    Displaying two calendars in the standard calendar in one list
    9 Posts 4 Posters 1.9k Views 4 Watching
    • K Offline
      Klinge
      I would like to display two Google calendars in the default calendar. However, both calendar should be displayed in one list on the mirror.
      I try to realize it with the following config
                              header: "Termine",
                                      timeFormat: 'absolute',
                                      maximumEntries: 10,
                                      dateFormat: 'ddd DD MMM HH:mm',
                                      fullDayEventDateFormat: 'ddd DD MMM',
                                      showEnd: false,
                                      urgency: 0,
                                      getRelative: 0,
                                                      symbol: "calendar-check",
                                                      url: "https://calendar.google.com/calendar/ical/******/basic.ics"
      But when the MMM starts the module first shows the first configured URL and a few seconds later the module only shows the appointments from the second URL.
      But as I wrote I need the entries from both calendars in one list.
      Please can you help me.
      Thank you in advance.
      Lars
      B L 2 Replies Last reply Reply Quote 0
        bdream @Klinge
        @Klinge I have a configuration as you but the fetchInterval:
        May it help butting this up to the config-part as:
        cheers, bdream
        • L Offline
          lif @Klinge
          @Klinge
          I use this to display 3 calendars in the same column
          module: “calendar”,
          header: “Our Calendar”,
          position: “top_left”,
          symbol: “calendar-check”,
          url: ‘https://calendar.google.com/calendar/ical/en.uk%23holiday%40group.v.calendar.google.com/public/basic.ics’,
          color: ‘#FFFF00’,
          symbol: “calendar”,
          url: ‘https://calendar.google.com/calendar/ical/fr.french%23holiday%40group.v.calendar.google.com/public/basic.ics’,
          color: ‘#00FF00’,
          symbol: “calendar”,
          url: ‘https://calendar.google.com/calendar/ical/xxxx%40gmail.com/private-xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/basic.ics’,
          • K Offline
            Klinge @bdream
            @bdream Thank you for you answer. Now I delete the second fetch line. So my config is
                                    header: "Termine",
                                            maximumEntries: 10,
                                            showEnd: false,
                                            urgency: 0,
                                            getRelative: 0,
            But now it’s getting really crazy. The mirror shows me an appointment at 12.20pm today as the first entry. That’s also correct. But after that it only shows me from both calendars all-day appointments. It no longer shows appointments that start at a certain time, for example at 1 pm.
            Why are only all-day appointments displayed?
              sdetweil @Klinge
              @Klinge fall back to the prior calendar parser
              npm install node-ical@0.16.1
              restart mm
              your config looks ok
              K 1 Reply Last reply Reply Quote 1
              • K Offline
                Klinge @sdetweil
                @sdetweil That´s it. Now it works. Thank you for your help again.
                @bdream @lif Thank you for your support as well.
                • L Offline
                  lif @Klinge
                  @Klinge
                  I typed too soon, just after I posted that I applied a MagicMirror upgrade, now it doesn’t display my personal calendar.
                  S L 2 Replies Last reply Reply Quote 0
                    sdetweil @lif
                    @lif can you do this
                    https://forum.magicmirror.builders/post/114622
                    • L Offline
                      lif @lif
                      @lif
                      Thanks, that worked.
