    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 here is the module config I used
      I took the size from the original web page
      		module: 'MMM-SmartWebDisplay',
      		position: 'middle_center',	// This can be any of the regions.
      			logDebug: false, //set to true to get detailed debug logs. To see them : "Ctrl+Shift+i"
      			height:"350px", //hauteur du cadre en pixel ou %
      			width:"650px", //largeur
                     		updateInterval: 0, //in min. Set it to 0 for no refresh (for videos)
                      	NextURLInterval: 0.5, //in min, set it to 0 not to have automatic URL change. If only 1 URL given, it will be updated
                      	displayLastUpdate: true, //to display the last update of the URL
      					displayLastUpdateFormat: 'ddd - HH:mm:ss', //format of the date and time to display
                      	url: ["https://isstracker.spaceflight.esa.int/"], //source of the URL to be displayed
      					scrolling: "no", // allow scrolling or not. html 4 only
      					shutoffDelay: 10000 //delay in miliseconds to video shut-off while using together with MMM-PIR-Sensor
      I didn’t change anything other than size and url
      there could be other settings needed…
      M 3 Replies Last reply Reply Quote 0
        Manu85 @sdetweil
        @sdetweil I did like you I see the image clearly on the MM, but it disappears every 3 seconds then recharges continuously, the green LED of the raspberry is lit very often, as if the module required a lot of resources from the pi
          Manu85 @sdetweil
          @sdetweil I found, you have to set this setting to “0”, otherwise it reloads every 30 seconds
          NextURLInterval: 0,
            Manu85 @sdetweil
            @sdetweil Hello Sam, I still need your help, I saw KristjanESPERANTO’s module: MMM-OneCallWeather which I really like, so I installed this module I copied his example from js.config which I have completed with my elements longitude, latitude apy key, I tested my api key on the internet in version 2.5 and it works, so I changed the version in MMM-OneCallWeather.js, as Kristjan explains in the github, and when I restart the MM it notifies loading and nothing happens, I tried to understand, but I’m stuck, so I call a specialist :-)
              sdetweil @Manu85
              @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
              -OneCall
              OneCall requires the v3 key and api as I understand it…
              M M 3 Replies Last reply Reply Quote 0
                Manu85 @sdetweil
                @sdetweil In detail he says this:
                (apiVersion The OpenWeatherMap API version to use. Change it to “2.5” if you have an old apikey
                Default value: 3.0)
                I understood that if we had an old version then we had to change this parameter but I may have misinterpreted
                  Manu85 @sdetweil
                  @sdetweil when I connect to an internet page it gives me this, so I think it’s active, I entered lat, long and api key
                    sdetweil @Manu85
                    @Manu85 as far as I can tell, the one call API with keys since mid 2023 is only available via the v3.0 apikey setting
                      Manu85 @sdetweil
                      @sdetweil So it pays?
                        Manu85 @sdetweil
                        @sdetweil on my weather module I have an api key 2.5, I don’t know if that’s it but I have the impression that the weather data is wrong. Do you know of a weather module for the MM with current and forecast that would be graphically nice and free? because if to have version 3.0 you have to pay that doesn’t interest me, thank you for your help
                          sdetweil @Manu85
                          @Manu85 in the console (where u start magicmirror, npm start )
                          you might see
                          [23.01.2024 12:12.22.384] [LOG]   [MMM-OneCallWeather] 23-Jan-24 12:12 ** ERROR ** Error: Unauthorized
                          if you are using the wrong api key
                            sdetweil @Manu85
                            @Manu85 the page says v3 api, and 1000 calls per day free
                              Manu85 @sdetweil
                              @sdetweil Yes I went to this page, but then they ask you for your bank card!!!
                                sdetweil @Manu85
                                @Manu85 yes, they will charge you IF you go over the 1000/day… nothing is free anymore… you MUST provide a valid card, or the api key is not functional
                                  Manu85 @sdetweil
                                  @sdetweil Thank you for your answer and you are right everything is charged today, fortunately there are still sites and people like you to share for FREE what they know
                                    sdetweil @Manu85
                                    @Manu85 yes, but I don’t generate any pretty user interfaces!! no icons or graphs…lol
                                      Manu85 @sdetweil
                                      @sdetweil Yes but it’s thanks to people like you that there is still communication without banking intermediary to build projects… I would therefore stay with my version 2.5 which is free while waiting for a developer to find a solution:- ) what bothers me is that the weather forecast with pretty icons etc. there are some on smartphones, cars, television, internet etc. and all this is free, as soon as you want to do something different you have to PAY :-(
                                        sdetweil @Manu85
                                        the problem is that the provider (openweathermap), is only providing v3 api keys now for the OneCall api used by the module.
                                        SO… there is nothing the developer can do to get around that.
                                        openweathermap is no longer issuing 2.5 api keys
                                          manu85340 @sdetweil
                                          @sdetweil I found a post from March 2023 where we talk about you on the same subject 😉
                                            sdetweil @manu85340
                                            @manu85340 yes, this module is already using all that
                                                apiVersion: "3.0",
                                             `https://api.openweathermap.org/data/${config.apiVersion}/onecall` +
                                            • 10
                                            • 15
                                            • 16
                                            • 8 / 16
