    MMM-GoogleKeep config.js
    18 Posts 3 Posters 7.0k Views 3 Watching
      sdetweil @svenpisa
      @svenpisa yes, the instruction leave out an important step
      after step 2
      then change to the module folder
       cd MMM-GoogleKeep
      THEN
      npm install
      you can do that step now, in the module folder
        svenpisa @sdetweil
        @sdetweil i did it…
        I went directly to ~/MagicMirror/modules/MMM-GoogleKeep $ and started npm install but then only got error messages
        npm ERR! code ERESOLVE
        npm ERR! ERESOLVE could not resolve
        npm ERR!
        npm ERR! While resolving: MMM-GoogleKeep@1.0.0
        npm ERR! Found: stylelint@15.11.0
        npm ERR! node_modules/stylelint
        npm ERR! peer stylelint@“15.x” from grunt-stylelint@0.19.0
        npm ERR! node_modules/grunt-stylelint
        npm ERR! dev grunt-stylelint@“latest” from the root project
        npm ERR!
        npm ERR! Could not resolve dependency:
        npm ERR! dev stylelint-config-standard@“latest” from the root project
        npm ERR!
        npm ERR! Conflicting peer dependency: stylelint@16.2.0
        npm ERR! peer stylelint@“^16.1.0” from stylelint-config-standard@36.0.0
        npm ERR! node_modules/stylelint-config-standard
        npm ERR!
        npm ERR! Fix the upstream dependency conflict, or retry
        npm ERR! this command with --force or --legacy-peer-deps
        npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
        npm ERR!
        npm ERR!
        npm ERR! For a full report see:
        npm ERR! /home/sven/.npm/_logs/2024-01-25T19_14_43_524Z-eresolve-report.txt
        npm ERR! A complete log of this run can be found in: /home/sven/.npm/_logs/2024-01-25T19_14_43_524Z-debug-0.log
          sdetweil @svenpisa
          @svenpisa gr… the developer junk
          edit package.json and change
          "devDependencies"
          to
          "devDependencies1"
          then do the
          npm install
          again
            svenpisa @sdetweil
            @sdetweil You’re great… Thank you very much
            Partly good news.
            It could now be installed and entered in config.js. MM also starts cleanly and is also displayed cleanly, but the KEEP module is unfortunately not displayed on the MM.
            Now I need to get the list displayed somehow.
            I have tried it with the APP password 16 digits as well as 4x4 digits and also with the Google password but unfortunately it is not displayed.
            Any more ideas?
              sdetweil @svenpisa
              @svenpisa sorry, don’t know the internals of the module
              S KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
                svenpisa @sdetweil
                @sdetweil What? I thought you were the God Father of Magic Mirror Modules!!! ;-)
                No problem, maybe there is someone who has used this module before and it works for him to tell me what to do… I would be very happy anyway!!!
                • KristjanESPERANTOK Offline
                  I have tried to get the module to run, but have also failed. It seems to me that there is a problem with gkeepapi. A simple query with gkeepapi already fails.
                  There seems to be a workaround with docker (see https://github.com/kiwiz/gkeepapi/issues/81), but I didn’t tested that. In the issue discussion the maintainer of gkeepapi mentioned waiting for a new release of gpsoauth. Then MMM-GoogleKeep might work again without any tinkering 🙂
                    svenpisa @KristjanESPERANTO
                    @KristjanESPERANTO Thank you very much. Do I understand correctly that I may only have to wait until the module works or do I have to make additional settings? Can I see the status somewhere when it should work again?
                      sdetweil @svenpisa
                      @svenpisa well I can fix most install problems.
                        KristjanESPERANTO Module Developer @svenpisa
                        I haven’t looked at the code in detail, but that could be possible, yes. Of course, it may still be the case that something needs to be adjusted in gkeepapi and/or MMM-GoogleKeep.
                        The best thing would probably be to look at alternatives.
                        If a gpsoauth version newer than 1.0.4 appears here, we can try again. You can also follow this discussion: https://github.com/kiwiz/gkeepapi/issues/81.
