    Starter problem
    73 Posts 8 Posters 92.0k Views 5 Watching
    • I
      in_a_days @kurt
      @kurt
      You’re missing a } here
                    module: "MMM-WienerLinien",
                         api_key: "xxxxxxxxxxx",
                         stations: ["142", "141"],
      should be
      Could be other issues, but check that out first :)
      K FrühstückF 2 Replies Last reply
      Reply Quote 2
      • I
        in_a_days @kurt
        @kurt
        Also, it’s a good idea to remove your personal API codes when sharing your config file(s).
        • K
          kurt @in_a_days
          Thank you @in_a_days
          I copied your answer into the right place, but the screen stays black.
          I 1 Reply Last reply
          • I
            in_a_days @kurt
            @kurt
            You’re welcome, did you re-start the mirror program after changing the config file?
            K 1 Reply Last reply
            • K
              kurt @in_a_days
              @in_a_days
              Yes with strg R on the raspi
              • I
                in_a_days @kurt
                @kurt
                Hmm. I’ll test your config.js on my system and see if I can isolate the problem.
                • K
                  kurt @in_a_days
                  @in_a_days
                  wow thanks a lot
                  • Y
                    yawns Moderator
                    Did you run npm install in the MMM-WienerLinien folder?
                    • K
                      kurt @yawns
                      @yawns
                      no ! how can I do this?
                      • I
                        in_a_days @kurt
                        @kurt
                        From a new terminal session:
                        cd MagicMirror/modules/MMM-WienerLinien
                        npm install
                        • K
                          kurt @in_a_days
                          @in_a_days
                          the installation went well, but when I try to reboot the booting logo appears shortly, but thats it.
                          But into the MM folder there are two config folder now, one .config and one config
                          Either I didn’t recogbize that bevor, or one is new.
                          • I
                            in_a_days @kurt
                            @kurt
                            Just wanted to check in. I tried to copy the config.js you posted and I had some problems as well. I’m a bit busy today, but I have some ideas and if you’re still stuck I’ll try to have a solution for you tomorrow. :)
                            • K
                              kurt
                              Hallo
                              Has somebody an idea to help?
                              The internet connection is fine, cause the rss from the Ney York Times is shown.
                              Thank you in advance
                              kurt
                              > magicmirror@2.1.0 start /home/pi/MagicMirror
                              > electron js/electron.js
                              Starting MagicMirror: v2.1.0
                              Loading config ...
                              Loading module helpers ...
                              All module helpers loaded.
                              Starting server op port 8080 ...
                              Server started ...
                              Starting module: newsfeed
                              { Error: listen EADDRINUSE :::8080
                                  at Object.exports._errnoException (util.js:1026:11)
                                  at exports._exceptionWithHostPort (util.js:1049:20)
                                  at Server._listen2 (net.js:1253:14)
                                  at listen (net.js:1289:10)
                                  at net.js:1399:9
                                  at _combinedTickCallback (internal/process/next_tick.js:77:11)
                                  at process._tickCallback (internal/process/next_tick.js:98:9)
                                  at Module.runMain (module.js:592:11)
                                  at run (bootstrap_node.js:402:7)
                                  at startup (bootstrap_node.js:157:9)
                                code: 'EADDRINUSE',
                                errno: 'EADDRINUSE',
                                syscall: 'listen',
                                address: '::',
                                port: 8080 }
                              Launching application.
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @kurt
                                @kurt this means probably that there is already an instance of magicmirror running on your pi because the port is already used
                                • K
                                  kurt @strawberry 3.141
                                  @strawberry-3.141
                                  Thank you strawberry, but how about this now?
                                  pi@raspberrypi:~ $ DISPLAY=:0 npm start
                                  npm ERR! Linux 4.4.38-v7+
                                  npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                  npm ERR! node v6.9.4
                                  npm ERR! npm  v3.10.10
                                  npm ERR! code ENOENT
                                  npm ERR! errno -2
                                  npm ERR! syscall open
                                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                  npm ERR! enoent This is most likely not a problem with npm itself
                                  npm ERR! enoent and is related to npm not being able to find a file.
                                  npm ERR! enoent
                                  npm ERR!     /home/pi/npm-debug.log
                                  • strawberry 3.141S
                                    @kurt you are in the wrong directory again :D
                                    cd ~MagicMirror first
                                    • K
                                      @strawberry-3.141
                                      Sorry , but now get the starting logo with the" Please create a config file"
                                      Thank you
                                      pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
                                      Loading config ...
                                      WARNING! Could not find config file. Please create one. Starting with default configuration.
                                      No helper found for module: helloworld.
                                      Server started ...
                                      • strawberry 3.141S
                                        @kurt are you sure you have a config file in /home/pi/MagicMirror/config
                                        K 2 Replies Last reply
                                        • K
                                          @strawberry-3.141 I’m allready working on that mistake.
                                          you a right, don’t know who took this fike from that place.
                                          Change the config, file and place over there.
                                          Mystery…
                                          Kurt
                                          • K
                                            @strawberry-3.141
                                            I’m working with File Zilla to transfer the files.
                                            By now I guess he the one who makes the config folder dissapear. Have you ever heard of something like that? or can you recommend an other tool to upload files? I tried Cyberduck, but won’t work.
                                            • 2 / 4
