    MMM-GoogleKeep config.js
    18 Posts 3 Posters 8.1k Views 3 Watching
      svenpisa @sdetweil
      @sdetweil You’re great… Thank you very much
      Partly good news.
      It could now be installed and entered in config.js. MM also starts cleanly and is also displayed cleanly, but the KEEP module is unfortunately not displayed on the MM.
      Now I need to get the list displayed somehow.
      I have tried it with the APP password 16 digits as well as 4x4 digits and also with the Google password but unfortunately it is not displayed.
      Any more ideas?
        sdetweil @svenpisa
        @svenpisa sorry, don’t know the internals of the module
        S KristjanESPERANTOK 2 Replies Last reply
          svenpisa @sdetweil
          @sdetweil What? I thought you were the God Father of Magic Mirror Modules!!! ;-)
          No problem, maybe there is someone who has used this module before and it works for him to tell me what to do… I would be very happy anyway!!!
          • KristjanESPERANTOK
            I have tried to get the module to run, but have also failed. It seems to me that there is a problem with gkeepapi. A simple query with gkeepapi already fails.
            There seems to be a workaround with docker (see https://github.com/kiwiz/gkeepapi/issues/81), but I didn’t tested that. In the issue discussion the maintainer of gkeepapi mentioned waiting for a new release of gpsoauth. Then MMM-GoogleKeep might work again without any tinkering 🙂
              svenpisa @KristjanESPERANTO
              @KristjanESPERANTO Thank you very much. Do I understand correctly that I may only have to wait until the module works or do I have to make additional settings? Can I see the status somewhere when it should work again?
              KristjanESPERANTOK 1 Reply Last reply
                sdetweil @svenpisa
                @svenpisa well I can fix most install problems.
                  KristjanESPERANTO Module Developer @svenpisa
                  I haven’t looked at the code in detail, but that could be possible, yes. Of course, it may still be the case that something needs to be adjusted in gkeepapi and/or MMM-GoogleKeep.
                  The best thing would probably be to look at alternatives.
                  If a gpsoauth version newer than 1.0.4 appears here, we can try again. You can also follow this discussion: https://github.com/kiwiz/gkeepapi/issues/81.
                    Hi @KristjanESPERANTO I have seen that something has happened in the issue. But I didn’t understand what was changed and what was adjusted. May I come back to your help? If you have time, could you take a look at the issue on GitHub?
                    Thank you very much and best regards
                      I still can’t see a new version of gpsoauth or gkeepapi. In the issue they seem only talking about a workaround.
                        @KristjanESPERANTO ah ok, then I took it the wrong way. Sorry and thanks
