta 79), reused 47 (delta 24), pack-reused 410
                      Receiving objects: 100% (546/546), 287.37 KiB | 2.79 MiB/s, done.
                      Resolving deltas: 100% (308/308), done.
                      pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Pir/
                      pi@raspberrypi:~/MagicMirror/modules/MMM-Pir $ npm install
                      npm WARN deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
                      > MMM-Pir@1.1.2 preinstall
                      > installer/preinstall.sh -d 'unclutter cec-utils ddcutil build-essential'
                      Welcome to MMM-Pir v1.1.2
                      No root checking...
                      Checking MMM-Pir: pi/pi
                      Checking MagicMirror: pi/pi
                      Checking OS...
                      OS Detected: linux-gnu (debian 12 aarch64)
                      Checking all dependencies...
                      Updating package...
                      Missing package: unclutter
                      Missing package: cec-utils
                      Missing package: ddcutil
                      Installing missing package...
                      Hit:1 http://deb.debian.org/debian bookworm InRelease
                      Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                      Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                      Reading package lists... Done
                      Building dependency tree... Done
                      The following additional packages will be installed:
                        libcec6 libp8-platform2 unclutter-startup
                      The following NEW packages will be installed:
                        cec-utils ddcutil libcec6 libp8-platform2 unclutter unclutter-startup
                      0 upgraded, 6 newly installed, 0 to remove and 0 not upgraded.
                      Need to get 549 kB of archives.
                      After this operation, 2,084 kB of additional disk space will be used.
                      Get:1 http://deb.debian.org/debian bookworm/main arm64 libp8-platform2 arm64 2.1.0.1+dfsg1-4 [20.9 kB]
                      Get:2 http://deb.debian.org/debian bookworm/main arm64 ddcutil arm64 1.4.1-1 [286 kB]
                      Get:3 http://deb.debian.org/debian bookworm/main arm64 unclutter arm64 8-25 [15.6 kB]
                      Get:4 http://deb.debian.org/debian bookworm/main arm64 unclutter-startup all 8-25 [8,860 B]
                      Get:5 http://archive.raspberrypi.com/debian bookworm/main arm64 libcec6 arm64 6.0.2-5+rpt2 [188 kB]
                      Get:6 http://archive.raspberrypi.com/debian bookworm/main arm64 cec-utils arm64 6.0.2-5+rpt2 [30.0 kB]
                      Fetched 549 kB in 1s (469 kB/s)
                      Preconfiguring packages ...
                      Selecting previously unselected package libp8-platform2:arm64.
                      (Reading database ... 154590 files and directories currently installed.)
                      Preparing to unpack .../0-libp8-platform2_2.1.0.1+dfsg1-4_arm64.deb ...
                      Unpacking libp8-platform2:arm64 (2.1.0.1+dfsg1-4) ...
                      Selecting previously unselected package libcec6:arm64.
                      Preparing to unpack .../1-libcec6_6.0.2-5+rpt2_arm64.deb ...
                      Unpacking libcec6:arm64 (6.0.2-5+rpt2) ...
                      Selecting previously unselected package cec-utils.
                      Preparing to unpack .../2-cec-utils_6.0.2-5+rpt2_arm64.deb ...
                      Unpacking cec-utils (6.0.2-5+rpt2) ...
                      Selecting previously unselected package ddcutil.
                      Preparing to unpack .../3-ddcutil_1.4.1-1_arm64.deb ...
                      Unpacking ddcutil (1.4.1-1) ...
                      Selecting previously unselected package unclutter.
                      Preparing to unpack .../4-unclutter_8-25_arm64.deb ...
                      Unpacking unclutter (8-25) ...
                      Selecting previously unselected package unclutter-startup.
                      Preparing to unpack .../5-unclutter-startup_8-25_all.deb ...
                      Unpacking unclutter-startup (8-25) ...
                      Setting up libp8-platform2:arm64 (2.1.0.1+dfsg1-4) ...
                      Setting up unclutter (8-25) ...
                      update-alternatives: using /usr/bin/unclutter-classic to provide /usr/bin/unclutter (unclutter) in auto mode
                      Setting up libcec6:arm64 (6.0.2-5+rpt2) ...
                      Setting up unclutter-startup (8-25) ...
                      Setting up ddcutil (1.4.1-1) ...
                      Setting up cec-utils (6.0.2-5+rpt2) ...
                      Processing triggers for man-db (2.11.2-2) ...
                      Processing triggers for libc-bin (2.36-9+rpt2+deb12u3) ...
                      All Dependencies needed are installed !
                      Installing @sdetweil sandbox fix...
                      fixing sandbox permissions
                      > MMM-Pir@1.1.2 postinstall
                      > installer/postinstall.sh -r -m
                      Minify Main code...
                      Found: 8 files to minify
                      Process File: ../MMM-Pir.js
                      Process File: ../node_helper.js
                      Process File: ../components/screenLib.js
                      Process File: ../components/screenDisplayer.js
                      Process File: ../components/progressbar.js
                      Process File: ../components/pirLib.js
                      Process File: ../components/parseData.js
                      Process File: ../components/loadLibraries.js
                      Done
                      Try to Disable screen saver...
                      Found: screen saver in gsettings
                      gsettings screen saver already disabled
                      Found: screen saver in lightdm
                      screensaver via lightdm already disabled but need to be updated
                      Found: screen saver in lxsession
                      lxsession screen saver already disabled but need to updated
                      Found: screen saver in wayland
                      disable screensaver via wayfire.ini
                      [WARN] There is some change for disable screen saver
                      [WARN] Please, don't forget to reboot your OS for apply the new configuration!
                      Done
                      Rebuild MagicMirror...
                      make: Entering directory '/home/pi/MagicMirror/modules/MMM-Pir/node_modules/epoll/build'
                        CXX(target) Release/obj.target/epoll/src/epoll.o
                        SOLINK_MODULE(target) Release/obj.target/epoll.node
                        COPY Release/epoll.node
                      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Pir/node_modules/epoll/build'
                      Done
                      MMM-Pir is now installed !
                      added 218 packages in 53s
                      43 packages are looking for funding
                        run `npm fund` for details
                      • I Offline
                        ingo916 @ingo916
                        @ingo916
                        Config
                        			module: 'MMM-Pir',
                        			position: 'top_left',
                        				debug: false,
                        				delay: 2 * 60 * 1000,
                        				turnOffDisplay: true,
                        				mode: 10,
                        				ecoMode: true,
                        				displayCounter: false,
                        				//displayCounter: true,
                        				displayBar: false,
                        				//displayBar: true,
                        				displayStyle: "Circle",
                        				displayLastPresence: false,
                        				//displayLastPresence: true,
                        				lastPresenceTimeFormat: "LL H:mm",
                        				mode6_gpio: 20,
                        				mode6_clearGpioValue: true,
                        				pir_gpio: 22,
                        				//pir_gpio: 21,
                        				pir_reverseValue: false,
                        				xrandrForceRotation: "normal",
                        				wrandrForceRotation: "normal"
