    Starter problem
    73 Posts 8 Posters 86.7k Views 5 Watching
    • K Offline
      kurt
      Thanks a lot once more!
      There was a point behind my “config.js” !
      I deletet that point and tryed again with
      DISPLAY=:0 npm start
      this is what happened:
      pi@raspberrypi:~ $ DISPLAY=:0 npm start
      npm ERR! Linux 4.4.38-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.9.4
      npm ERR! npm  v3.10.10
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/npm-debug.log
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @kurt
        @kurt you are in the wrong directory again cd ~/MagicMirror
        • K Offline
          kurt
          I’m in the /home/pi/MagicMirror/config - file
          Is this the wrong one?
          and what does it mean “cd ~/Magic Mirror”
          strawberry 3.141S tosti007T 2 Replies Last reply Reply Quote 0
            @kurt
            your logs show what you are not in /home/pi/MagicMirror/config with the terminal console
            if you type in that command you will be in the correct directory cd means change directory
            after that do DISPLAY=:0 npm start
            • tosti007T Offline
              tosti007 Module Developer @kurt
              @kurt if you are on /home/pi/MagicMirror/config then you have to move one folder up. You can do this by typing cd ..
              If there is anything don't hesitate to contact me!
              ProfileSwitcher, TouchNotifications
              • K Offline
                kurt
                WoW strawberry3.141 you made my day!
                I’m looking hot, so they say :)
                is it so that I have to typ in first the : cd ~/MagicMirror to get into the right directory, and is this the same I can see in my FTP Client?
                Thanks a lot for your help, I’m just happy and thankfull.
                Without you guys it would be impossible to get into that projekts so quick.
                So I guess this the moment for the beer! Cheers and thank you again.
                Now after some break I will start with the adaptions…
                Do you have any hints for the best way to avoid problems with this adaption?
                What a day
                Greetings kurt
                  @kurt it’s past 4 o’clock so no reason to drink no beer :D cd ~ ist the same as cd /home/pi/
                  i dont know which directory you are looking at in the client but i guess its the same.
                  what adaptions do you mean? styling, more modules, …?
                  tosti007T 1 Reply Last reply Reply Quote 0
                  • tosti007T Offline
                    tosti007 Module Developer @strawberry 3.141
                    @strawberry-3.141 I think he means changing his config file and maybe adding in some more modules. So time to get your app up and running :P
                    @Kurt I would start by first using the default modules (like calendar, time, etc). If you aren’t sure you changed it correctly then you can always just change one thing at the time and make sure it still works.
                    • K Offline
                      kurt
                      Yes, thats what i’ll do. Step by step. just change the rss feed or the compliments (does it matter how many of them you put into the modul?) weatherforcast…
                      Also Thanks to @tosti007
                      I feel comfortable in this forum!
                      @strawberry-3-141 by the way you are working on an hot app?
                        @kurt my bachelor thesis is about a mobile app to configure the mirror
                        cause you are from vienna, you might want to checkout my transport module for vienna https://github.com/fewieden/MMM-WienerLinien
                        • tosti007T Offline
                          @kurt no it doesn’t matter how many compliments you put in. And good to hear that you feel comfortable :) and you’re welcome!
                          • K Offline
                            kurt
                            @strawberry-3-141 Hey I allready visit it today! while drifting thru the forum. suprise! I lived in Barawitzkagasse for quite a long time. funny small world, isn’it?
                            Is the modul allready finished or are still in it?
                              @kurt it should be finished
                              K 2 Replies Last reply Reply Quote 0
                              • K Offline
                                kurt @strawberry 3.141
                                @strawberry-3.141
                                fine , is on my list :)
                                • K Offline
                                  @strawberry-3.141
                                  Hallo strawberry
                                  Can you pleas tell me whats wrong with my config.js
                                  By now nothing is shown. I wanted to impement the W.Linien modul, but also the weatherforcast was not shown.
                                  Thank you in advance
                                  Kurt
                                  /* Magic Mirror Config Sample
                                   * MIT Licensed.
                                  var config = {
                                  	port: 8080,
                                  	language: 'de',
                                  	timeFormat: 24,
                                  	units: 'metric',
                                                        module: "MMM-WienerLinien",
                                                             api_key: "NZXDPzyd3QsAtTCT",
                                                             stations: ["142", "141"],
                                  			module: 'alert',
                                  			module: "updatenotification",
                                  			position: "top_bar"
                                  			module: 'clock',
                                  			position: 'top_left'
                                  			module: 'compliments',
                                  			position: 'lower_third'
                                  			module: 'currentweather',
                                  			position: 'top_right',
                                  				locationID: '',  //ID from http://www.openweathermap.org
                                  				appid: 'xxxxxxxxxxxxxxxxxxx'
                                  			module: 'weatherforecast',
                                  			header: 'Das Wetter',
                                  				locationID: '5128581',  //ID from http://www.openweathermap.org
                                  			module: 'newsfeed',
                                  			position: 'bottom_bar',
                                  				feeds: [
                                  						title: "Der Standard",
                                  						url: "http://derstandard.at/?page=rss&ressort=Seite1"
                                  				showSourceTitle: true,
                                  				showPublishDate: true
                                  in_a_daysI 2 Replies Last reply Reply Quote 0
                                  • in_a_daysI Offline
                                    in_a_days @kurt
                                    @kurt
                                    You’re missing a } here
                                                       api_key: "xxxxxxxxxxx",
                                    should be
                                    Could be other issues, but check that out first :)
                                    K FrühstückF 2 Replies Last reply Reply Quote 2
                                      in_a_days @kurt
                                      @kurt
                                      Also, it’s a good idea to remove your personal API codes when sharing your config file(s).
                                      • K Offline
                                        kurt @in_a_days
                                        Thank you @in_a_days
                                        I copied your answer into the right place, but the screen stays black.
                                        in_a_daysI 1 Reply Last reply Reply Quote 0
                                          in_a_days @kurt
                                          @kurt
                                          You’re welcome, did you re-start the mirror program after changing the config file?
                                          • K Offline
                                            kurt @in_a_days
                                            @in_a_days
                                            Yes with strg R on the raspi
                                            • 1 / 4
