    Hello everyone, do you know if there is an MM module for rugby
    105 Posts 5 Posters 170.1k Views 6 Watching
    • mumblebajM
      mumblebaj Module Developer @manu85340
      @manu85340 Nice idea. I was just interested in what you would like to see from the module. Wasn’t really volunteering for one. :-)
      The API’s from the link you shared initially, some work and others don’t. The data is huge and can’t see any documentation explaining it. Would be a guessing game for somebody to put this together.
      M 1 Reply Last reply
        Manu85 @mumblebaj
        @mumblebaj I had hope… but I understand that it must be crazy work! I told myself, with my little brain, that someone could take inspiration from the football module and add the rugby teams, but I understand that it is not as simple as writing requests on a forum :beaming_face_with_smiling_eyes:
        mumblebajM 1 Reply Last reply
        • mumblebajM
          mumblebaj Module Developer @Manu85
          @Manu85 You can have a look at the following. I think there is room for some improvements but you can use the first pass. Please check the README carefully for leagues and other options etc.
          MMM-Rugby
          M 3 Replies Last reply
            Manu85 @mumblebaj
            @mumblebaj A big thank you, you are fantastic, I will try this module quickly, thank you for your work
              Manu85 @mumblebaj
                Manu85 @Manu85
                  Manu85 @mumblebaj
                  @mumblebaj I’m reading the readme and I don’t see the “top 14” do you think it’s possible to add it? Strength to you and the ZAF🏉
                  mumblebajM 2 Replies Last reply
                  • mumblebajM
                    @Manu85 Unfortunately those are not part of the API. From what I could see he was creating tables from CSV files manually for those.
                    • mumblebajM
                      @Manu85 There is another API that would give us results for this but it does mean that you would have to subscribe to it. I will have a look at incorporating it into the code. Will give the option to use the free API with the current available stats, and using the other and what is available on there. Will have a look when I have some time this week.
                        Manu85 @mumblebaj
                        @mumblebaj Magnificent !!! I hope you will succeed (but I have no doubt of it :-))
                          Manu85 @mumblebaj
                          @mumblebaj I see an ‘intruder’ match, it’s the one I circled in red, it’s not teams from the Six Nations tournament.
                          competition: ["Six Nations 2024"],
                          I don’t know if you can do anything, I also saw that you were going to work again on the presentation of the tables, it will be great
                            Manu85 @mumblebaj
                            @mumblebaj there is another match, the first which is not part of the six nations, I will give you my js config, I may have made mistakes, thank you for your help
                                    		module: "MMM-Rugby",
                                    		disabled: false,
                                            	        updateInterval: 1000*60*60*24,
                                                    rotateInterval: 60000,
                                                    rankingLimit: 10,
                                                    matchesLimit: 10,
                                                    matchesOlderThan: 7
                            • mumblebajM
                              @Manu85 Thanks for the feedback. Will have a look at the above. The table display may not get any better for this.
                              Will see if I can trace why those 2 matches are in the results. They certainly should not be.
                                manu85340 @mumblebaj
                                @mumblebaj ok, thank you for your work
                                • mumblebajM
                                  @manu85340 Busy working on the below. Hopefully I will have a release ready this weekend.
                                  • mumblebajM
                                    @manu85340 Starting to look a lot better. Now to work on the match data.
                                      Manu85 @mumblebaj
                                      @mumblebaj you are the best !!!
                                      If you want you can delete the country comnne and can the column headers be “changeable” in French?
                                      Pld = MJ / W=V / D=N / L=D /
                                      GF= I think points marked? if that’s it then if possible PM
                                      GA= I think not cashed? if that’s it then if possible PE
                                      and for pts no problem
                                      This is only if it is possible, if it is configurable this would give a possibility of configuration for the countries where your module is installed.
                                      But you are on top, BRAVO
                                      • mumblebajM
                                        @Manu85 I can look at adding a Translation option. The fields are as follows.
                                        Rank
                                        Flag
                                        Team
                                        Country
                                        PLD=Played
                                        W = Win
                                        D = Draw
                                        L = Lose
                                        GF = Goals For
                                        GA = Goals Against
                                        Pts = Points
                                        If you can provide me with the French equivalent then I can add it.
                                        Still have a bit of work to do on the Previous tables.
                                          Manu85 @mumblebaj
                                          @mumblebaj Yes!!! Below is the French translation if you want the diminutives so that it takes up less space, tell me
                                          Rank = Classement
                                          Flag = écusson
                                          Team = équipe
                                          Country= pays
                                          PLD=Joué
                                          W = Gagné
                                          D = nul
                                          L = Perdu
                                          GF = Marqués
                                          GA = Encaissés
                                          Pts = Points
                                          • mumblebajM
                                            @Manu85 said in Hello everyone, do you know if there is an MM module for rugby:
                                            PLD=Joué
                                            W = Gagné
                                            D = nul
                                            L = Perdu
                                            GF = Marqués
                                            GA = Encaissés
                                            Pts = Points
                                            Are there ay short codes I can use for these? The table will become too big with the full text
                                            M M 3 Replies Last reply
                                            • 1 / 6
