    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil I try to move forward on the folder, I changed the destination folder for the “current” part by directing to a folder in css/icons/animated, but nothing changes, the supported icon is that of css/icons, red square (which keeps the properties, size, positioning of weather) I have the impression that “css/icons/animated” is not supported, green square, I think I am not far from the solution, but without your help I don’t think I’ll get there
        Manu85 @sdetweil
        @sdetweil Thanks to you, I finally managed to configure the weather module with animated icons, I finally understood the advantages and the settings possible with the console (ctrl+shift+i) it also allowed me to make other settings on other modules, it’s been 5 years since I did this MM and I learned more with you in 3 days than in 5 years, a big thank you for your help
          sdetweil @Manu85
          @Manu85 awesome!! glad you got it.
          that dev window is amazing for what you can discover and try
          M 1 Reply Last reply
            manu85340 @sdetweil
            I will actually look precisely at the possibilities of this window, a thousand thanks Sam
              sdetweil @manu85340
              @manu85340 the top right window allows you to set styles on the selected element
              any style supported by the browser… color, font, icon, padding, border, you name it…
              so, you can test out the effect you want and then copy/paste those to the entry for custom.css
              one other learning thing…
              in css
              the stuff before the {
              is called the selector clause… it ‘selects’ the elements that that the stuff INSIDE the {} will apply to…
              the selector clause will ALWAYS select ALL elements that match , ALWAYS ALL
              but you can make it very selective…, it can be quite complex…
              here I want to hide (display :none) an element generated by a library I used
              that didn’t apply to the output it generated
              .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item%201"] {
                display: none;
              I use this page to help me with the selector clause possibilities and syntax
              https://www.w3schools.com/cssref/css_selectors.php
              sometimes it helps to look at the selector clause from right to left , what element is it, and how does it fit in the content its in.
              this selector clause is trying to find an <a (action/link) element with a title of “Item 1”
                Manu85 @sdetweil
                @sdetweil It’s really nice of you to share all these elements, I’m going to look at it while taking my time, I feel like the possibilities are endless
                  sdetweil @Manu85
                  @Manu85 no rush… just wanted to give you some base info to use as you explore.
                  also from the MM doc on css
                  https://docs.magicmirror.builders/modules/customcss.html#target-a-specific-module
                  target and select mean the same
                    Manu85 @sdetweil
                    @sdetweil :folded_hands:
                      sdetweil @Manu85
                      @Manu85 oh, and html stuff is a lot to know… (I think I know maybe 5%)
                      https://www.w3schools.com/html/
                      that top box in the developers window elements tab will start dropdowns of selection choices when u start typing
                        Manu85 @sdetweil
                        you made me want to do a lot of things, but I think I’m going to be limited very quickly… I have the “MMM-ISS-Live” module, from [Mykle1](https://github.com/ Mykle1), updated by KristjanESPERANTO https://github.com/KristjanESPERANTO/MMM-ISS-Live which is really great (force to them) and I would like to know if it was possible to add a module with the position of the 'ISS on the planisphere to have the position of the ISS live as on the ESA website: https://www.esa.int/Science_Exploration/Human_and_Robotic_Exploration/International_Space_Station/Where_is_the_International_Space_Station
                        I don’t know if I’m posting on the right subject but it’s a development that could interest a lot of people
                        code_text
                          sdetweil @Manu85
                          @Manu85 is it possible… sure…
                          and as that image is already an iframe you can do the same thing with existing modules
                          the web content of that page contains(using the dev window to look at the html source of that page)
                          <p>&nbsp;</p><iframe src="https://isstracker.spaceflight.esa.int/" width="625" height="350" frameborder="0" scrolling="no" allowfullscreen></iframe>
                          SO, you can use one of the iframe modules… to use that same link from the src=
                          see the 3rd party module list
                          https://github.com/MagicMirrorOrg/MagicMirror/wiki/3rd-Party-Modules
                          M 2 Replies Last reply
                            Manu85 @sdetweil
                            @sdetweil you are a genius, how did you manage to recover the ifram
                            “https://isstracker.spaceflight.esa.int/”?
                              sdetweil @Manu85
                              @Manu85 I viewed the page, then right clicked and selected ‘View Page Source’
                              which got me this (I have scrolled down a little)
                              and you can look at the real page and see the text and follow along to find the spot where the image would be… and boom, its in an iframe
                              and then copy the url out…
                                Manu85 @sdetweil
                                @sdetweil I think I started to understand, like that?
                                  sdetweil @Manu85
                                  @Manu85 using the dev window is another way, yes
                                  and if you had used the pointer to hover over the image, it would have taken you directly to that part of the html content
                                    Manu85 @sdetweil
                                    @sdetweil This means that by using existing modules I can change some properties to adapt them to my needs, for example if I use the ISS live module if I change the address in the module’s js can it work?
                                    S 2 Replies Last reply
                                      sdetweil @Manu85
                                      @Manu85 existing modules like MMM-SmartWebDisplay take the URL as a config option . no coding required
                                        sdetweil @Manu85
                                        @Manu85 I don’t think the ISS-live module can do that, as it calls an api to get the images
                                          Manu85 @sdetweil
                                          @sdetweil ah ok I will try, you are my master
                                            sdetweil @Manu85
                                            @Manu85 there are other modules too… (note that you can push the iframe right up against the ISS-live output, so they LOOK like they are together…) a little css borders and padding… maybe other stuff…
                                            • 15
                                            • 16
                                            • 7 / 16
