    Hello everyone, do you know if there is an MM module for rugby
    105 Posts 5 Posters 170.1k Views 6 Watching
    • mumblebajM
      mumblebaj Module Developer @Manu85
      @Manu85 Unfortunately those are not part of the API. From what I could see he was creating tables from CSV files manually for those.
      • mumblebajM
        @Manu85 There is another API that would give us results for this but it does mean that you would have to subscribe to it. I will have a look at incorporating it into the code. Will give the option to use the free API with the current available stats, and using the other and what is available on there. Will have a look when I have some time this week.
        M 3 Replies Last reply
          Manu85 @mumblebaj
          @mumblebaj Magnificent !!! I hope you will succeed (but I have no doubt of it :-))
            Manu85 @mumblebaj
            @mumblebaj I see an ‘intruder’ match, it’s the one I circled in red, it’s not teams from the Six Nations tournament.
            competition: ["Six Nations 2024"],
            I don’t know if you can do anything, I also saw that you were going to work again on the presentation of the tables, it will be great
              Manu85 @mumblebaj
              @mumblebaj there is another match, the first which is not part of the six nations, I will give you my js config, I may have made mistakes, thank you for your help
                      		module: "MMM-Rugby",
                      		disabled: false,
                              	        updateInterval: 1000*60*60*24,
                                      rotateInterval: 60000,
                                      rankingLimit: 10,
                                      matchesLimit: 10,
                                      matchesOlderThan: 7
              mumblebajM 1 Reply Last reply
              • mumblebajM
                @Manu85 Thanks for the feedback. Will have a look at the above. The table display may not get any better for this.
                Will see if I can trace why those 2 matches are in the results. They certainly should not be.
                  manu85340 @mumblebaj
                  @mumblebaj ok, thank you for your work
                  mumblebajM 2 Replies Last reply
                  • mumblebajM
                    mumblebaj Module Developer @manu85340
                    @manu85340 Busy working on the below. Hopefully I will have a release ready this weekend.
                    • mumblebajM
                      @manu85340 Starting to look a lot better. Now to work on the match data.
                        Manu85 @mumblebaj
                        @mumblebaj you are the best !!!
                        If you want you can delete the country comnne and can the column headers be “changeable” in French?
                        Pld = MJ / W=V / D=N / L=D /
                        GF= I think points marked? if that’s it then if possible PM
                        GA= I think not cashed? if that’s it then if possible PE
                        and for pts no problem
                        This is only if it is possible, if it is configurable this would give a possibility of configuration for the countries where your module is installed.
                        But you are on top, BRAVO
                        • mumblebajM
                          @Manu85 I can look at adding a Translation option. The fields are as follows.
                          Rank
                          Flag
                          Team
                          Country
                          PLD=Played
                          W = Win
                          D = Draw
                          L = Lose
                          GF = Goals For
                          GA = Goals Against
                          Pts = Points
                          If you can provide me with the French equivalent then I can add it.
                          Still have a bit of work to do on the Previous tables.
                            Manu85 @mumblebaj
                            @mumblebaj Yes!!! Below is the French translation if you want the diminutives so that it takes up less space, tell me
                            Rank = Classement
                            Flag = écusson
                            Team = équipe
                            Country= pays
                            PLD=Joué
                            W = Gagné
                            D = nul
                            L = Perdu
                            GF = Marqués
                            GA = Encaissés
                            Pts = Points
                            • mumblebajM
                              @Manu85 said in Hello everyone, do you know if there is an MM module for rugby:
                              PLD=Joué
                              W = Gagné
                              D = nul
                              L = Perdu
                              GF = Marqués
                              GA = Encaissés
                              Pts = Points
                              Are there ay short codes I can use for these? The table will become too big with the full text
                              M M 3 Replies Last reply
                                Manu85 @mumblebaj
                                @mumblebaj ok, you can put the following things:
                                PLD=J
                                W = G
                                D = N
                                L = P
                                GF = MA (if it possible Otherwise M)
                                GA = EN (if it possible Otherwise E)
                                Pts = Pts
                                  Manu85 @mumblebaj
                                  @mumblebaj you can even save a column (if you want) by making a single column of the difference of the points scored and conceded to have the goal-average: GA-GF and this column in French would be called “DIF” :-)
                                    @mumblebaj and for the top 14 there are 14 teams, so it would be great to have all 14, thank you again for your work
                                    • mumblebajM
                                      Points
                                      You can now do an update. Please take note of the requirements. You need to register for an API-KEY on API-SPORTS. Check the readme for new settings.
                                        Manu85 @mumblebaj
                                        @mumblebaj ok, I will try this as soon as I get home, I will let you know, thanks again
                                          Manu85 @mumblebaj
                                          @mumblebaj Hello when I go to the API-SPORTS site I have a page where I have a link for api rugby but when I click on the link the page returns me an error code, perhaps I am not in the right place , I need your help please, below is the link to the api-sports page and this from api rugby
                                          https://api-sports.io/
                                          API-SPORTS: https://v1.rugby.api-sports.io/
                                            Manu85 @mumblebaj
                                            @mumblebaj sorry I didn’t see that in the readme there was a link… I registered and when I am on the page I have several api sports when I click on api-rugby nothing happens
                                            • 2 / 6
