    Starter problem
    73 Posts 8 Posters 89.7k Views 5 Watching
    • T Offline
      tosti007 Module Developer @kurt
      @kurt no it doesn’t matter how many compliments you put in. And good to hear that you feel comfortable :) and you’re welcome!
      If there is anything don’t hesitate to contact me!
      ProfileSwitcher, TouchNotifications
      • K Offline
        kurt
        @strawberry-3-141 Hey I allready visit it today! while drifting thru the forum. suprise! I lived in Barawitzkagasse for quite a long time. funny small world, isn’it?
        Is the modul allready finished or are still in it?
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @kurt
          @kurt it should be finished
          K 2 Replies Last reply Reply Quote 0
          • K Offline
            kurt @strawberry 3.141
            @strawberry-3.141
            fine , is on my list :)
            • K Offline
              @strawberry-3.141
              Hallo strawberry
              Can you pleas tell me whats wrong with my config.js
              By now nothing is shown. I wanted to impement the W.Linien modul, but also the weatherforcast was not shown.
              Thank you in advance
              Kurt
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: 'de',
              	timeFormat: 24,
              	units: 'metric',
                                    module: "MMM-WienerLinien",
                                         api_key: "NZXDPzyd3QsAtTCT",
                                         stations: ["142", "141"],
              			module: 'alert',
              			module: "updatenotification",
              			position: "top_bar"
              			module: 'clock',
              			position: 'top_left'
              			module: 'compliments',
              			position: 'lower_third'
              			module: 'currentweather',
              			position: 'top_right',
              				locationID: '',  //ID from http://www.openweathermap.org
              				appid: 'xxxxxxxxxxxxxxxxxxx'
              			module: 'weatherforecast',
              			header: 'Das Wetter',
              				locationID: '5128581',  //ID from http://www.openweathermap.org
              			module: 'newsfeed',
              			position: 'bottom_bar',
              				feeds: [
              						title: "Der Standard",
              						url: "http://derstandard.at/?page=rss&ressort=Seite1"
              				showSourceTitle: true,
              				showPublishDate: true
              I 2 Replies Last reply Reply Quote 0
              • I Offline
                in_a_days @kurt
                @kurt
                You’re missing a } here
                                   api_key: "xxxxxxxxxxx",
                should be
                Could be other issues, but check that out first :)
                K FrühstückF 2 Replies Last reply Reply Quote 2
                • I Offline
                  in_a_days @kurt
                  @kurt
                  Also, it’s a good idea to remove your personal API codes when sharing your config file(s).
                  • K Offline
                    kurt @in_a_days
                    Thank you @in_a_days
                    I copied your answer into the right place, but the screen stays black.
                    • I Offline
                      in_a_days @kurt
                      @kurt
                      You’re welcome, did you re-start the mirror program after changing the config file?
                      • K Offline
                        kurt @in_a_days
                        @in_a_days
                        Yes with strg R on the raspi
                        • I Offline
                          in_a_days @kurt
                          @kurt
                          Hmm. I’ll test your config.js on my system and see if I can isolate the problem.
                          • K Offline
                            kurt @in_a_days
                            @in_a_days
                            wow thanks a lot
                            • Y Offline
                              yawns Moderator
                              Did you run npm install in the MMM-WienerLinien folder?
                              • K Offline
                                kurt @yawns
                                @yawns
                                no ! how can I do this?
                                • I Offline
                                  in_a_days @kurt
                                  @kurt
                                  From a new terminal session:
                                  cd MagicMirror/modules/MMM-WienerLinien
                                  npm install
                                  • K Offline
                                    kurt @in_a_days
                                    @in_a_days
                                    the installation went well, but when I try to reboot the booting logo appears shortly, but thats it.
                                    But into the MM folder there are two config folder now, one .config and one config
                                    Either I didn’t recogbize that bevor, or one is new.
                                    • I Offline
                                      in_a_days @kurt
                                      @kurt
                                      Just wanted to check in. I tried to copy the config.js you posted and I had some problems as well. I’m a bit busy today, but I have some ideas and if you’re still stuck I’ll try to have a solution for you tomorrow. :)
                                      • K Offline
                                        kurt
                                        Hallo
                                        Has somebody an idea to help?
                                        The internet connection is fine, cause the rss from the Ney York Times is shown.
                                        kurt
                                        > magicmirror@2.1.0 start /home/pi/MagicMirror
                                        > electron js/electron.js
                                        Starting MagicMirror: v2.1.0
                                        Loading config ...
                                        Loading module helpers ...
                                        All module helpers loaded.
                                        Starting server op port 8080 ...
                                        Server started ...
                                        Starting module: newsfeed
                                        { Error: listen EADDRINUSE :::8080
                                            at Object.exports._errnoException (util.js:1026:11)
                                            at exports._exceptionWithHostPort (util.js:1049:20)
                                            at Server._listen2 (net.js:1253:14)
                                            at listen (net.js:1289:10)
                                            at net.js:1399:9
                                            at _combinedTickCallback (internal/process/next_tick.js:77:11)
                                            at process._tickCallback (internal/process/next_tick.js:98:9)
                                            at Module.runMain (module.js:592:11)
                                            at run (bootstrap_node.js:402:7)
                                            at startup (bootstrap_node.js:157:9)
                                          code: 'EADDRINUSE',
                                          errno: 'EADDRINUSE',
                                          syscall: 'listen',
                                          address: '::',
                                          port: 8080 }
                                        Launching application.
                                          @kurt this means probably that there is already an instance of magicmirror running on your pi because the port is already used
                                          • K Offline
                                            @strawberry-3.141
                                            Thank you strawberry, but how about this now?
                                            pi@raspberrypi:~ $ DISPLAY=:0 npm start
                                            npm ERR! Linux 4.4.38-v7+
                                            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                                            npm ERR! node v6.9.4
                                            npm ERR! npm  v3.10.10
                                            npm ERR! code ENOENT
                                            npm ERR! errno -2
                                            npm ERR! syscall open
                                            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                                            npm ERR! enoent This is most likely not a problem with npm itself
                                            npm ERR! enoent and is related to npm not being able to find a file.
                                            npm ERR! enoent
                                            npm ERR!     /home/pi/npm-debug.log
                                            • 2 / 4
