    Starter problem
    73 Posts 8 Posters 92.0k Views 5 Watching
    • K
      kurt
      I’m working via ssh, I can see the starter Logo, but thats’it
      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
      magicmirror@2.1.0 start /home/pi/MagicMirror
      electron js/electron.js
      Starting MagicMirror: v2.1.0
      Loading config …
      WARNING! Could not find config file. Please create one. Starting with default configuration.
      Loading module helpers …
      No helper found for module: helloworld.
      All module helpers loaded.
      Starting server op port 8080 …
      Server started …
      Sockets connected & modules started …
      Launching application.
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @kurt
        @kurt WARNING! Could not find config file. Please create one. Starting with default configuration.
        are you sure you renamed the file correctly?
        cd ~/MagicMirror/config
        ls
        if not then copy the sample again
        cp config.js.sample config.js
        • K
          kurt
          Thanks a lot once more!
          There was a point behind my “config.js” !
          I deletet that point and tryed again with
          this is what happened:
          pi@raspberrypi:~ $ DISPLAY=:0 npm start
          npm ERR! Linux 4.4.38-v7+
          npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
          npm ERR! node v6.9.4
          npm ERR! npm  v3.10.10
          npm ERR! code ENOENT
          npm ERR! errno -2
          npm ERR! syscall open
          npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
          npm ERR! enoent This is most likely not a problem with npm itself
          npm ERR! enoent and is related to npm not being able to find a file.
          npm ERR! enoent
          npm ERR!     /home/pi/npm-debug.log
          • strawberry 3.141S
            @kurt you are in the wrong directory again cd ~/MagicMirror
            • K
              kurt
              I’m in the /home/pi/MagicMirror/config - file
              Is this the wrong one?
              and what does it mean “cd ~/Magic Mirror”
              strawberry 3.141S T 2 Replies Last reply
              • strawberry 3.141S
                @kurt
                your logs show what you are not in /home/pi/MagicMirror/config with the terminal console
                if you type in that command you will be in the correct directory cd means change directory
                after that do DISPLAY=:0 npm start
                • T
                  tosti007 Module Developer @kurt
                  @kurt if you are on /home/pi/MagicMirror/config then you have to move one folder up. You can do this by typing cd ..
                  If there is anything don’t hesitate to contact me!
                  ProfileSwitcher, TouchNotifications
                  • K
                    kurt
                    WoW strawberry3.141 you made my day!
                    I’m looking hot, so they say :)
                    is it so that I have to typ in first the : cd ~/MagicMirror to get into the right directory, and is this the same I can see in my FTP Client?
                    Thanks a lot for your help, I’m just happy and thankfull.
                    Without you guys it would be impossible to get into that projekts so quick.
                    So I guess this the moment for the beer! Cheers and thank you again.
                    Now after some break I will start with the adaptions…
                    Do you have any hints for the best way to avoid problems with this adaption?
                    What a day
                    Greetings kurt
                    • strawberry 3.141S
                      @kurt it’s past 4 o’clock so no reason to drink no beer :D cd ~ ist the same as cd /home/pi/
                      i dont know which directory you are looking at in the client but i guess its the same.
                      what adaptions do you mean? styling, more modules, …?
                      T 1 Reply Last reply
                      • T
                        tosti007 Module Developer @strawberry 3.141
                        @strawberry-3.141 I think he means changing his config file and maybe adding in some more modules. So time to get your app up and running :P
                        @Kurt I would start by first using the default modules (like calendar, time, etc). If you aren’t sure you changed it correctly then you can always just change one thing at the time and make sure it still works.
                        • K
                          kurt
                          Yes, thats what i’ll do. Step by step. just change the rss feed or the compliments (does it matter how many of them you put into the modul?) weatherforcast…
                          Also Thanks to @tosti007
                          I feel comfortable in this forum!
                          @strawberry-3-141 by the way you are working on an hot app?
                          • strawberry 3.141S
                            @kurt my bachelor thesis is about a mobile app to configure the mirror
                            cause you are from vienna, you might want to checkout my transport module for vienna https://github.com/fewieden/MMM-WienerLinien
                            • T
                              @kurt no it doesn’t matter how many compliments you put in. And good to hear that you feel comfortable :) and you’re welcome!
                              • K
                                kurt
                                @strawberry-3-141 Hey I allready visit it today! while drifting thru the forum. suprise! I lived in Barawitzkagasse for quite a long time. funny small world, isn’it?
                                Is the modul allready finished or are still in it?
                                • strawberry 3.141S
                                  @kurt it should be finished
                                  K 2 Replies Last reply
                                  • K
                                    kurt @strawberry 3.141
                                    @strawberry-3.141
                                    fine , is on my list :)
                                    • K
                                      @strawberry-3.141
                                      Hallo strawberry
                                      Can you pleas tell me whats wrong with my config.js
                                      By now nothing is shown. I wanted to impement the W.Linien modul, but also the weatherforcast was not shown.
                                      Thank you in advance
                                      Kurt
                                      /* Magic Mirror Config Sample
                                       * MIT Licensed.
                                      var config = {
                                      	port: 8080,
                                      	language: 'de',
                                      	timeFormat: 24,
                                      	units: 'metric',
                                                            module: "MMM-WienerLinien",
        api_key: "NZXDPzyd3QsAtTCT",
        stations: ["142", "141"],
                                      			module: 'alert',
                                      			module: "updatenotification",
                                      			position: "top_bar"
                                      			module: 'clock',
                                      			position: 'top_left'
                                      			module: 'compliments',
                                      			position: 'lower_third'
                                      			module: 'currentweather',
                                      			position: 'top_right',
                                      				locationID: '',  //ID from http://www.openweathermap.org
                                      				appid: 'xxxxxxxxxxxxxxxxxxx'
                                      			module: 'weatherforecast',
                                      			header: 'Das Wetter',
                                      				locationID: '5128581',  //ID from http://www.openweathermap.org
                                      			module: 'newsfeed',
                                      			position: 'bottom_bar',
                                      				feeds: [
                                      						title: "Der Standard",
                                      						url: "http://derstandard.at/?page=rss&ressort=Seite1"
                                      				showSourceTitle: true,
                                      				showPublishDate: true
                                      I 2 Replies Last reply
                                      • I
                                        in_a_days @kurt
                                        @kurt
                                        You’re missing a } here
                                                           api_key: "xxxxxxxxxxx",
                                        should be
                                        Could be other issues, but check that out first :)
                                        K FrühstückF 2 Replies Last reply
                                        Reply Quote 2
                                        • I
                                          in_a_days @kurt
                                          @kurt
                                          Also, it’s a good idea to remove your personal API codes when sharing your config file(s).
                                          • K
                                            kurt @in_a_days
                                            Thank you @in_a_days
                                            I copied your answer into the right place, but the screen stays black.
                                            I 1 Reply Last reply
                                            • 1 / 4
