    Calendar shows incorrect time for a single changed event in a series
    9 Posts 4 Posters 1.7k Views 4 Watching
    • KristjanESPERANTOK Offline
      @sdetweil Just out of curiosity: Is the library moment.js?
        sdetweil @KristjanESPERANTO
        @KristjanESPERANTO no, rrule
        it expects only local date/times
        node-ical converts all to utc based times…
        so we get some events that have todays date with tomorrows UTC time… Nov 6 -01:30 UTC -8
        for LosAngeles that makes the event date yesterday… Nov 5- 17:30… oops…
        but we in MM don’t ever look at the text in the ICS, so we have NO way of knowing of the mishmash date/time… and it seems to happen MOST with ByDay (only on thrusday or friday) …
        AND EVEN if we DID look at the ICS, we wouldn’t see this, as its a recurring date event, calculated by RRULE. from start and the rules… so unless WE recode RRULE, we would never ever know
          sdetweil @Hinge
          @Hinge @KristjanESPERANTO node-ical has just release a new version (0.17.0) which removes the luxon library which causes all the localdate/time issues…
          want to give it a try ? do
          npm install node-ical@latest
          then start mm as usual
          • G Offline
            gelaw @sdetweil
            @sdetweil said in Calendar shows incorrect time for a single changed event in a series:
            I have the same problem.
            Did this fix work?
              sdetweil @gelaw
              @gelaw do
               npm install node-ical@0.16.1
              • G Offline
                gelaw @sdetweil
                @sdetweil Thanks!
                This worked in my first tests. Is this now the official version? or still in work?
                  sdetweil @gelaw
                  @gelaw this is the version from prior release…
                  we’ll see what happens by April 1.(next mm release)
