    Default Weather Module Icon Position
    38 Posts 4 Posters 18.3k Views 4 Watching
      svenpisa @sdetweil
      I have reset the weather.css again. Fits so far.
      I think I have also understood the module and classes.
      So if I have the following
      			module: "weather",
      			classes: "forecast",
      then I would have to enter it in the custom.css as follows?
      .weather .forecast
      Unfortunately, I have not yet understood how to access it via browser.
      Exactly! The MM should hang on the wall, but if I want to make changes, I want to access the Raspi / MM via WLAN and make the changes via my laptop and since I am not a programmer and like to have everything visually, I would like to mirror the MM or the OS on my laptop screen and preferably make the changes via the “Geany” tool.
      How exactly should I enter it in the browser?
      I have tried it with IP and port, but only get an error message. I have also tried with the WLAN IP and port, but also without success.
      	address: "0.0.0.0",
      	port: 8080,
      Thanks in advance
      S 3 Replies Last reply
        sdetweil @svenpisa
        @svenpisa said in Default Weather Module Icon Position:
        .weather .forecast
        no… just
        .forecast
        that overrides .weather
          sdetweil @svenpisa
          address: “0.0.0.0”,
          port: 8080,
          ok, and ipWhitelist:[], too, right?? this restricts incoming request to JUST the addresses listed… by default this was JUST the loopback address (localhost), again ONLY inside this machine…
          so, the first two mean,
          listen for incoming connections on all network interfaces (image ethernet and wifi active, you can restrict to just one by using the actual ip address assigned, OR allow connections on BOTH without having to know the assigned addresses)…
          and the the port 8080…
          you used remote connection to the PI… use the same address in the browser
          http://pi_ip_address(or name):8080
          on my current mac connecting to raspberry pi 5
          I can use
          http://raspberrypi5:8080
          or
          http://192.168.12.121:8080
            sdetweil @svenpisa
            i strongly recommend installing Winscp or Bitvise ssh clients on your windows machine. (both free)
            these will give you BOTH the ssh window (for commands, installing updates and modules) AND a file manager window over the PI files (for editing files). Then you can double click to edit ON YOUR PC, with your PC EDITOR, and auto save back to the pi…
            bitvise ALSO provides a window for drag/drop to copy files in either direction
            great for copying log files from the pi…
            i use notepad++ on my windows machine for editing but you can use visual studio code or whatever text editor you like… they don’t know the file is over ssh…
            I NEVER edit ON the pi itself… only over ssh, and use one of the visual tools when I need to …
              svenpisa @sdetweil
              Thanks @sdetweil
              It works… Was my mistake… i took a / instead of : between ip and port…
              Looks great now.
              Last question for that… Have you got a link for a tutorial how to use the developer mode?
                svenpisa @sdetweil
                @sdetweil i installed Bitvise now. The first view looks good… i will try it the next days!
                  sdetweil @svenpisa
                  @svenpisa learn developers window
                  see
                  https://forum.magicmirror.builders/post/90135
                  and a little here
                  https://forum.magicmirror.builders/topic/7227/changing-icons-of-the-modules-current-weather-and-weather-forecast/290?_=1707252488912
                  • Z
                    ZiggidyZ
                    Personally I use putty and do everything over command line. On my PC I use Notepad++ for working on files as well, then will copy and paste over to the ssh session.
                      sdetweil @ZiggidyZ
                      @ZiggidyZ yeh, I used to do that too.
                      then I have 10 systems I work on, got to be too much copying.
                        svenpisa
                        Thank you guys for your tips and help. Now I only have one issue left.
                        How do I get the icons in the right place?
                          sdetweil @svenpisa
                          @svenpisa I don’t understand. you have mmm-wallpaoer selected, but weather icons in class list
                            svenpisa @sdetweil
                            @sdetweil I had taken the section to see the Custom.css and weather.css on the right side. Shouldn’t the wallpaper actually be displayed?
                              sdetweil @svenpisa
                              @svenpisa as I said, confused.
                              in custom.css do
                              html {
                                 cursor: default;
                              to turn on the mouse pointer over the mm content
                              then easier to see to select correct content
                                svenpisa @sdetweil
                                @sdetweil said in Default Weather Module Icon Position:
                                html {
                                cursor: default;
                                Is the screenshot better?
                                  sdetweil @svenpisa
                                  @svenpisa yes, better.
                                  so that stuff for .weathericon from custom.css, I would click off each and see the effect.
                                  as you mouse over the settings in the right column a checkbox will appear, that u can check to disable a setting
                                  note .weather-icon applies to ALL of the icons.
                                  the css selector clause (stuff before the {) WILL ALWAYS match every such item on the page. you can make it more specific to get fewer elements.
                                    svenpisa
                                    Thank you very much for your help.
                                    I first had to read through your messages at my leisure and at the same time I tried to understand the messages parallel to the developer tool.
                                    And lo and behold, it worked.
                                    I have now split the weather module into two classes.
