    Hello everyone, do you know if there is an MM module for rugby
    105 Posts 5 Posters 171.2k Views 6 Watching
      manu85340 @sdetweil
      @sdetweil Thank you for your response and for your help but I am unable to rewrite this…unless you help me
        sdetweil @manu85340
        @manu85340 I understand. that’s why I moved it to requests… in hopes there is someone else interested and capable.
        M 1 Reply Last reply
          Manu85 @sdetweil
          @sdetweil Thanks Sam, hope someone can help me
          mumblebajM 1 Reply Last reply
          • mumblebajM
            mumblebaj Module Developer @Manu85
            @Manu85 Just out of interest, what would you like to see from the module? There are loads of information
            M 2 Replies Last reply
              manu85340 @mumblebaj
              @mumblebaj hello and thank you for your response, I would like (if possible) to have a module like soccer, live match results, team rankings with points, number of matches played, goals scored, goals collected, for the top 14 France, the 6 nations tournament, the world cup, if the module could display these elements in rotation for example 30 seconds live matches, 30 seconds the ranking etc. all if possible with the badges of each team, this is my request to Santa 😁 I will try to find a similar MM module and send you the link, thank you again for your help
                @mumblebaj
                a module like this: https://github.com/0m4r/MMM-SoccerLiveScore
                • mumblebajM
                  mumblebaj Module Developer @manu85340
                  @manu85340 Nice idea. I was just interested in what you would like to see from the module. Wasn’t really volunteering for one. :-)
                  The API’s from the link you shared initially, some work and others don’t. The data is huge and can’t see any documentation explaining it. Would be a guessing game for somebody to put this together.
                    Manu85 @mumblebaj
                    @mumblebaj I had hope… but I understand that it must be crazy work! I told myself, with my little brain, that someone could take inspiration from the football module and add the rugby teams, but I understand that it is not as simple as writing requests on a forum :beaming_face_with_smiling_eyes:
                    • mumblebajM
                      @Manu85 You can have a look at the following. I think there is room for some improvements but you can use the first pass. Please check the README carefully for leagues and other options etc.
                      MMM-Rugby
                      M 3 Replies Last reply
                        Manu85 @mumblebaj
                        @mumblebaj A big thank you, you are fantastic, I will try this module quickly, thank you for your work
                          Manu85 @mumblebaj
                            Manu85 @Manu85
                              Manu85 @mumblebaj
                              @mumblebaj I’m reading the readme and I don’t see the “top 14” do you think it’s possible to add it? Strength to you and the ZAF🏉
                              mumblebajM 2 Replies Last reply
                              • mumblebajM
                                @Manu85 Unfortunately those are not part of the API. From what I could see he was creating tables from CSV files manually for those.
                                • mumblebajM
                                  @Manu85 There is another API that would give us results for this but it does mean that you would have to subscribe to it. I will have a look at incorporating it into the code. Will give the option to use the free API with the current available stats, and using the other and what is available on there. Will have a look when I have some time this week.
                                    Manu85 @mumblebaj
                                    @mumblebaj Magnificent !!! I hope you will succeed (but I have no doubt of it :-))
                                      Manu85 @mumblebaj
                                      @mumblebaj I see an ‘intruder’ match, it’s the one I circled in red, it’s not teams from the Six Nations tournament.
                                      competition: ["Six Nations 2024"],
                                      I don’t know if you can do anything, I also saw that you were going to work again on the presentation of the tables, it will be great
                                        Manu85 @mumblebaj
                                        @mumblebaj there is another match, the first which is not part of the six nations, I will give you my js config, I may have made mistakes, thank you for your help
                                                		module: "MMM-Rugby",
                                                		disabled: false,
        updateInterval: 1000*60*60*24,
        rotateInterval: 60000,
        rankingLimit: 10,
        matchesLimit: 10,
        matchesOlderThan: 7
                                        • mumblebajM
                                          @Manu85 Thanks for the feedback. Will have a look at the above. The table display may not get any better for this.
                                          Will see if I can trace why those 2 matches are in the results. They certainly should not be.
                                            @mumblebaj ok, thank you for your work
                                            • 1 / 6
