    MMM-GoogleKeep config.js
    18 Posts 3 Posters 7.0k Views 3 Watching
      sdetweil @svenpisa
      @svenpisa please check the messages where u do npm start
      if you use pm2 then do pm2 logs --lines=50
      or
      pm2 stop all
      npm start
      if you are running on the same screen as mm, then press ctrl-q, look at the messages
        svenpisa
        Hi Sam,
        Here is the error excerpt. The error definitely occurs with KEEP but no idea what to do…
        magicmirror@2.25.0 start
        [25.01.2024 19:42.13.949] [LOG] Starting MagicMirror: v2.25.0
        [25.01.2024 19:42.13.959] [LOG] Loading config …
        [25.01.2024 19:42.13.964] [DEBUG] config template file not exists, no envsubst
        [25.01.2024 19:42.13.972] [LOG] Loading module helpers …
        [25.01.2024 19:42.13.975] [LOG] No helper found for module: alert.
        [25.01.2024 19:42.14.621] [LOG] Initializing new module helper …
        [25.01.2024 19:42.14.622] [LOG] Module helper loaded: MMM-Wallpaper
        [25.01.2024 19:42.14.624] [LOG] No helper found for module: clock.
        [25.01.2024 19:42.15.040] [LOG] Module helper loaded: MMM-Sonos
        [25.01.2024 19:42.15.042] [LOG] No helper found for module: weather.
        [25.01.2024 19:42.15.044] [LOG] No helper found for module: MMM-CalendarExt3.
        [25.01.2024 19:42.15.046] [LOG] No helper found for module: MMM-CalendarExt3Agenda.
        [25.01.2024 19:42.15.408] [LOG] Initializing new module helper …
        [25.01.2024 19:42.15.409] [LOG] Module helper loaded: calendar
        [25.01.2024 19:42.15.411] [LOG] No helper found for module: compliments.
        [25.01.2024 19:42.15.518] [LOG] Initializing new module helper …
        [25.01.2024 19:42.15.519] [LOG] Module helper loaded: MMM-AccuWeatherForecastDeluxe
        [25.01.2024 19:42.15.527] [ERROR] (node:3930) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘python-shell’
        Require stack:
        • /home/sven/MagicMirror/modules/MMM-GoogleKeep/node_helper.js
        • /home/sven/MagicMirror/js/app.js
        • /home/sven/MagicMirror/js/electron.js
        • /home/sven/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        • at node:internal/modules/cjs/loader:1084:15
          at Function. (node:electron/js2c/browser_init:2:117576)
          at Module._resolveFilename (/home/sven/MagicMirror/node_modules/module-alias/index.js:49:29)
          at node:internal/modules/cjs/loader:929:27
          at Function._load (node:electron/js2c/asar_bundle:2:13327)
          at Module.require (node:internal/modules/cjs/loader:1150:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at Object. (/home/sven/MagicMirror/modules/MMM-GoogleKeep/node_helper.js:10:23)
          at Module._compile (node:internal/modules/cjs/loader:1271:14)
          at Object…js (node:internal/modules/cjs/loader:1326:10)
          at Module.load (node:internal/modules/cjs/loader:1126:32)
          at node:internal/modules/cjs/loader:967:12
          at loadModule (/home/sven/MagicMirror/js/app.js:180:19)
          (Use electron --trace-warnings ... to show where the warning was created)
          [25.01.2024 19:42.15.528] [ERROR] (node:3930) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
          [3930:0125/194216.046643:ERROR:object_proxy.cc(590)] Failed to call method: org.freedesktop.portal.Settings.Read: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.portal.Desktop was not provided by any .service files
          MESA-LOADER: failed to retrieve device information
          ^C/home/sven/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          sdetweil @svenpisa
          @svenpisa yes, the instruction leave out an important step
          after step 2
          then change to the module folder
           cd MMM-GoogleKeep
          THEN
          npm install
          you can do that step now, in the module folder
            svenpisa @sdetweil
            @sdetweil i did it…
            I went directly to ~/MagicMirror/modules/MMM-GoogleKeep $ and started npm install but then only got error messages
            npm ERR! code ERESOLVE
            npm ERR! ERESOLVE could not resolve
            npm ERR!
            npm ERR! While resolving: MMM-GoogleKeep@1.0.0
            npm ERR! Found: stylelint@15.11.0
            npm ERR! node_modules/stylelint
            npm ERR! peer stylelint@“15.x” from grunt-stylelint@0.19.0
            npm ERR! node_modules/grunt-stylelint
            npm ERR! dev grunt-stylelint@“latest” from the root project
            npm ERR!
            npm ERR! Could not resolve dependency:
            npm ERR! dev stylelint-config-standard@“latest” from the root project
            npm ERR!
            npm ERR! Conflicting peer dependency: stylelint@16.2.0
            npm ERR! peer stylelint@“^16.1.0” from stylelint-config-standard@36.0.0
            npm ERR! node_modules/stylelint-config-standard
            npm ERR!
            npm ERR! Fix the upstream dependency conflict, or retry
            npm ERR! this command with --force or --legacy-peer-deps
            npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
            npm ERR!
            npm ERR!
            npm ERR! For a full report see:
            npm ERR! /home/sven/.npm/_logs/2024-01-25T19_14_43_524Z-eresolve-report.txt
            npm ERR! A complete log of this run can be found in: /home/sven/.npm/_logs/2024-01-25T19_14_43_524Z-debug-0.log
              sdetweil @svenpisa
              @svenpisa gr… the developer junk
              edit package.json and change
              "devDependencies"
              to
              "devDependencies1"
              then do the
              npm install
              again
                svenpisa @sdetweil
                @sdetweil You’re great… Thank you very much
                Partly good news.
                It could now be installed and entered in config.js. MM also starts cleanly and is also displayed cleanly, but the KEEP module is unfortunately not displayed on the MM.
                Now I need to get the list displayed somehow.
                I have tried it with the APP password 16 digits as well as 4x4 digits and also with the Google password but unfortunately it is not displayed.
                Any more ideas?
                  sdetweil @svenpisa
                  @svenpisa sorry, don’t know the internals of the module
                  S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                    svenpisa @sdetweil
                    @sdetweil What? I thought you were the God Father of Magic Mirror Modules!!! ;-)
                    No problem, maybe there is someone who has used this module before and it works for him to tell me what to do… I would be very happy anyway!!!
                    • KristjanESPERANTOK Offline
                      I have tried to get the module to run, but have also failed. It seems to me that there is a problem with gkeepapi. A simple query with gkeepapi already fails.
                      There seems to be a workaround with docker (see https://github.com/kiwiz/gkeepapi/issues/81), but I didn’t tested that. In the issue discussion the maintainer of gkeepapi mentioned waiting for a new release of gpsoauth. Then MMM-GoogleKeep might work again without any tinkering 🙂
                        svenpisa @KristjanESPERANTO
                        @KristjanESPERANTO Thank you very much. Do I understand correctly that I may only have to wait until the module works or do I have to make additional settings? Can I see the status somewhere when it should work again?
