    Starter problem
    73 Posts 8 Posters 89.7k Views 5 Watching
    • Y Offline
      yawns Moderator
      Are you working on your raspberry? Or are you connected via ssh?
      If you are connected via ssh you need to run DISPLAY=:0 npm start instead to tell the raspberry to use the display connected to the raspberry instead of the not working ssh connection
      • K Offline
        kurt
        I’m working via ssh, I can see the starter Logo, but thats’it
        pi@raspberrypi:~/MagicMirror $ DISPLAY=:0 npm start
        magicmirror@2.1.0 start /home/pi/MagicMirror
        electron js/electron.js
        Starting MagicMirror: v2.1.0
        Loading config …
        WARNING! Could not find config file. Please create one. Starting with default configuration.
        Loading module helpers …
        No helper found for module: helloworld.
        All module helpers loaded.
        Starting server op port 8080 …
        Server started …
        Sockets connected & modules started …
        Launching application.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @kurt
          @kurt WARNING! Could not find config file. Please create one. Starting with default configuration.
          are you sure you renamed the file correctly?
          cd ~/MagicMirror/config
          ls
          if not then copy the sample again
          cp config.js.sample config.js
          • K Offline
            kurt
            Thanks a lot once more!
            There was a point behind my “config.js” !
            I deletet that point and tryed again with
            this is what happened:
            pi@raspberrypi:~ $ DISPLAY=:0 npm start
            npm ERR! Linux 4.4.38-v7+
            npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
            npm ERR! node v6.9.4
            npm ERR! npm  v3.10.10
            npm ERR! code ENOENT
            npm ERR! errno -2
            npm ERR! syscall open
            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            npm ERR! enoent This is most likely not a problem with npm itself
            npm ERR! enoent and is related to npm not being able to find a file.
            npm ERR! enoent
            npm ERR!     /home/pi/npm-debug.log
              @kurt you are in the wrong directory again cd ~/MagicMirror
              • K Offline
                kurt
                I’m in the /home/pi/MagicMirror/config - file
                Is this the wrong one?
                and what does it mean “cd ~/Magic Mirror”
                strawberry 3.141S T 2 Replies Last reply Reply Quote 0
                  @kurt
                  your logs show what you are not in /home/pi/MagicMirror/config with the terminal console
                  if you type in that command you will be in the correct directory cd means change directory
                  after that do DISPLAY=:0 npm start
                  • T Offline
                    tosti007 Module Developer @kurt
                    @kurt if you are on /home/pi/MagicMirror/config then you have to move one folder up. You can do this by typing cd ..
                    If there is anything don’t hesitate to contact me!
                    ProfileSwitcher, TouchNotifications
                    • K Offline
                      kurt
                      WoW strawberry3.141 you made my day!
                      I’m looking hot, so they say :)
                      is it so that I have to typ in first the : cd ~/MagicMirror to get into the right directory, and is this the same I can see in my FTP Client?
                      Thanks a lot for your help, I’m just happy and thankfull.
                      Without you guys it would be impossible to get into that projekts so quick.
                      So I guess this the moment for the beer! Cheers and thank you again.
                      Now after some break I will start with the adaptions…
                      Do you have any hints for the best way to avoid problems with this adaption?
                      What a day
                      Greetings kurt
                        @kurt it’s past 4 o’clock so no reason to drink no beer :D cd ~ ist the same as cd /home/pi/
                        i dont know which directory you are looking at in the client but i guess its the same.
                        what adaptions do you mean? styling, more modules, …?
                        • T Offline
                          tosti007 Module Developer @strawberry 3.141
                          @strawberry-3.141 I think he means changing his config file and maybe adding in some more modules. So time to get your app up and running :P
                          @Kurt I would start by first using the default modules (like calendar, time, etc). If you aren’t sure you changed it correctly then you can always just change one thing at the time and make sure it still works.
                          • K Offline
                            kurt
                            Yes, thats what i’ll do. Step by step. just change the rss feed or the compliments (does it matter how many of them you put into the modul?) weatherforcast…
                            Also Thanks to @tosti007
                            I feel comfortable in this forum!
                            @strawberry-3-141 by the way you are working on an hot app?
                              @kurt my bachelor thesis is about a mobile app to configure the mirror
                              cause you are from vienna, you might want to checkout my transport module for vienna https://github.com/fewieden/MMM-WienerLinien
                              • T Offline
                                @kurt no it doesn’t matter how many compliments you put in. And good to hear that you feel comfortable :) and you’re welcome!
                                • K Offline
                                  kurt
                                  @strawberry-3-141 Hey I allready visit it today! while drifting thru the forum. suprise! I lived in Barawitzkagasse for quite a long time. funny small world, isn’it?
                                  Is the modul allready finished or are still in it?
                                    @kurt it should be finished
                                    K 2 Replies Last reply Reply Quote 0
                                    • K Offline
                                      kurt @strawberry 3.141
                                      @strawberry-3.141
                                      fine , is on my list :)
                                      • K Offline
                                        @strawberry-3.141
                                        Hallo strawberry
                                        Can you pleas tell me whats wrong with my config.js
                                        By now nothing is shown. I wanted to impement the W.Linien modul, but also the weatherforcast was not shown.
                                        Thank you in advance
                                        Kurt
                                        /* Magic Mirror Config Sample
                                         * MIT Licensed.
                                        var config = {
                                        	port: 8080,
                                        	language: 'de',
                                        	timeFormat: 24,
                                        	units: 'metric',
                                                              module: "MMM-WienerLinien",
        api_key: "NZXDPzyd3QsAtTCT",
        stations: ["142", "141"],
                                        			module: 'alert',
                                        			module: "updatenotification",
                                        			position: "top_bar"
                                        			module: 'clock',
                                        			position: 'top_left'
                                        			module: 'compliments',
                                        			position: 'lower_third'
                                        			module: 'currentweather',
                                        			position: 'top_right',
                                        				locationID: '',  //ID from http://www.openweathermap.org
                                        				appid: 'xxxxxxxxxxxxxxxxxxx'
                                        			module: 'weatherforecast',
                                        			header: 'Das Wetter',
                                        				locationID: '5128581',  //ID from http://www.openweathermap.org
                                        			module: 'newsfeed',
                                        			position: 'bottom_bar',
                                        				feeds: [
                                        						title: "Der Standard",
                                        						url: "http://derstandard.at/?page=rss&ressort=Seite1"
                                        				showSourceTitle: true,
                                        				showPublishDate: true
                                        I 2 Replies Last reply Reply Quote 0
                                        • I Offline
                                          in_a_days @kurt
                                          @kurt
                                          You’re missing a } here
                                                             api_key: "xxxxxxxxxxx",
                                          should be
                                          Could be other issues, but check that out first :)
                                          K FrühstückF 2 Replies Last reply Reply Quote 2
                                          • I Offline
                                            in_a_days @kurt
                                            @kurt
                                            Also, it’s a good idea to remove your personal API codes when sharing your config file(s).
                                            • 1 / 4