                                    			module: "weather",
                                    			header: "Wettervorschau",
                                    				type: "forecast",
                                    				locationID: "2911xxx", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                    				apiKey: "c64bb3321848fe4e76163xxxxxxxxxc"
                                    			module: "weather",
                                    			classes: "wetter",
                                    			position: "top_center",
                                    				type: "current",
                                    				apiKey: "c64bb3321848fe4e76163xxxxxxxxx"
                                    You could then play around really well with each class in the developer tool and then find the right position.
                                    For those who are interested. I have now made the following entries in the Custom.css so that it looks like this:
                                    .forecast .weathericon {
                                    position:absolute;	// absolute
                                    z-index: 0;
                                    height: 200px;
                                    right: 120px;
                                    margin-top: -65px;
                                    padding-left: 60px;
                                    padding-top: 50px;
                                    height: 35px;
                                    .forecast .wi-day-sunny {
                                    content: url("/css/icons/day.svg");
                                    .forecast .wi-day-cloudy {
                                    content: url("/css/icons/cloudy-day-1.svg");
                                    .forecast .wi-rain {
                                    content: url("/css/icons/rainy-6.svg");
                                    forecast .wi-night-clear {
                                    content: url("/css/icons/night.svg");
                                    .forecast .wi-night-cloudy {
                                    content: url("/css/icons/cloudy-night-2.svg");
                                    padding-right: 15px;
                                    padding-top: 10px;
                                    .forecast .wi-cloudy {
                                    content: url("/css/icons/cloudy.svg");
                                    .forecast .wi-showers {
                                    content: url("/css/icons/rainy-7.svg");
                                    .forecast .wi-thunderstorm {
                                    content: url("/css/icons/thunder.svg");
                                    .forecast .wi-snow {
                                    content: url("/css/icons/snowy-6.svg");
                                    .forecast .wi-cloudy-windy {
                                    content: url("/css/icons/cloudy-day-3.svg");
                                    .forescast.wi-night-rain {
                                    .forecast .wi-night-snow {
                                    .forecast .wi-night-thunderstorm {
                                    .forecast .wi-night-showers {
                                    .forecast .wi-fog {
                                    .forecast .wi-night-alt-cloudy-windy {
                                    content: url("/css/icons/cloudy-night-1.svg");
                                    /* Aenderungen Wettervorhersage */
                                    .wetter .weathericon {
                                    position: absolute;
                                    z-index: 1;
                                    margin-top: -33px;
                                    padding-top: 20px;
                                    left: 60px;
                                    .wetter .wi-day-sunny {
                                    padding-left: 6px;
                                    padding-top: 5px;
                                    height: 50px;
                                    .wetter .wi-day-cloudy {
                                    .wetter .wi-rain {
                                    padding-left: 8px;
                                    padding-top: 5px;
                                    height: 45px;
                                    .wetter .wi-night-clear {
                                    .wetter .wi-night-cloudy {
                                    height: 50px;
                                    padding-left: 5px;
                                    padding-top: 7px;
                                    .wetter .wi-cloudy {
                                    .wetter .wi-showers {
                                    .wetter .wi-thunderstorm {
                                    .wetter .wi-snow {
                                    .wetter .wi-cloudy-windy {
                                    height: 45px;
                                    padding-left: 8px;
                                    padding-top: 7px;
                                    .wetter .wi-night-rain {
                                    padding-left: 8px;
                                    padding-top: 5px;
                                    height: 45px;
                                    .wetter .wi-night-snow {
                                    .wetter .wi-night-thunderstorm {
                                    .wetter .wi-night-showers {
                                    .wetter .wi-fog {
                                    .wetter .wi-night-alt-cloudy-windy {
                                    height: 50px;
                                    padding-left: 5px;
                                    padding-top: 7px;
                                    We can therefore close the entry here
                                    Thanks all again
                                      sdetweil @svenpisa
                                      @svenpisa awesome! thanks for the feedback.
                                      • G
                                        greedyvegan
                                        I have this issue too, the dev window says they’re the same class
                                        but the classes are already different/labeled as forecast and weather in config
                                        when I open everything in the developer window,
                                        this is the one that highlights the icon I want to move “</span> == $0”
                                        the current weather “sun” icon in the top module is the one I want to move,
                                        but its labeled as the current weather condition, NOT the icon I want to move
                                        when I uncheck the one I need, both icons from current weather and “today” from forecast both change
                                        it’s labeled as “weather weather” , when I change that, they both change (current weather and forecast)
                                        what am I doing wrong?
                                        • G
                                          greedyvegan
                                          (currently reading)
                                          https://forum.magicmirror.builders/topic/6808/css-101-getting-started-with-css-and-understanding-how-css-works?_=1602611995137
                                            sdetweil @greedyvegan
                                            @greedyvegan yes, they are the same, that is why you need to add unique classes per my previous post, OR use the id value in custom css as the primary selector
                                            #module_{number}_module-name
                                            G 2 Replies Last reply
