    Starter problem
    73 Posts 8 Posters 92.0k Views 5 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @kurt
      @kurt it should be finished
      K 2 Replies Last reply
      • K
        kurt @strawberry 3.141
        @strawberry-3.141
        fine , is on my list :)
        • K
          @strawberry-3.141
          Hallo strawberry
          Can you pleas tell me whats wrong with my config.js
          By now nothing is shown. I wanted to impement the W.Linien modul, but also the weatherforcast was not shown.
          Thank you in advance
          Kurt
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: 'de',
          	timeFormat: 24,
          	units: 'metric',
                                module: "MMM-WienerLinien",
                                     api_key: "NZXDPzyd3QsAtTCT",
                                     stations: ["142", "141"],
          			module: 'alert',
          			module: "updatenotification",
          			position: "top_bar"
          			module: 'clock',
          			position: 'top_left'
          			module: 'compliments',
          			position: 'lower_third'
          			module: 'currentweather',
          			position: 'top_right',
          				locationID: '',  //ID from http://www.openweathermap.org
          				appid: 'xxxxxxxxxxxxxxxxxxx'
          			module: 'weatherforecast',
          			header: 'Das Wetter',
          				locationID: '5128581',  //ID from http://www.openweathermap.org
          			module: 'newsfeed',
          			position: 'bottom_bar',
          				feeds: [
          						title: "Der Standard",
          						url: "http://derstandard.at/?page=rss&ressort=Seite1"
          				showSourceTitle: true,
          				showPublishDate: true
          I 2 Replies Last reply
          • I
            in_a_days @kurt
            @kurt
            You’re missing a } here
                               api_key: "xxxxxxxxxxx",
            should be
            Could be other issues, but check that out first :)
            K FrühstückF 2 Replies Last reply
            Reply Quote 2
            • I
              in_a_days @kurt
              @kurt
              Also, it’s a good idea to remove your personal API codes when sharing your config file(s).
              • K
                kurt @in_a_days
                Thank you @in_a_days
                I copied your answer into the right place, but the screen stays black.
                I 1 Reply Last reply
                • I
                  in_a_days @kurt
                  @kurt
                  You’re welcome, did you re-start the mirror program after changing the config file?
                  K 1 Reply Last reply
                  • K
                    kurt @in_a_days
                    @in_a_days
                    Yes with strg R on the raspi
                    • I
                      in_a_days @kurt
                      @kurt
                      Hmm. I’ll test your config.js on my system and see if I can isolate the problem.
                      • K
                        kurt @in_a_days
                        @in_a_days
                        wow thanks a lot
                        • Y
                          yawns Moderator
                          Did you run npm install in the MMM-WienerLinien folder?
                          • K
                            kurt @yawns
                            @yawns
                            no ! how can I do this?
                            • I
                              in_a_days @kurt
                              @kurt
                              From a new terminal session:
                              cd MagicMirror/modules/MMM-WienerLinien
                              npm install
                              • K
                                kurt @in_a_days
                                @in_a_days
                                the installation went well, but when I try to reboot the booting logo appears shortly, but thats it.
                                But into the MM folder there are two config folder now, one .config and one config
                                Either I didn’t recogbize that bevor, or one is new.
                                • I
                                  in_a_days @kurt
                                  @kurt
                                  Just wanted to check in. I tried to copy the config.js you posted and I had some problems as well. I’m a bit busy today, but I have some ideas and if you’re still stuck I’ll try to have a solution for you tomorrow. :)
                                  • K
                                    kurt
                                    Hallo
                                    Has somebody an idea to help?
                                    The internet connection is fine, cause the rss from the Ney York Times is shown.
                                    kurt
                                    > magicmirror@2.1.0 start /home/pi/MagicMirror
                                    > electron js/electron.js
                                    Starting MagicMirror: v2.1.0
                                    Loading config ...
                                    Loading module helpers ...
                                    All module helpers loaded.
                                    Starting server op port 8080 ...
                                    Server started ...
                                    Starting module: newsfeed
                                    { Error: listen EADDRINUSE :::8080
                                        at Object.exports._errnoException (util.js:1026:11)
                                        at exports._exceptionWithHostPort (util.js:1049:20)
                                        at Server._listen2 (net.js:1253:14)
                                        at listen (net.js:1289:10)
                                        at net.js:1399:9
                                        at _combinedTickCallback (internal/process/next_tick.js:77:11)
                                        at process._tickCallback (internal/process/next_tick.js:98:9)
                                        at Module.runMain (module.js:592:11)
                                        at run (bootstrap_node.js:402:7)
                                        at startup (bootstrap_node.js:157:9)
                                      code: 'EADDRINUSE',
                                      errno: 'EADDRINUSE',
                                      syscall: 'listen',
                                      address: '::',
                                      port: 8080 }
                                    Launching application.
                                    • strawberry 3.141S
                                      @kurt this means probably that there is already an instance of magicmirror running on your pi because the port is already used
                                      • K
                                        @strawberry-3.141
                                        Thank you strawberry, but how about this now?
                                        pi@raspberrypi:~ $ DISPLAY=:0 npm start
                                        npm ERR! Linux 4.4.38-v7+
                                        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                        npm ERR! node v6.9.4
                                        npm ERR! npm  v3.10.10
                                        npm ERR! code ENOENT
                                        npm ERR! errno -2
                                        npm ERR! syscall open
                                        npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                        npm ERR! enoent This is most likely not a problem with npm itself
                                        npm ERR! enoent and is related to npm not being able to find a file.
                                        npm ERR! enoent
                                        npm ERR!     /home/pi/npm-debug.log
                                        • strawberry 3.141S
                                          @kurt you are in the wrong directory again :D
                                          cd ~MagicMirror first
                                          • K
                                            @strawberry-3.141
                                            Sorry , but now get the starting logo with the" Please create a config file"
                                            Thank you
                                            pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                                            Loading config ...
                                            WARNING! Could not find config file. Please create one. Starting with default configuration.
                                            No helper found for module: helloworld.
                                            Server started ...
                                            • 2 / 4
