Solved MMM-GoogleKeep config.js
@KristjanESPERANTO Thank you very much. Do I understand correctly that I may only have to wait until the module works or do I have to make additional settings? Can I see the status somewhere when it should work again?
@svenpisa well I can fix most install problems.
I haven’t looked at the code in detail, but that could be possible, yes. Of course, it may still be the case that something needs to be adjusted in gkeepapi and/or MMM-GoogleKeep.
The best thing would probably be to look at alternatives.
If a gpsoauth version newer than 1.0.4 appears here, we can try again. You can also follow this discussion: https://github.com/kiwiz/gkeepapi/issues/81.
Hi @KristjanESPERANTO I have seen that something has happened in the issue. But I didn’t understand what was changed and what was adjusted. May I come back to your help? If you have time, could you take a look at the issue on GitHub?
Thank you very much and best regards -
I still can’t see a new version of gpsoauth or gkeepapi. In the issue they seem only talking about a workaround.
@KristjanESPERANTO ah ok, then I took it the wrong way. Sorry and thanks
