    Starter problem
    73 Posts 8 Posters 86.2k Views 5 Watching
    • tosti007T Offline
      tosti007 Module Developer @strawberry 3.141
      @strawberry-3.141 I think he means changing his config file and maybe adding in some more modules. So time to get your app up and running :P
      @Kurt I would start by first using the default modules (like calendar, time, etc). If you aren’t sure you changed it correctly then you can always just change one thing at the time and make sure it still works.
      If there is anything don't hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • K Offline
        kurt
        Yes, thats what i’ll do. Step by step. just change the rss feed or the compliments (does it matter how many of them you put into the modul?) weatherforcast…
        Also Thanks to @tosti007
        I feel comfortable in this forum!
        @strawberry-3-141 by the way you are working on an hot app?
        strawberry 3.141S tosti007T 2 Replies Last reply Reply Quote 0
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @kurt
          @kurt my bachelor thesis is about a mobile app to configure the mirror
          cause you are from vienna, you might want to checkout my transport module for vienna https://github.com/fewieden/MMM-WienerLinien
          • tosti007T Offline
            tosti007 Module Developer @kurt
            @kurt no it doesn’t matter how many compliments you put in. And good to hear that you feel comfortable :) and you’re welcome!
            • K Offline
              kurt
              @strawberry-3-141 Hey I allready visit it today! while drifting thru the forum. suprise! I lived in Barawitzkagasse for quite a long time. funny small world, isn’it?
              Is the modul allready finished or are still in it?
                @kurt it should be finished
                K 2 Replies Last reply Reply Quote 0
                • K Offline
                  kurt @strawberry 3.141
                  @strawberry-3.141
                  fine , is on my list :)
                  • K Offline
                    @strawberry-3.141
                    Hallo strawberry
                    Can you pleas tell me whats wrong with my config.js
                    By now nothing is shown. I wanted to impement the W.Linien modul, but also the weatherforcast was not shown.
                    Thank you in advance
                    Kurt
                    /* Magic Mirror Config Sample
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: 'de',
                    	timeFormat: 24,
                    	units: 'metric',
                                          module: "MMM-WienerLinien",
                                               api_key: "NZXDPzyd3QsAtTCT",
                                               stations: ["142", "141"],
                    			module: 'alert',
                    			module: "updatenotification",
                    			position: "top_bar"
                    			module: 'clock',
                    			position: 'top_left'
                    			module: 'compliments',
                    			position: 'lower_third'
                    			module: 'currentweather',
                    			position: 'top_right',
                    				locationID: '',  //ID from http://www.openweathermap.org
                    				appid: 'xxxxxxxxxxxxxxxxxxx'
                    			module: 'weatherforecast',
                    			header: 'Das Wetter',
                    				locationID: '5128581',  //ID from http://www.openweathermap.org
                    			module: 'newsfeed',
                    			position: 'bottom_bar',
                    				feeds: [
                    						title: "Der Standard",
                    						url: "http://derstandard.at/?page=rss&ressort=Seite1"
                    				showSourceTitle: true,
                    				showPublishDate: true
                    in_a_daysI 2 Replies Last reply Reply Quote 0
                    • in_a_daysI Offline
                      in_a_days @kurt
                      @kurt
                      You’re missing a } here
                                         api_key: "xxxxxxxxxxx",
                      should be
                      Could be other issues, but check that out first :)
                      K FrühstückF 2 Replies Last reply Reply Quote 2
                        in_a_days @kurt
                        @kurt
                        Also, it’s a good idea to remove your personal API codes when sharing your config file(s).
                        • K Offline
                          kurt @in_a_days
                          Thank you @in_a_days
                          I copied your answer into the right place, but the screen stays black.
                          in_a_daysI 1 Reply Last reply Reply Quote 0
                            in_a_days @kurt
                            @kurt
                            You’re welcome, did you re-start the mirror program after changing the config file?
                            • K Offline
                              kurt @in_a_days
                              @in_a_days
                              Yes with strg R on the raspi
                                in_a_days @kurt
                                @kurt
                                Hmm. I’ll test your config.js on my system and see if I can isolate the problem.
                                • K Offline
                                  kurt @in_a_days
                                  @in_a_days
                                  wow thanks a lot
                                  • yawnsY Offline
                                    yawns Moderator
                                    Did you run npm install in the MMM-WienerLinien folder?
                                    • K Offline
                                      kurt @yawns
                                      @yawns
                                      no ! how can I do this?
                                        in_a_days @kurt
                                        @kurt
                                        From a new terminal session:
                                        cd MagicMirror/modules/MMM-WienerLinien
                                        npm install
                                        • K Offline
                                          kurt @in_a_days
                                          @in_a_days
                                          the installation went well, but when I try to reboot the booting logo appears shortly, but thats it.
                                          But into the MM folder there are two config folder now, one .config and one config
                                          Either I didn’t recogbize that bevor, or one is new.
                                            in_a_days @kurt
                                            @kurt
                                            Just wanted to check in. I tried to copy the config.js you posted and I had some problems as well. I’m a bit busy today, but I have some ideas and if you’re still stuck I’ll try to have a solution for you tomorrow. :)
                                            • 2 / 4
